270cdi pressure plate.. - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Drivetrain (https://www.superturbodiesel.com/std/forumdisplay.php?fid=9) +--- Thread: 270cdi pressure plate.. (/showthread.php?tid=7573) |
270cdi pressure plate.. - bruno_pinho - 01-10-2017 Anyone can tell if the 270 cdi pressure plate is directly plugged into the om605 dual mass flywheel? RE: 270cdi pressure plate.. - Flo.Pe - 01-22-2017 Yes it will fit the OM605 DMF, only when you use the 5 speed gearbox from W202 C250TD then you must reduce the max way from the clutch pedal (2mm at the pedal stop point) because the throw out fork grind on the pressure plate housing. RE: 270cdi pressure plate.. - dieseltorque - 04-11-2017 Hi, if the pressure plate fits, then clutch disc from 270 cdi fits there aswell or not? |
