OM606 Turbo going into '95 W124 - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Other (https://www.superturbodiesel.com/std/forumdisplay.php?fid=19) +--- Forum: Projects (https://www.superturbodiesel.com/std/forumdisplay.php?fid=14) +--- Thread: OM606 Turbo going into '95 W124 (/showthread.php?tid=7595) |
OM606 Turbo going into '95 W124 - WDiesel - 01-24-2017 Long time coming, reached 425k miles on the OM606 NA, finally got the turbo block in and beginning the swap. Researching driveline solutions, I would like to go 5 speed, 6 speed manual would be even better. From what I've found so far mercedes options aren't the strongest? Is the clutch the only weak part? Consequently I've been looking at a BMW box with an adapter plate - I wouldn't mind a MErcedes option that bolts up however. RE: OM606 Turbo going into '95 W124 - erx - 01-25-2017 What power are you looking for? RE: OM606 Turbo going into '95 W124 - WDiesel - 01-27-2017 I want the car to be streetable without too much turbo lag. I was thinking an 8mm pump, but realistically it may not be the best for my scenario. I am in Southern California and do a lot of freeway driving - so maybe it wouldn't be an issue but I'm actually leaning towards a 7.5mm pump. Compound turbos seem like a good option to cut black smoke and lag, but I've not ruled out a good tuned single. Now I'm looking for the best option for a transmision RE: OM606 Turbo going into '95 W124 - erx - 01-27-2017 Are you planning over 600hp? If not then you definitely don't need 8mm. Dieselmeken can tune your RS203 pump from 606 na to 190cc with 7.5mm elements which means over 700hp. Even HX52 couldn't handle this. You can look for transmission after you have decided how far you go with hp. RE: OM606 Turbo going into '95 W124 - WDiesel - 01-27-2017 That's sound advice. I just read your build thread, very cool and informative. 183mph???? That's impressive, congrats. I'll take a lesson from you and go for a 7.5mm pump, aiming for over 600 horse. RE: OM606 Turbo going into '95 W124 - Mr_Robs - 02-03-2017 I have a bmw box re welded for an OM606 with clutch flywheel and pressure plate up in norcal for sale. I ended up deciding to go automatic in the end. I also have a BMW diff w/ factory LSD if you want to upgrade that too. RE: OM606 Turbo going into '95 W124 - WDiesel - 05-09-2017 Hey Mr_Robs, thanks for that - and sorry for delay in response. Your build thread is awesome! erx - thanks for your advise so far! *Update* I got a 716.xxx 6 speed gearbox from a w203 and a sprinter single mass flywheel kit. There's someone running 500bhp to the wheels from a om606 powered w124 with a Mercedes gear box - I also really wanted to keep the driveline Mercedes. A cherry on top would be to relocate the parking brake to a hand brake. Anyone know if the transmission cross member from the e400/r129 will bolt to an e300d chassis? The 6 speed box I'm swapping in uses the same mount. I'll likely weld and modify the existing cross member. The e400 option does appear more rigid. To deal with the turbo block sump clearance issue on the w124 chassis I was planning on swapping in an R129 bar as I've found they fit. Another option is to install the sump pan from the 95 na on the turbo motor. I'd prefer to keep the turbo sump as it doesn't have the extra oil cooler off to the side of the sump, which also means less gaskets down there to worry about. RE: OM606 Turbo going into '95 W124 - WDiesel - 05-15-2017 Here's a short video showing the wear line from the stock OEM rear main seal https://www.youtube.com/watch?v=g4thCW5QFnk RE: OM606 Turbo going into '95 W124 - WDiesel - 09-03-2017 Finally got the block in! https://www.youtube.com/watch?v=gZICsfdt1go Can anyone tell me the name of this part on the bottom of the transmission? https://flic.kr/p/YbgFmi RE: OM606 Turbo going into '95 W124 - WDiesel - 09-04-2017 Bump? RE: OM606 Turbo going into '95 W124 - winmutt - 09-05-2017 Still got the trans? Is the x5 diesel? RE: OM606 Turbo going into '95 W124 - WDiesel - 10-27-2017 Not sure what you mean winmutt - I do not have the old trans if that's what you're asking. Here's the most recent update video: https://www.youtube.com/watch?v=wDQ0aHrXzsU RE: OM606 Turbo going into '95 W124 - WDiesel - 11-09-2017 Got the trans crossmember back! https://www.youtube.com/watch?v=GQbnibtX3Gw RE: OM606 Turbo going into '95 W124 - WDiesel - 11-13-2017 https://www.youtube.com/watch?v=VwROpHr4ALo Got the xmeber bolted i! RE: OM606 Turbo going into '95 W124 - WDiesel - 11-15-2017 A video showing the next ssteps: shift linkage mount, slip yoke lengthening and the hand brake. I've seen some good looking handbrakes from old Porsche - I'll keep you posted. https://www.youtube.com/watch?v=xxD78FngvdI I've also picked up a sponsor - if you are inclined to day any shopping for every day carry items check out the link in the video bio. Thanks all for watching and shooting me questions, feedback and suggestions RE: OM606 Turbo going into '95 W124 - WDiesel - 03-30-2018 Got the handbrake and trans shifter mounting points welded in https://www.youtube.com/watch?v=jPPv1doV6Cg Here's a link to a playlist of 20 + videos cataloging the process of the build so far https://www.youtube.com/watch?v=0AmRxrf8f6A&list=PLrVclkjDHXeL3Dmt9Me1lcp1kpXPzX4i1 RE: OM606 Turbo going into '95 W124 - W140 - 04-05-2018 will the stock gearbox handle well with modded om606 ? RE: OM606 Turbo going into '95 W124 - WDiesel - 04-17-2018 Sorry for delay -- from what I've found online it should be ok - either way sub to my youtube if you want to see (I'm more active there) cause if it breaks I'll throw a video up there RE: OM606 Turbo going into '95 W124 - WDiesel - 04-19-2018 I found a shop to shorten the front driveshaft locally, they also regularly service shafts by mail https://youtu.be/FyVxWR13NOw RE: OM606 Turbo going into '95 W124 - WDiesel - 05-13-2018 No mod front driveshaft option: https://www.youtube.com/watch?v=kEBOMbLW6eg and answer a few questions about shifter, pedal and hand brake mount RE: OM606 Turbo going into '95 W124 - WDiesel - 05-30-2018 Here's what the intercooler setup is looking like so far https://www.youtube.com/watch?v=a8luQQ1rPZQ RE: OM606 Turbo going into '95 W124 - WDiesel - 06-15-2018 Intercooler mounted: https://www.youtube.com/watch?v=OsgoA9q1mOc RE: OM606 Turbo going into '95 W124 - WDiesel - 10-30-2018 Here's a quick vid of the car running: https://www.youtube.com/watch?v=dbRbuBKRio8 I relocated the oil cooler and am making the intercooler mount more minimal: https://www.youtube.com/watch?v=_NcctMudjck |
