Sprinter clutch - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Drivetrain (https://www.superturbodiesel.com/std/forumdisplay.php?fid=9) +--- Thread: Sprinter clutch (/showthread.php?tid=7616) |
Sprinter clutch - bruno_pinho - 02-09-2017 Hi Know if this kit gives in 606 with 6-speed gearbox? http://www.ebay.co.uk/itm/Mercedes-Benz-Sprinter-2-2-CDi-16V-Dual-Mass-Replacement-Flywheel-Clutch-Kit-/172400773792?hash=item2823e30aa0:g:DcUAAOSwcUBYH8uG RE: Sprinter clutch - svengali0 - 03-14-2017 Good question. Sorry I don't have an answer but I also need two smf & clutch kits for a OM605/716.647 and OM662/716.647 for my g wagons. Hoping some one can advise on this listing. RE: Sprinter clutch - Max - 03-16-2017 Looks like a Copy of the Valeo Kit. So it may work. Valeo kit Works with 605/606 and 716.6XX Greets Max RE: Sprinter clutch - peter - 03-29-2017 Does the flywheel and clutch from 270cdi also fitt to 60x engines? RE: Sprinter clutch - jim8280 - 04-01-2017 The one in the link is the kit i have in mine all fits well and works as it should RE: Sprinter clutch - Max - 04-01-2017 Anyone knows if the Sprinter Kit works with the Stock 5 Speed Transmissions with short Inputshaft ? |
