722.6 ML Class Gearbox output splines - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Drivetrain (https://www.superturbodiesel.com/std/forumdisplay.php?fid=9) +--- Thread: 722.6 ML Class Gearbox output splines (/showthread.php?tid=7689) |
722.6 ML Class Gearbox output splines - ross - 04-06-2017 Does anyone on here know the size of the output splines on an ML class version of the 722.6? Or know where I might find it? Thanks in advance! RE: 722.6 ML Class Gearbox output splines - whipplem104 - 04-06-2017 are you asking about the transmission shaft or the output that bolts on?? RE: 722.6 ML Class Gearbox output splines - ross - 04-06-2017 (04-06-2017, 07:56 AM)whipplem104 are you asking about the transmission shaft or the output that bolts on?? The output that bolts on, the ~50ish mm diameter female spline. RE: 722.6 ML Class Gearbox output splines - whipplem104 - 04-06-2017 Well normally you measure diameter and count the splines. So I would say it is 55mm 26 spline. It might be 54mm. I do not have my good calipers here today. Just used some brake calipers Splines are really standard so you should be able to find the standard sizes RE: 722.6 ML Class Gearbox output splines - ross - 04-07-2017 Yeah, but there are all sorts of shapes of spline, lots of different standards. RE: 722.6 ML Class Gearbox output splines - whipplem104 - 04-07-2017 What are you trying to find out if it fits? RE: 722.6 ML Class Gearbox output splines - ross - 04-07-2017 I need the original specification of the spline so I can have a spline machined to match it on my adaptor shaft. RE: 722.6 ML Class Gearbox output splines - whipplem104 - 04-07-2017 Ok, It is the same as the JEEP srt8 and the wranglers with the nv t cases. You might find more info looking for those. RE: 722.6 ML Class Gearbox output splines - ross - 04-19-2017 Thanks Whipple ![]() I've actually contacted Mercedes UK, and I've had a response! ![]() RE: 722.6 ML Class Gearbox output splines - matfield - 06-29-2017 Ross... would you have a measurement from bell housing to the rear output flange that bolts onto the Merc transfer box? Thanks Mat RE: 722.6 ML Class Gearbox output splines - ross - 07-04-2017 (06-29-2017, 05:39 AM)matfield Ross... would you have a measurement from bell housing to the rear output flange that bolts onto the Merc transfer box? The back face where the adaptor bolts on? There's a small link bit/adaptor on the ML box. I haven't got the measurement to hand, but I can get it for you? |
