OM606 Injectors stuck! help! - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Engine (https://www.superturbodiesel.com/std/forumdisplay.php?fid=7) +--- Thread: OM606 Injectors stuck! help! (/showthread.php?tid=7740) |
OM606 Injectors stuck! help! - ak47is1337 - 05-13-2017 I think my injectors are stuck due to moron past owners! I say that the past owners messed it up because they jb-welded the glow plugs into place does anybody have ideas? Maybe I am doing something wrong? I am using this tool: http://www.ebay.com/itm/Diesel-Engine-Injector-Socket-Removal-Tool-22mm-1-2-Drive-For-Mercedes-/262879132978?hash=item3d34d13d32:g:HEgAAOSw~AVYuVBh I am pushing HARD on this thing counterclockwise, hard enough to move the car forwards in park. Should I resort to the ryobi impact? blast it with torch? help! RE: OM606 Injectors stuck! help! - Hercules - 05-14-2017 Have you tried a four ft. or longer pipe on your breaker bar,and give a hard jerk,is not the steady pull that works best. Don"t think that tool will hold the stress. RE: OM606 Injectors stuck! help! - barrote - 05-15-2017 Pneumatic hammer wrench.... If u keep on pushing with big breaker bars u will end up braking the tool. With impact wrench its like butter in a dog nose. I bet my ass ... RE: OM606 Injectors stuck! help! - Fishman - 05-15-2017 Did mine yesterday. Took a lot of force to break them loose. Impact wrench should do the job. RE: OM606 Injectors stuck! help! - Hario' - 05-15-2017 They aren't torqued to a very high setting, but I always have better luck with a breaker bar over any electric 'rattle gun' |
