will i need to build new exhaust? - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Engine (https://www.superturbodiesel.com/std/forumdisplay.php?fid=7) +--- Thread: will i need to build new exhaust? (/showthread.php?tid=7756) |
will i need to build new exhaust? - Devil3344 - 05-25-2017 I have a s124 300tdt (om603), engine is original with adjusted diesel pump and turbo pressure. Is there more horse power to pick up if I build new exhaust in 3 "or are there other things I can do? RE: will i need to build new exhaust? - Devil3344 - 05-27-2017 No one? RE: will i need to build new exhaust? - awsrock - 05-27-2017 Aadjusted to max or with bigger elements? Either way, stock exhaust is kind of small, some bends get down to 2". You will gain some n/a torque as well as flow a bit better in high rpm but the more fuel you have the more you will notice it RE: will i need to build new exhaust? - mrfajita - 05-29-2017 Mine is 3" straight pipe from the second turbo all the way to the bumper. Works fine with my compounds, but I'll see if it needs upgraded when I upgrade my injection pump. Unfortunately due to the layout of my engine bay I can't fit larger than a 3" downpipe, and even that had to be oval pipe and requires a hammer to install RE: will i need to build new exhaust? - Devil3344 - 05-30-2017 (05-27-2017, 07:34 PM)awsrock Aadjusted to max or with bigger elements? Either way, stock exhaust is kind of small, some bends get down to 2". You will gain some n/a torque as well as flow a bit better in high rpm but the more fuel you have the more you will notice it Pump is orginal, no bigger elements..but i can probably adjust a little more on the pump, but not mutch.. i removed the catalyst and the last silencer, but i still feel the exhaust does not go out fast enough.. |
