FPR connection (603 filter) - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Engine (https://www.superturbodiesel.com/std/forumdisplay.php?fid=7) +--- Thread: FPR connection (603 filter) (/showthread.php?tid=7757) |
FPR connection (603 filter) - TomasMB - 05-25-2017 Hi, could you instruct me about connection of fuel pressure regulator ? God Meken told us, that presure for his new pumps should be about constant 1,5 bar. So i bought 044 lift pump and FPR, but im pretty not sure where to put that FPR. picture here: http://tomasmb.rajce.idnes.cz/FPR/#DSC_2379.jpg ![]() RE: FPR connection (603 filter) - Jonas - 05-25-2017 In my opinion there is no need to change pump the orginal lift pump makes aprox 1.0bar no need for more pressure. If you are going beyond 400hp then you can think about changing the orginal lift pump. RE: FPR connection (603 filter) - Sultzi - 05-25-2017 I have connected the fpr in the line between injection pump out port and filter housing back port. And then replaced that filter housing back ports banjo bolt with regular bolt, so only return line to the tank leaves from the fpr. Also overflow from the injectors is after the fpr in the original place and fitting (where is that regular bolt instead of banjo bolt). Hope you understand ![]() RE: FPR connection (603 filter) - TomasMB - 05-25-2017 If i understand correctly, this is the right way: Picture: http://tomasmb.rajce.idnes.cz/FPR/#FPR_1_STD.jpg Yep? Thanks a lot. ![]() RE: FPR connection (603 filter) - Sultzi - 05-27-2017 I have the fpr in the place of number "4" in the line and that number "5" which is overflow from the injectors goes to stock place in the fuel filter housing. I just have replaced that fuel filter housing "back" port banjo bolt with normal bolt so there is no connection to inside the fuel filter housing anymore. I mean this connection -> http://www.benzworld.org/forums/attachments/w123-e-ce-d-cd-td/326320d1282429866-1985-300d-fuel-line-replacement-fuel-head-002.jpg and replaced that banjo bolt with regular bolt (with correct thread) and route the line from the fpr to the other connection on the fitting and return line leaves from the another barb to the tank. And overflow from the injectors is connected as stock. You can do this probably another way too, like you draw, but I did this way (easier to connect that overflow). RE: FPR connection (603 filter) - whipplem104 - 05-27-2017 This is much easier than all of this. Just hook up the lines all stock with the stock banjo bolt and all. You simply put the FPR before the filter so that you are regulating the fuel into the system. We did ours all in the rear of the car and I simply tee'd in at the return line to the tank and so all the return flow from the regulator is going straight back into the tank. All the lines in the engine bay are configured as stock. If I could I would have the return from the FPR go straight into the tank in a separate line. I worry about having an increase in the return line pressure and causing issues on that side. But so far I have not seen an issue. This way you are also not running full fuel volume that the pump runs through the filter all the time. The filter can just barely handle the amount of fuel that an 044 can run at full tilt. As the filter gets clogged up under normal conditions if you are regulation pressure downtstream instead of upstream you are going to increase pressure at the inlet to the filter. RE: FPR connection (603 filter) - TomasMB - 05-31-2017 Well, thank you for valuable answers ![]() Anyone else has any working solution? I´m still thinking about best way... RE: FPR connection (603 filter) - Hario' - 06-01-2017 ![]() I am fitting fpr downstream of IP to get best regulated pressure like on petrol system fuel rail. Like so: ![]() Installing.. ![]() Injector leakoff will tee in downstream of fpr with this: |
