hi i need help - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Engine (https://www.superturbodiesel.com/std/forumdisplay.php?fid=7) +--- Thread: hi i need help (/showthread.php?tid=7807) |
hi i need help - bans21 - 07-18-2017 Hi, I like to upload a thread for a new project, what happens is that my English is very bad. I have 2 engines of 5 cylinders a 2.5 turbodiesel and another of direct injection 2.9 td of a donor e290 td. Over time arm the e290 and a pump line type m with elements 5.5mm and achieve a good results on the part of fuel economy but very very little power said so only I get to raise it to 4000 rpm. And all those rpm almost pulling the car from the gulf by a mountain. Now I would like to know that it would be better to do without selling my soul. I had thought of doing the following to make a mixture of parts to be able to gain some advantage of what I have. I explained my idea, crankshaft 2.9 and crankshaft + pistons 2.5td and I think with that you get a 2.7td pre-cam which would achieve 5000 rpm with good reliability and good torque. Another idea I have is to leave the 2.5td engine like this and only upgrades injectors and turbo variable type with these other parts. For more improvements ajet injectors a vw which is in 2 phases a 135bar I think and another 155 bars, with my pump injector m could run without problems. For more things I have a turbo vw 1749v that with that and an arduino controller that I have almost finished I think I can maintain an almost constant 1bar from 1300rpm to almost 4500rpm (all this part is theory) Now I need your advice that I can do or see better to do. I am not looking for many I value with 150hp and a decent torque from 1500rpm and with that I am happy. Greetings bans21 Pd .: all ideas as well as criticism are accepted with pleasure RE: hi i need help - Simpler=Better - 07-24-2017 I'm not familiar with those engines, but you should be able to get 150hp from a 2.5L engine easily |
