Turbo boost Controller - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Engine (https://www.superturbodiesel.com/std/forumdisplay.php?fid=7) +--- Thread: Turbo boost Controller (/showthread.php?tid=7943) |
Turbo boost Controller - Frank606 - 01-09-2018 Any one can Help There is so much confusion and many applications on how to fit a Manual boost Controller combined with a boost vacuum gauge I want to fit one of these for a internal wastegate set up Any one can send me a simple Diagram on this set up would be great Thanks RE: Turbo boost Controller - Fishman - 01-10-2018 Need more info. Original turbo has vacuum actuator. RE: Turbo boost Controller - Frank606 - 01-10-2018 Hi Thanks for your Reply Turbo is a upgrade TD04HL16T internal Wastgate and Vacuum Actuator And The Ecu has Been Chipped RE: Turbo boost Controller - Fishman - 01-10-2018 Since it is vacuum operated, you can't use a boost controller. Maybe if you connect it the 'wrong' way?? |
