Noise dissapears above 2000rpm - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Engine (https://www.superturbodiesel.com/std/forumdisplay.php?fid=7) +--- Thread: Noise dissapears above 2000rpm (/showthread.php?tid=7969) |
Noise dissapears above 2000rpm - addi.bigg - 02-07-2018 OM605 7,5mm Dieselmeken elements, mechanical pump. Timing is in place, adjusted to the stock value. The symptom is that while running in low rpm (1200-1300rpm), pressing the throttle pedal to speed up, some strange noise comes, some knocking which sudennly dissapears at 2000rpm. It seems like something is a bit late while increase the rpm and it's gain on at 2000rpm. Nothing above it. It always dissapears in the same rpm. Any ideas what that can be? RE: Noise dissapears above 2000rpm - CutWeldDrive - 02-08-2018 as far as i know the 7,5mm Dieselmeken elements have a different timing value to stock. someone maybe able to confirm or tell me i'm talking crap. but nearly sure i saw this somewhere RE: Noise dissapears above 2000rpm - Mr.Emo - 02-08-2018 Yeah, they usually send out instructions with the pump. RE: Noise dissapears above 2000rpm - addi.bigg - 02-09-2018 (02-08-2018, 11:50 AM)CutWeldDrive as far as i know the 7,5mm Dieselmeken elements have a different timing value to stock. The quantity is low 85-90ccm. I'm really not on the borderline from the upper side. RE: Noise dissapears above 2000rpm - addi.bigg - 02-09-2018 If the oil pump chain is not tight enough what kind of noise it can make? RE: Noise dissapears above 2000rpm - barrote - 02-09-2018 Mos probably the noise u mention is nailing due to excess advance in low rpm. Once the threshold is passed it goes. Replace timming sprocket by a 605 N/A. RE: Noise dissapears above 2000rpm - addi.bigg - 02-12-2018 (02-09-2018, 04:56 AM)barrote Mos probably the noise u mention is nailing due to excess advance in low rpm. I've sent you a pm. RE: Noise dissapears above 2000rpm - addi.bigg - 02-13-2018 https://www.youtube.com/watch?v=NuL12eCnDR8&feature=youtu.be Any suggestions regarding this noise? This is the one that dissapears. If the engine is cold it is louder. RE: Noise dissapears above 2000rpm - addi.bigg - 02-13-2018 (02-13-2018, 12:42 PM)addi.bigg https://www.youtube.com/watch?v=NuL12eCnDR8&feature=youtu.be In this you can hear when the noise dissapears. https://youtu.be/GK_naRLhslk RE: Noise dissapears above 2000rpm - NoFear - 08-07-2019 Same problem. What is the solution? RE: Noise dissapears above 2000rpm - barrote - 08-08-2019 Those engines in the videos sound really bad... my sugestion on the advance mechanism is still valid. Check out it is working properlly. Sometimes they do not, cause of a design flaw. Using a older 605 N/A solve the problem. But its definetly timing related... its god damm advanced... RE: Noise dissapears above 2000rpm - NoFear - 08-14-2019 Is this normal sound? https://youtu.be/jl55lNaYGz0 https://youtu.be/HTKOZvW_tik |
