OM612/OM647 bigger map sensor - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Engine (https://www.superturbodiesel.com/std/forumdisplay.php?fid=7) +--- Thread: OM612/OM647 bigger map sensor (/showthread.php?tid=7976) |
OM612/OM647 bigger map sensor - NiTeC - 02-14-2018 Folks, getting ready to tune the Sprinters and my tuner is complaining the stock 2.5bar map sensor is insufficient for any good performance tune... is there any other mercedes map sensor that can be used with these engines? the OM647 uses a Bosch EDC16 ECU similar to my VW/Audi TDi setup - is it a far stretch to think that the VAG 4bar map sensor can be made to work with the MB ecu? anybody run into these issues before? RE: OM612/OM647 bigger map sensor - Petar - 02-14-2018 I believe pretty much any 0-5v MAP sensor could be used and maps rescaled for it. But I could be wrong as I don't have much experience with that. RE: OM612/OM647 bigger map sensor - NiTeC - 02-15-2018 looks like the A0071530028 4Bar map sensor should do the trick...I've ordered one - we'll see what happens... RE: OM612/OM647 bigger map sensor - Sotvisp - 02-16-2018 Hello who is remapping the ECU ?? seems to be hard to get any info about this im in the beginning of a projekt learning how to program with Kess V2. Br Per RE: OM612/OM647 bigger map sensor - Turbo - 02-16-2018 I guess here you can find something interesting http://www.ecuconnections.com/forum/viewtopic.php?f=6&t=16242&sid=ddc5b79d23ebe53ed1747b47a2600bdf RE: OM612/OM647 bigger map sensor - starynovy - 02-17-2018 Yes sensor is good. Use linearisation: 20 102 921 1003 289 500 4000 4000 |
