617 turbo choices? myna pump - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Engine (https://www.superturbodiesel.com/std/forumdisplay.php?fid=7) +--- Thread: 617 turbo choices? myna pump (/showthread.php?tid=7980) |
617 turbo choices? myna pump - MTUPower - 02-18-2018 I'm taking the next steps and would like a better performing turbo on my 1984 300TD with a 617-95X. It's a stock turbo now. I'll be upgrading my exhaust to 3 inches and adding the older 617 high rise intake manifold. This is a daily driver and I want boost at low end but more power as well. My current 0-60mph is 9 seconds. Please advise. ![]() RE: 617 turbo choices? myna pump - R-3350 - 02-19-2018 depends on your budget. i would recommend something in the 35/lb min range which should be enough for good power and spool quite quickly. that could be a HX30, HE221W, various TD05 turbos, GT2860R, or a borg warner EFR6258. RE: 617 turbo choices? myna pump - awsrock - 02-19-2018 Do you know what size elements / cc the pump is? I assume 7mm since you have had it for a few years RE: 617 turbo choices? myna pump - atypicalguy - 02-19-2018 (02-18-2018, 10:26 PM)MTUPower I'm taking the next steps and would like a better performing turbo on my 1984 300TD with a 617-95X. It's a stock turbo now. I'll be upgrading my exhaust to 3 inches and adding the older 617 high rise intake manifold. This is a daily driver and I want boost at low end but more power as well. My current 0-60mph is 9 seconds. I cannot recall what your intercooler situation is, but you will need a good one before you try to burn that much fuel, probably. RE: 617 turbo choices? myna pump - MTUPower - 02-19-2018 (02-19-2018, 09:24 PM)atypicalguy(02-18-2018, 10:26 PM)MTUPower I'm taking the next steps and would like a better performing turbo on my 1984 300TD with a 617-95X. It's a stock turbo now. I'll be upgrading my exhaust to 3 inches and adding the older 617 high rise intake manifold. This is a daily driver and I want boost at low end but more power as well. My current 0-60mph is 9 seconds. |
