rebuilding Injetion nozzles - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Engine (https://www.superturbodiesel.com/std/forumdisplay.php?fid=7) +--- Thread: rebuilding Injetion nozzles (/showthread.php?tid=8001) |
rebuilding Injetion nozzles - peter - 03-16-2018 after a damaged glowplug with a burned of end i am giong to rebuild my nozzles. So my research endet in the result that om 606 engines have DN0SD310 original. I found DN0SD265 nozzles on dieselkontor.de that are recommended for std`s. I asked my self if the 265 nozzles are a better choice for an om606 with an modified pump. RE: rebuilding Injetion nozzles - firen456 - 03-16-2018 I have a set of DN0SD314 which are mounted in the OM606LA engine from factory. They are from Dieselsend rebuilt about 10000km ago. Contact me. I also have some other solution for nozzles which might fit you needs. RE: rebuilding Injetion nozzles - peter - 03-17-2018 Im sorry, this was my mistake Om606 NA have the 310 nozzels |
