Fitting an OM606 Turbo into a RHD w114 (steering interference) - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Engine (https://www.superturbodiesel.com/std/forumdisplay.php?fid=7) +--- Thread: Fitting an OM606 Turbo into a RHD w114 (steering interference) (/showthread.php?tid=8009) |
Fitting an OM606 Turbo into a RHD w114 (steering interference) - ChasesDragons - 03-23-2018 Hi all, I could really do with some advice here. I hear there are issues with the Turbo/exhaust interfering with the steering column in a Right Hand Drive W114. How do I get around this issue? Has the interefering bits been rerouted without losing performance? Any help appreciated. Also, do I assume that a normally aspirated OM605 or OM606 would fit without issue (apart from the front crossmember chops) Warmest Regards Udhi RE: Fitting an OM606 Turbo into a RHD w114 (steering interference) - NZScott - 03-23-2018 Can't help with the /8 but other RHD cars like 116 and 123 take 60x just fine. You should get a new exhaust made when doing the swap regardless. I had a 617A in my RHD 123 and the only issue was the air filter housing rubbing on a brake line at the master cylinder RE: Fitting an OM606 Turbo into a RHD w114 (steering interference) - ChasesDragons - 03-24-2018 Thank You mate. My concern is the wiggle room available to avoid the interference. I am not sure what exactly interferes and if it can br worked around. Even a talented boy like Monstercrawlers had chosen a lhd to install the om606 in the UK. RE: Fitting an OM606 Turbo into a RHD w114 (steering interference) - ChasesDragons - 04-28-2018 Anyone? This is probably too simple and boring question for most of you here, but its seriously hamstringimg my dreams. RE: Fitting an OM606 Turbo into a RHD w114 (steering interference) - madmog - 06-17-2018 I can't help from direct experience but only option seems to be to create a new manifold to move everything out of the way. W114/5 is much narrower than W123, W126. Less room to get everything in. With regard to loss of performance, if manifold well designed, no sharp angles it should be a negligible difference. It's not like a naturally asparated petrol engine where manifold shape makes a bigger difference to fueling, as the fuel is injected and the air is wumped in by the turbo. |
