spare head for 617 95X - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Engine (https://www.superturbodiesel.com/std/forumdisplay.php?fid=7) +--- Thread: spare head for 617 95X (/showthread.php?tid=8019) |
spare head for 617 95X - MTUPower - 03-29-2018 I bought a wagon block with the head and it's in my garage. I read somewhere where someone had ported the head on his MB diesel and the results were another 5% more power or so. Who has experience with this and where can I send my head to to get this done? I'd like to put a new turbo on and increase the exhaust to 3 inches, plus increase the holes in the prechambers even more than they are after I made them bigger. Give even more advance timing as well. Please advise as to head porting or any other mods... thx RE: spare head for 617 95X - R-3350 - 03-29-2018 iv done a few 617 heads now and i would say that with a larger turbo the effects are more than 5%. that being said there is some risk in porting these heads far enough to really make a difference as you can breach the port walls into the coolant jacket. also its a very long process i spent something like 30 hours on the last one i did. RE: spare head for 617 95X - MTUPower - 04-02-2018 looks like I have to find a engine head shop via google and send it to them for flow analysis and porting. RE: spare head for 617 95X - NZScott - 04-03-2018 How hard is ultrasonic depth measuring stuff to come by if we want to get rather keen with the die grinder? Probably need a mortgage? RE: spare head for 617 95X - R-3350 - 04-03-2018 the ultrasonic units that are easily available work ok and aren't too expensive however the transducer heads are a bit large to work in all the sections of the ports. i used to have access to some nice NDT equipment i used when i did the first head for my car. i worked out that the 617 heads don't tend to have much core shift at most 2-3MM in the thicker sections with port wall thickness around 7-8mm at its thinest. i have some photos from cutting a head into sections somewhere but i cant find them. as for flow benching a head and having a professional port them all the shops i talked to that i would trust to really know what they are doing either didn't want to touch it once i mentioned it was a Mercedes and diesel or wanted well into the 4 figure range to do it. you can do what i did and build your own flow bench and do a lot of research. its not like heads are all that rare or expensive. RE: spare head for 617 95X - atypicalguy - 04-04-2018 The wagon heads are quite rare in good, rebuildable condition. RE: spare head for 617 95X - MTUPower - 04-05-2018 There's a shop in NC which I've been talking to which seems like they will be able and willing to do this for me. |
