om605 injector leak?? - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Engine (https://www.superturbodiesel.com/std/forumdisplay.php?fid=7) +--- Thread: om605 injector leak?? (/showthread.php?tid=8042) |
om605 injector leak?? - Antonio - 04-30-2018 what could be the problem when engine runs there is some smoke coming from injector at the bottom... I was pressing it and it made sound (psshh). when i opened the hood it was wet above 4th cylinder. when engine is running it gets smoke from the bottom of injector, could be a bad injector, bad washer or something more serious? i had a problem with injector connecting hoses that were leaking diesel and slowly filling injector skirt. what is the best solution to fix that (hoses were new) om605- 6mm pump 100cc and stock 606 turbo cheers Antonio RE: om605 injector leak?? - Symondo - 05-26-2018 Hi Antonio, I had the same problem with ours. I had a combustion leak on no. 5. The pre chambers seem to loosen over time. creates a 'chuff chuff' noise while running. most noticeable at idle. i had to remove the injectors, Remove and re torque the pre chamber retaining collar. this does require a special splined MB socket. And long tube socket for injector removal. RE: om605 injector leak?? - Bigpanda16 - 05-28-2018 Take note that to "tighten up" the pre-chamber retaining rings: you must remove fuel hardlines, cam cover and the o-ringed trumpets as well as the fuel injectors themselves. If you let it be it will build up a nasty lack tar substance from the compression/fuel leak over time, very nasty to clean up. RE: om605 injector leak?? - Bigpanda16 - 05-28-2018 (05-28-2018, 02:01 PM)Bigpanda16 Take note that to "tighten up" the pre-chamber retaining rings: you must remove fuel hardlines, cam cover and the o-ringed trumpets as well as the fuel injectors themselves. If you let it be, it will build up a nasty black tar substance from the compression/fuel leak over time, very nasty to clean up. RE: om605 injector leak?? - Antonio - 06-11-2018 I have put another injector shims and was okay for a short amount of time... il try to do prechambers today and tomorow hopefully that is the problem... So i have info that prechambers go on 140nm tight, is that right? Do you heat injector shims before tightening injectors? Cheers Antonio |
