om605 intake manifold/plenum gasket - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Engine (https://www.superturbodiesel.com/std/forumdisplay.php?fid=7) +--- Thread: om605 intake manifold/plenum gasket (/showthread.php?tid=8110) |
om605 intake manifold/plenum gasket - veg124 - 09-08-2018 Hello! I have recently acquired a C250 w/ stock OM605. I'd like to get rid of an oil leak which could be from the rocker/valve cover gasket (have part, will replace), but I suspect it's the intake gasket between the head and plastic intake. All I can find are the little o-rings, but I'm assuming it is a gasket similar to the exhaust manifold gasket. I have searched high and low and used google images. No luck. Perhaps I'm daft...but I usually don't have problems finding basic parts like this. Cheers, Jon RE: om605 intake manifold/plenum gasket - barrote - 09-09-2018 Only O rings... no gasket in 605. RE: om605 intake manifold/plenum gasket - veg124 - 09-11-2018 Cheers! |
