Common rail diesel discussion thread - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Engine (https://www.superturbodiesel.com/std/forumdisplay.php?fid=7) +--- Thread: Common rail diesel discussion thread (/showthread.php?tid=8180) |
Common rail diesel discussion thread - baldur - 01-13-2019 It has been requested that I open a thread to discuss and share information about common rail diesel injection. I am in the process of developing a controller to run solenoid controlled injectors, and plan to create a different power supply for piezoelectric injectors. The difference there being that the solenoid injectors require high current and low voltage, although a moderate voltage (80 volts nominally) from a charged up capacitor is used to boost them during the opening phase to get a faster current rise. To keep them open requires only on the order of 6 volts. Piezoelectric injectors on the other hand need a couple hundred volts to open, with high initial current and this voltage must be maintained to keep them open, at negligible current. Then in order to close them they require an inverse current as the piezoelectric element has internal capacitance that must be discharged. Common rail is unique to most other injection control systems in that you have control over injection quantity and injection duration independently. Only other control system that offers this is hydraulically actuated unit injectors. Other solenoid controlled systems such as cam actuated unit injectors and injection pumps while allowing exact control of injection start and end do not have any way to control the rate of delivery during the injection. One advantage offered by direct electronic injection control that is not possible with rack controlled injection pumps is the ability to have multiple injection events during the combustion cycle. This feature is not unique to common rail but is also possible with some solenoid valve controlled unit injectors and some solenoid valve controlled injection pumps. The primary advantage of this is being able to use pre-injection to heat up the air prior to starting the main combustion event, as this accelerates ignition of the fuel injected for the main combustion event and thus reduces diesel knock which is caused by a too abrupt ignition of the fuel (too much fuel is introduced before it is able to ignite in the chamber) I will add more information to this post later. Feel free to ask any questions. RE: Common rail diesel discussion thread - firen456 - 01-14-2019 I wanna know something more about the EDC15/16 ecus from OM613/648. It seems that EIS, ESL, TCU and DAS and some ABS/ESP stuff is needed. The EIS will send a crypted can message to the ecu to start the engine. So we'll have to keep the EIS because it's to complicated to reengineer the crypted message. It seems there are two options to deal with the rest. First: Deleting all the DTCs in the ecu regarding ELS, DAS and TCU like wheelspeed and missing can bus devices and modify the ecu to start without them (gearlever in N or P for example). This seems to be the harder way. The easier solution might be to emulate all the can meassages the ecu wants do see via a can controller. Maybe something arduino based. There will of course have to be deleted some DTCs in the ecu because we don't want to run ELS, factory TCU, DAS and ESP. We must have a W210/211 car to reingeneer the can bus. To start the engine the gearleaver must be in N or P position. What other signals will the engine need to start? Maybe there can be found something in the WIS. Searching for some opinions or a little help from people who run these ecus in older cars. RE: Common rail diesel discussion thread - barrote - 01-14-2019 As of me, i'm dealing with changing mechanichal properties of bosch CRD system to operate under higher pressure and higher flow and reliable for the tunning fans. Electronically, as discussed a stand alone ECU without the vehicle electronics seem a lot viable. One feature must be present , the box must be switched in same socket as a EDC16 or have a kind of adapter. For the users without edc16 cars(loom) does not really matter which conector to work on. Injection opening resolution is of atmost importance weather the coil or the driver , need to be in line with needs. As there is no point using a diff nozzle if opening is not within 100's of milisecond. As example. RE: Common rail diesel discussion thread - baldur - 01-29-2019 I'm getting there. Running some tests on the prototype and if they all pass I will run an engine on it. ![]() ![]() RE: Common rail diesel discussion thread - madmog - 01-29-2019 (01-14-2019, 02:24 AM)firen456 I wanna know something more about the EDC15/16 ecus from OM613/648. It seems that EIS, ESL, TCU and DAS and some ABS/ESP stuff is needed. The EIS will send a crypted can message to the ecu to start the engine. So we'll have to keep the EIS because it's to complicated to reengineer the crypted message. It seems there are two options to deal with the rest. First: Deleting all the DTCs in the ecu regarding ELS, DAS and TCU like wheelspeed and missing can bus devices and modify the ecu to start without them (gearlever in N or P for example). This seems to be the harder way. The easier solution might be to emulate all the can meassages the ecu wants do see via a can controller. Maybe something arduino based. There will of course have to be deleted some DTCs in the ecu because we don't want to run ELS, factory TCU, DAS and ESP. We must have a W210/211 car to reingeneer the can bus. To start the engine the gearleaver must be in N or P position. What other signals will the engine need to start? Maybe there can be found something in the WIS. Searching for some opinions or a little help from people who run these ecus in older cars. RE: Common rail diesel discussion thread - AlanMcR - 01-30-2019 The coding can be moved from one ECU to another with the STAR system. Ultimately it is just setting an clearing bits in the EEPROM, which can easily be copied. RE: Common rail diesel discussion thread - firen456 - 01-30-2019 There's no 613/648 manual car. Copying the eeprom is clear to me. But u will still need the matching key and eis for it. RE: Common rail diesel discussion thread - barrote - 01-30-2019 I guess baldur is doing this just cause of that... To run without CAN permissions , otherwise what sense does it make. I belive TCU's , IMMO, etc, will be available as add on later if user wishes, if not please Baldur do it to run engine on minimal hardware... RE: Common rail diesel discussion thread - baldur - 01-30-2019 (01-30-2019, 05:17 AM)barrote I guess baldur is doing this just cause of that... Yes that's the plan. I will also have a complete wiring harness available for engine swaps if I manage to source all of the connectors. RE: Common rail diesel discussion thread - starynovy - 02-02-2019 Very interesting. I keep fingers crossed for you man. Dont forget to make it for piezos since they flow heaps lot more than magnets. ![]() RE: Common rail diesel discussion thread - Turbo - 02-03-2019 (02-02-2019, 02:05 PM)starynovy Very interesting. I keep fingers crossed for you man. Dont forget to make it for piezos since they flow heaps lot more than magnets. There are quite big solenoid injectors too, I have new ones that give about 50% more then BMW550ds pizo injectors, orginal bosch, and they are resonantly fast at 8 event/ cykle according to bosch , now BMW can make 10 so a little bit slower there Just Waiting for Baldur to start this up ![]() RE: Common rail diesel discussion thread - baldur - 02-03-2019 I am making progress. First start up happened tonight. https://www.facebook.com/stalsmidjan.knarri.7/videos/140812056936849/ Timing is very late in that video so it smoked a lot and ran rough, and when I squeezed the accelerator pedal the smoke just changed colour instead of accelerating the engine, but I am satisfied with that result for the first start, it can only get better once I tune the timing and fuelling. I do of course plan to make another version to drive piezo injectors once I have the controller for solenoid injectors in production. ![]() RE: Common rail diesel discussion thread - Motohead1 - 02-03-2019 Very cool. Caint wait to see the final product. RE: Common rail diesel discussion thread - starynovy - 02-04-2019 Ou yeah it lives! Best thing from this would be lighting fast throttle response. I hated 320CDI for that slugish sleepy gas pedal. RE: Common rail diesel discussion thread - baldur - 02-04-2019 (02-04-2019, 12:30 PM)starynovy Ou yeah it lives! Best thing from this would be lighting fast throttle response. I hated 320CDI for that slugish sleepy gas pedal. How is this for throttle response? ![]() https://www.facebook.com/stalsmidjan.knarri.7/videos/141076760243712/ I agree, I like quick response. That's my biggest complaint with modern cars, throttle response is non-existent, and the manufacturer made it that way intentionally. RE: Common rail diesel discussion thread - engineengineer - 02-06-2019 (02-04-2019, 04:30 PM)baldurBaldur, will this be usable on other engines? Particularly the Mitsubishi Fuso.(02-04-2019, 12:30 PM)starynovy Ou yeah it lives! Best thing from this would be lighting fast throttle response. I hated 320CDI for that slugish sleepy gas pedal. RE: Common rail diesel discussion thread - atypicalguy - 02-06-2019 (01-13-2019, 01:50 PM)baldur It has been requested that I open a thread to discuss and share information about common rail diesel injection. This sounds super. I think the blacksmoke guys are on a standalone ECU now also. No idea but their tuner seems to post on here from time to time. It seems like this is the new black art :-) Perhaps one could retrofit a high pressure pump and piezo injectors to all those smoky 606 motors out there... RE: Common rail diesel discussion thread - baldur - 02-06-2019 (02-06-2019, 01:25 AM)engineengineer(02-04-2019, 04:30 PM)baldurBaldur, will this be usable on other engines? Particularly the Mitsubishi Fuso.(02-04-2019, 12:30 PM)starynovy Ou yeah it lives! Best thing from this would be lighting fast throttle response. I hated 320CDI for that slugish sleepy gas pedal. With this controller I plan to support nearly any engine that uses solenoid controlled high current injectors. Common rail, unit injectors (pumpe duse) and spill valve controlled injection pumps. RE: Common rail diesel discussion thread - baldur - 02-06-2019 (02-06-2019, 04:16 AM)atypicalguy(01-13-2019, 01:50 PM)baldur It has been requested that I open a thread to discuss and share information about common rail diesel injection. They may have, but I don't think they are. I think they are still using the EDC16 on the OM648, but they had struggles getting it to work properly although they got there eventually. Tuning OEM ECUs is a black art. I hope to make common rail diesel tuning less of a black art by making a controller that is a lot easier to tune. My current version is not for piezo injectors but solenoid injectors, I plan to make a variant of the same controller for piezo injectors later, they require a very different power supply as piezo injectors are voltage controlled but solenoid injectors are current controlled. I remember the finns built a direct injection OM606 some years ago, but I think this is a lot of trouble when there are so many good common rail engines becoming available. RE: Common rail diesel discussion thread - Sotvisp - 02-07-2019 i think this is amazing work !! I have been planning to do a transplant with BMW edc15 from tu30 to a om613 because its much easier to program the ecu as standalone and they are quite similar in many ways. Very interesting to follow the progress here , what will such product cost when its up and running ?? Keep on Rocking.... RE: Common rail diesel discussion thread - Sotvisp - 02-07-2019 (02-06-2019, 04:52 AM)baldur(02-06-2019, 04:16 AM)atypicalguy(01-13-2019, 01:50 PM)baldur It has been requested that I open a thread to discuss and share information about common rail diesel injection. Blacksmoke engine seems to have Nira now days https://youtu.be/tYE-QcvCjCM RE: Common rail diesel discussion thread - baldur - 02-07-2019 (02-07-2019, 07:39 AM)Sotvisp i think this is amazing work !! Thank you. I do not know what the cost will be until I finish the final design and get it manufactured. I want to make it affordable so it will be an attractive option for engine swaps and not just for the most hardcore tuning applications. I also want to make casual tuning of common rail diesels accessible. It is notoriously difficult to get good results with the Bosch ECUs which are not designed to be tuned by the end user. A simple to use solution that isn't 4000 euros is going to enable a lot more people to start tuning their common rail engines, and not constrained by what the factory ECU can do. Baldur RE: Common rail diesel discussion thread - baldur - 02-16-2019 The prototype has been installed in a car. Here is an OM613 swapped Nissan Patrol. Tuning is not done yet but the engine runs and sounds very smooth and power is definitely better than the ZD30 engine it replaced. https://www.facebook.com/stalsmidjan.knarri.7/videos/pcb.144350383249683/144350339916354/?type=3&theater Using the stock auto transmission, accelerator pedal, instrument cluster and idle up switch. Everything works as if the car was stock, except it's got a better engine. None of that is easily done using a Mercedes ECU on a swap like this. RE: Common rail diesel discussion thread - Motohead1 - 03-23-2019 Any new updates? RE: Common rail diesel discussion thread - baldur - 03-24-2019 I am just working to finish the design. It's getting there, but other projects are getting in the way. RE: Common rail diesel discussion thread - Motohead1 - 03-24-2019 Hey I understand that. Thanks for the update! RE: Common rail diesel discussion thread - madmog - 03-25-2019 When the OM613 is ready & available, will also do OM611 and OM612 Baldur? RE: Common rail diesel discussion thread - baldur - 03-26-2019 (03-25-2019, 01:18 PM)madmog When the OM613 is ready & available, will also do OM611 and OM612 Baldur? Yes, as the OM611 and OM612 use the same ECU board as the OM613 it will be a plug and play fit for those as well. It will be able to handle any engine that has solenoid injectors, up to 8 cylinders, so OM646-OM648 and OM628 will also work but they will need a change of connector on their wiring harness. Same for earlier BMW M57 engines, Cummins, Toyota and even Volkswagen PD engines will work. Once this platform is in production I plan to create another version for piezoelectric injectors which will cover all of the newest engines like OM642. RE: Common rail diesel discussion thread - madmog - 03-26-2019 Awesome, thanks Baldur RE: Common rail diesel discussion thread - Langstrom - 04-17-2019 This looks awesome baldur! What's the current status of this project? Langstrom RE: Common rail diesel discussion thread - baldur - 04-17-2019 (04-17-2019, 08:49 AM)Langstrom This looks awesome baldur! What's the current status of this project? I have been so busy with other projects that progress on getting the production design done is slow, but I'm getting there. Schematic has been finalised but board layout is left. RE: Common rail diesel discussion thread - starynovy - 04-20-2019 Ou yea thats my kind of response. ![]() RE: Common rail diesel discussion thread - madmog - 05-11-2019 Baldur, I'm curious, are you planning on having any out-of-ordinary-readings cause a limp mode event? Or, if not limp mode, will out-of-ordinary-readings toy your ECU create an OBD type message, light a warning light or whatever? Or is it simply a case of when something isn't running correctly, a failed MAF sensor or whatever, it's tracked down in the old fashioned way? Thanks RE: Common rail diesel discussion thread - baldur - 05-12-2019 (05-11-2019, 06:35 AM)madmog Baldur, I'm curious, are you planning on having any out-of-ordinary-readings cause a limp mode event? Or, if not limp mode, will out-of-ordinary-readings toy your ECU create an OBD type message, light a warning light or whatever? Yes there will be a comprehensive set of self diagnostics on there including OBD messages. RE: Common rail diesel discussion thread - madmog - 05-13-2019 (03-26-2019, 05:36 AM)baldur(03-25-2019, 01:18 PM)madmog When the OM613 is ready & available, will also do OM611 and OM612 Baldur? (05-12-2019, 06:03 PM)baldurAwesome!!(05-11-2019, 06:35 AM)madmog Baldur, I'm curious, are you planning on having any out-of-ordinary-readings cause a limp mode event? Or, if not limp mode, will out-of-ordinary-readings toy your ECU create an OBD type message, light a warning light or whatever? RE: Common rail diesel discussion thread - SurfRodder - 07-29-2019 This is awesome. I'm really looking forward to getting one of these! RE: Common rail diesel discussion thread - atypicalguy - 07-29-2019 (05-12-2019, 06:03 PM)baldur(05-11-2019, 06:35 AM)madmog Baldur, I'm curious, are you planning on having any out-of-ordinary-readings cause a limp mode event? Or, if not limp mode, will out-of-ordinary-readings toy your ECU create an OBD type message, light a warning light or whatever? You could easily fund development of this using kickstarter or Patreon or some such mechanism. I think there are several to choose from now. RE: Common rail diesel discussion thread - baldur - 07-30-2019 (07-29-2019, 11:04 PM)atypicalguy(05-12-2019, 06:03 PM)baldur(05-11-2019, 06:35 AM)madmog Baldur, I'm curious, are you planning on having any out-of-ordinary-readings cause a limp mode event? Or, if not limp mode, will out-of-ordinary-readings toy your ECU create an OBD type message, light a warning light or whatever? It's not a problem. I have everything needed to develop it, only thing that is in short supply is time and much of my time is being eaten up by billed projects. If I apply the billed rate to the development hours on this project it's over $100k by now. That being said, I am making progress. I am maybe 3/4 of the way through the design work on the production circuit board. I hope to get a prototype built of the production board in a few weeks time and then if I don't find any errors in that design I will pull the trigger on doing a manufacturing run. There are 4 cars driving on the initial prototype design and it works well although the firmware needs more development. RE: Common rail diesel discussion thread - SurfRodder - 08-13-2019 (05-12-2019, 06:03 PM)baldur Yes there will be a comprehensive set of self diagnostics on there including OBD messages. I know this is a whole other can of worms, but have you considered trying to tie in any emissions systems? Some Bosch Denoxtronic pumps and spray controllers talk to ECU via CAN and somehow modify spray of NH3 in exhaust stream due to engine load, etc. I've been looking into trying to retrofit a modified denox standalone system (or 2) from a Sprinter to try to modify exhaust gases. Obviously, getting the main system ready for manufacture is first priority, just curious as to whether or not you've considered emissions control as a long term goal. RE: Common rail diesel discussion thread - baldur - 08-14-2019 I currently have no plans for emission controls. I plan to address everything else and then maybe I will look at emission controls. RE: Common rail diesel discussion thread - atypicalguy - 08-28-2019 (07-30-2019, 02:08 PM)baldur(07-29-2019, 11:04 PM)atypicalguy(05-12-2019, 06:03 PM)baldur Yes there will be a comprehensive set of self diagnostics on there including OBD messages. Cool. Keep us posted. RE: Common rail diesel discussion thread - SurfRodder - 09-04-2019 (08-28-2019, 08:08 PM)atypicalguy Cool. Keep us posted. Agreed...super stoked about this! RE: Common rail diesel discussion thread - baldur - 10-15-2019 I got manufacturing of my controller started today, expecting to receive boards and enclosures around a month from now. RE: Common rail diesel discussion thread - atypicalguy - 10-24-2019 (10-15-2019, 08:01 PM)baldur I got manufacturing of my controller started today, expecting to receive boards and enclosures around a month from now. If I have a stock 648 and want to put a larger turbo on it, would I be able to use your ecu and manage the tuning myself, or would I need to work with you long distance or take it to a tuning shop? How do you see this playing out for the end user? Thanks. RE: Common rail diesel discussion thread - baldur - 10-24-2019 (10-24-2019, 07:03 PM)atypicalguy(10-15-2019, 08:01 PM)baldur I got manufacturing of my controller started today, expecting to receive boards and enclosures around a month from now. The end game is to make tuning as easy as possible with no extra hardware required other than a laptop PC. Much like my current systems, I will have reasonable base maps available for the engines I have worked with and I am able to provide assistance with making changes to those maps but the user can also make changes themselves. RE: Common rail diesel discussion thread - orion - 10-31-2019 Hello Baldur, nice to see the progress in this project. You explain that it's possible to control a OM628. Can you confirm this message? RE: Common rail diesel discussion thread - baldur - 10-31-2019 Hello. Yes the OM628 uses solenoid injectors similar to those found on the OM613 so that engine can be controlled with this unit. I have not yet reverse engineered the electronic actuators on the stock OM628 turbochargers but as far as the engine itself that is a piece of cake. RE: Common rail diesel discussion thread - orion - 11-01-2019 Very interesting. I think the actuaters works with a PWM. But thats not the problem, its possible to swap to K03S chargers with pressure actuators and work with a valve, maybe from VW RE: Common rail diesel discussion thread - SurfRodder - 11-03-2019 (10-15-2019, 08:01 PM)baldur I got manufacturing of my controller started today, expecting to receive boards and enclosures around a month from now. Awesome!. Best news I've heard all week! RE: Common rail diesel discussion thread - baldur - 11-22-2019 I am happy to announce that after over a year of development work and several prototypes built with a decent amount of fault free running time on them I am finally ready to receive orders for the DID1 direct injection diesel controller. This is capable of operating common rail diesel engines with solenoid injectors, up to 8 cylinders. https://controls.is/shop/DID1 |
