OM606 to GS6X-53DZ in a Land Rover - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Drivetrain (https://www.superturbodiesel.com/std/forumdisplay.php?fid=9) +--- Thread: OM606 to GS6X-53DZ in a Land Rover (/showthread.php?tid=8234) |
OM606 to GS6X-53DZ in a Land Rover - 606110 - 05-14-2019 Hi guys looking for some advice on the better gearbox mounting solution. I have a Dieselpumpuk kit with a 19kg flywheel which I was planning on using but have also considered the welded bellhousing route with a much lighter sprinter flywheel. Being on a heavy 4wd heavier flywheel will be more advantageous right? Has anyone on here used the DPUK kit? There's not a lot of info out there. All the best 606110 |
