W126 OM606 Engine Tach - Printable Version
+--- Thread: W126 OM606 Engine Tach (/showthread.php?tid=8252)
W126 OM606 Engine Tach - wiseman89 - 07-17-2019
Hi guys,
So im currently working on wiring up my transmission controller and installing my diesel shut off valve on the tumbler.
Im trying to figure out how to get the rpm gauge to work on the 1991 560 sel.
does anyone have any suggestions ?
RE: W126 OM606 Engine Tach - WSchotty - 07-18-2019
(07-17-2019, 01:01 PM)wiseman89 Hi guys,
Check this out, starting point for ideas:
http://www.superturbodiesel.com/std/showthread.php?tid=7571
Schematic for diesel version in here:
https://www.benzworld.org/forums/w126-s-se-sec-sel-sd/1635793-91-350sdl-tach-dead-but-no.html
RE: W126 OM606 Engine Tach - wiseman89 - 07-18-2019
Thanks WSchotty, I think I still have to reply to the DM you send me !
I Did pick up a dakota digital diesel tach interface.
I can get a signal from either the W on the alternator or the sensor on the flywheel. Im just not sure where to hook that up.
