om603.912 hx40 - Printable Version
+--- Thread: om603.912 hx40 (/showthread.php?tid=8253)
om603.912 hx40 - jarow123 - 07-21-2019
Hello
Im from Slovakia so i apologise if the spelling or some words might be wrong. I have build a om603.912 superturbo. 8mm dieselmeken pump with outside alda, holset hx40. what is the safe boost a om603NA ? actually i run 1,65 bar without any problems. The engine could handle a pressure of 2 bars ? ?.
Thanks
RE: om603.912 hx40 - NZScott - 07-22-2019
I'm sure you'd tell us if it wasn't Smile
With an HX40 your bottom end is probably ok as it won't ever get high boost at low RPM
