W123 4spd swap driveshaft question - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Drivetrain (https://www.superturbodiesel.com/std/forumdisplay.php?fid=9) +--- Thread: W123 4spd swap driveshaft question (/showthread.php?tid=8254) |
W123 4spd swap driveshaft question - Dinman - 08-06-2019 As title states: As countless people have done/talked about doing, i'm putting an aluminum 4spd (83 240d) into my 1983 300D (us spec) Bought the entire car for the swap. Wrecked in the front. Here's my question- regarding the driveshaft. From my understanding, ~19.5" is the length you want out of the front shaft in order to swap the 4spd into an om617 equipped w123. & a 240d 4spd shaft is 24". So lop ~4" off and balance? Or- i found this shaft pictured. Coming from trans back, colors are Green/Green/Red/Green. Seller claims "Mounting flange to end of coupling nut is 21" It came from a 1982ish 300CD coupe, that had an iron box 4spd swap. Shouldn't this shaft bolt right into my w123 300D sedan with the aluminum 4spd swapped in? Thanks! PHOTO_20190806_152448 by Daniel Inman, on Flickr RE: W123 4spd swap driveshaft question - NZScott - 08-08-2019 Remember coupes have a shorter body...I'd think they'd make the front shaft shorter rather than have a different rear one. Don't know if the 4 speed Getrag boxes are the same length as the iron ones. I can't tell you much else sorry... RE: W123 4spd swap driveshaft question - Dinman - 08-19-2019 (08-08-2019, 01:31 AM)NZScott Remember coupes have a shorter body...I'd think they'd make the front shaft shorter rather than have a different rear one. Don't know if the 4 speed Getrag boxes are the same length as the iron ones. I can't tell you much else sorry... No worries, thanks for the reply. If anyone knows, im all ears. Trying to piece together everything for the swap |
