OM651 set-up - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Engine (https://www.superturbodiesel.com/std/forumdisplay.php?fid=7) +--- Thread: OM651 set-up (/showthread.php?tid=8255) |
OM651 set-up - madmog - 08-08-2019 Does the OM651 have the same basic shape as the OM646 and OM611 engines and is it mounted slanted as per OM611? I'm thinking of picking up a W204 C220 or C250CDi as my daily driver for a few years then having the option to use as a donor car down the line. I've looked in engine bays but the plastic cover makes it difficult to see what's going on. Ta RE: OM651 set-up - barrote - 08-08-2019 651 is totally diff engine from 611 breed. I'm not expert in them, but i can say they're nothing alike... But also haven't heard much about it , neither good or bad... RE: OM651 set-up - Sotvisp - 08-09-2019 Here are an swap in W201 Om651 https://www.motor1.com/news/17321/mercedes-benz-190-d-blueefficiency-1992-mercedes-190-e-26-sportline-retrofitted/ Br RE: OM651 set-up - madmog - 08-09-2019 Thanks |
