OM 606 oil filter relocation plates - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Engine (https://www.superturbodiesel.com/std/forumdisplay.php?fid=7) +--- Thread: OM 606 oil filter relocation plates (/showthread.php?tid=8270) |
OM 606 oil filter relocation plates - zeeman - 09-08-2019 Who is making oil filter housing relocation plates for the OM 606 to retain the stock filter housing with the thermo check valve ? RE: OM 606 oil filter relocation plates - SurfRodder - 09-21-2019 I made my own from a gasket and 3/4" alum plate. A bolt in option would be grabbing an spin on filter housing from an m103 engine and getting a spin on adapter or relocation bracket for remote mount spin on filter if you wanted to get rid of the messy oil tower. RE: OM 606 oil filter relocation plates - SurfRodder - 09-30-2019 (09-21-2019, 11:16 AM)SurfRodder I made my own from a gasket and 3/4" alum plate. A bolt in option would be grabbing an spin on filter housing from an m103 engine and getting a spin on adapter or relocation bracket for remote mount spin on filter if you wanted to get rid of the messy oil tower.Actually, I am moving the oil cooler from my w123 onto my w124 during my om606 install (hopefully this weekend) I already have the factory spin on adapter from an m103 so Im going to get 2 of these: https://www.amazon.com/10AN-Flare-Adapter-Fitting-F10AN100R/dp/B079TXLM5W/ref=sr_1_1?keywords=10an+oring&qid=1569905280&s=gateway&sr=8-1 to connect this to the AN oil cooler lines I already have: https://www.amazon.com/Derale-35703-Premium-Engine-Adapters/dp/B004XOQKV2/ref=sr_1_1?keywords=35703+derale&qid=1569905249&s=gateway&sr=8-1 |
