OM606 and G Wagon power steering box - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Engine (https://www.superturbodiesel.com/std/forumdisplay.php?fid=7) +--- Thread: OM606 and G Wagon power steering box (/showthread.php?tid=8323) |
OM606 and G Wagon power steering box - Nick S - 03-11-2020 I'm currently putting a 606 into a Volvo 6x6 and will be using a G wagon steering box. My question is the power steering box ok with the pressure output from the 606 power steering pump or will I need to adjust the pressure output? Thanks Nick RE: OM606 and G Wagon power steering box - zeeman - 03-11-2020 (03-11-2020, 07:20 AM)Nick S I'm currently putting a 606 into a Volvo 6x6 and will be using a G wagon steering box. My question is the power steering box ok with the pressure output from the 606 power steering pump or will I need to adjust the pressure output? You should be fine, I use the Mercedes pump with all the Jeep steering boxes no problem. You might talk to Luke at Dieselpumpuk.com he does a lot of OM 606 conversions in the G wagons and should be able to also answer that question. RE: OM606 and G Wagon power steering box - Nick S - 03-14-2020 Thanks Zeeman! Cheers Nick |
