My OM606 search criteria for Row52 - Printable Version
+--- Thread: My OM606 search criteria for Row52 (/showthread.php?tid=8395)
My OM606 search criteria for Row52 - SurfRodder - 08-12-2020
I set this up a while back, but keep forgetting to post here for others to use:
https://row52.com/Search/?DisplaySavedSearch=1&YMMorVin=VIN&Year=&V1=W&V2=D&V3=B&V4=J&V5=&V6=2&V7=&V8=&V9=&V10=&V11=&V12=&V13=&V14=&V15=&V16=&V17=&ZipCode=&Page=1&ModelId=&MakeId=&LocationId=&IsVin=true&Distance=50&SearchId=1230706
Search is set up for 98-99 E300 with diesel vin code, nationwide.  You can set up an account and specific radius from your ZIP and get email or text updates.
Recent posts include one car in K.C. and another in Cinci.
Most of these are outta my range...hopefully some of yous gize here in the U.S. can grab a needed 606 / parts from a donor.
RE: My OM606 search criteria for Row52 - SurfRodder - 10-14-2020
Apparently ithas for all w210 diesels. I just got notice of a 96 the other day. I thought I had it setup for a specific year range, but that might not apply when using VIN criteria. If you only want turbo versions, 2 identical searches with different year codes in vin would get it done. It *should* also work if you hit y/m/m tab and input 98-99 for year, then switch back to vin tab and hit search.
