Mercedes 605.910 - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Engine (https://www.superturbodiesel.com/std/forumdisplay.php?fid=7) +--- Thread: Mercedes 605.910 (/showthread.php?tid=8480) |
Mercedes 605.910 - benzguy - 12-05-2021 i would like to know if a injection pump from a 602.910 n/a will fit and work in a 605.910 ? RE: Mercedes 605.910 - barrote - 12-06-2021 Yes it will, Nevertheless some parts inside are diff. Fueling for instance... May i ask why such change? Regards RE: Mercedes 605.910 - benzguy - 12-07-2021 I’m buying a 605.910 to be swap for the 601 in my 85 190D in America we never got the 605 and to make the 605 work in the 190 I need the mechanical pump I just like to find out if it’s going to have the same power or maybe less RE: Mercedes 605.910 - barrote - 12-07-2021 Hum hum ... U havd to buy a 605.96X Then a min 6 mil pump got to be prepared, from that one u have so u can hit 150hp or a litle more. If u wich PM me i help u through the process. Regards RE: Mercedes 605.910 - benzguy - 12-07-2021 The 605.96x it’s harder to find and not every one is willing to ship it to America so I already bought the 605.910 from Spain I know it’s going to be a better engine then the 601 and I converting to manual transmission 5 speed I still looking for the flywheel RE: Mercedes 605.910 - Petar - 12-08-2021 It will work and run fine, but without adjustment it will only make 602 power (~95hp) You can adjust the full load screw to get the extra 20hp or so. RE: Mercedes 605.910 - barrote - 12-08-2021 Well, as Petar said... no turbo no fun, no fuel no pnys... BTW buying a 605.911 in spain is quite a bad idea, when u could had had one 605.96X from UK at half price. Next time ask around i'm sure many will be glad send u an engine... Wish u luck with the build. RE: Mercedes 605.910 - benzguy - 12-09-2021 (12-08-2021, 04:04 PM)barrote Well, as Petar said... no turbo no fun, no fuel no pnys... Well I’m asking now because they canceled my order they gave me a good deal 575€ for the engine and 675€ for shipping I think they made a mistake. I’m looking now for the 605.96X I’ll appreciate the help RE: Mercedes 605.910 - barrote - 12-09-2021 No they did not. Its just besides there are also few of those engines around nobody wants them. Its not its a bad engine, its just isn't as though as a .96X therefore does not hold abuse very well. Just rodwise. Pistowise too. Head assy is also slightly diff. For a STD need some upgrade... In UK is the place to look. Regards. RE: Mercedes 605.910 - benzguy - 12-09-2021 Thanks a lot for your help Francisco. And Petar thanks for the tip if I ever get my hands on a 605.910 I’ll do that |
