STD Other Projects S202 OM605 build .
S202 OM605 build .
S202 OM605 build .
Niko
02-27-2023, 07:36 AM #3
So,
slight progress to report .
An OM605 turbo was bought on the cheap and is now proudly weighing on a cart in my garage . Came up with a super simple exhaust manifold which I'll show a bit later .
Also a simple design of an intake is on the way .
Still no car to put it in, though I'm working on that as well .
It's gonna be a 124 estate .
So some questions :
Will a 53dz gearbox fit in a 124 tunel behind a 605 ?
The shifter will need modifications, that's clear but I'd rather not drill/cut.beat up the original tunnel .
Anybody have experience with a s200sxe with a 0.82 AR ? When can I expect boost ?
And will the stock 411 box hold about 200hp ?
Edit :
Some pictures of the intake and exhaust
It's a two piece construction  . The bottom pieces are 20 mm thick and use a gasket from a 606 . the seal to the top piece uses O rings . And the top piece is attached with three studs to the bottom pieces .
The exhaust is just flat stock laser cut to fit and the space in between is made from 33.7 90 degree beds just cut up and welded together .
This post was last modified: 03-05-2023, 10:44 AM by Niko.
Niko
So,
So some questions :
Edit :
Messages In This Thread
S202 OM605 build . - by Niko - 02-05-2023, 01:11 AM
RE: Not a project yet . - by Niko - 02-19-2023, 02:44 AM
RE: Not a project yet . - by Niko - 02-27-2023, 07:36 AM
RE: Not a project yet . - by Niko - 03-11-2023, 03:03 PM
RE: Not a project yet . - by Tobulus - 03-12-2023, 10:41 AM
RE: Not a project yet . - by Niko - 03-13-2023, 12:38 PM
RE: S202 OM605 build . - by Niko - 03-16-2023, 10:38 AM
RE: S202 OM605 build . - by Niko - 03-31-2023, 06:25 AM
RE: S202 OM605 build . - by Niko - 04-02-2023, 11:19 AM
RE: S202 OM605 build . - by junkyarddawg - 04-14-2023, 06:17 AM
RE: S202 OM605 build . - by Niko - 04-17-2023, 10:15 AM
RE: S202 OM605 build . - by TE27Levin - 04-22-2023, 02:25 PM
RE: S202 OM605 build . - by Niko - 04-24-2023, 05:23 AM
RE: S202 OM605 build . - by Niko - 05-15-2023, 02:28 PM
RE: S202 OM605 build . - by Niko - 05-26-2023, 12:03 PM
RE: S202 OM605 build . - by Niko - 06-12-2023, 02:25 AM
RE: S202 OM605 build . - by Niko - 06-21-2023, 01:30 AM
RE: S202 OM605 build . - by Niko - 06-25-2023, 02:34 PM
RE: S202 OM605 build . - by Niko - 07-03-2023, 05:16 AM
RE: S202 OM605 build . - by Niko - 08-30-2023, 08:38 AM
RE: S202 OM605 build . - by Niko - 09-03-2023, 08:13 AM
RE: S202 OM605 build . - by Niko - 09-11-2023, 09:29 AM
RE: S202 OM605 build . - by Niko - 09-27-2023, 02:14 PM
RE: S202 OM605 build . - by Niko - 10-08-2023, 09:52 AM
RE: S202 OM605 build . - by Niko - 10-22-2023, 02:29 AM
RE: S202 OM605 build . - by Niko - 11-11-2023, 03:44 PM
RE: S202 OM605 build . - by Niko - 11-20-2023, 02:43 PM
RE: S202 OM605 build . - by Deltaevo - 01-14-2024, 01:16 PM
RE: S202 OM605 build . - by Niko - 01-15-2024, 02:18 AM
RE: S202 OM605 build . - by Niko - 02-05-2024, 01:08 PM
RE: S202 OM605 build . - by Niko - 03-17-2024, 03:00 AM
RE: S202 OM605 build . - by Deltaevo - 06-03-2024, 02:33 PM
RE: S202 OM605 build . - by Niko - 05-23-2024, 02:48 AM
RE: S202 OM605 build . - by Niko - 06-05-2024, 02:43 AM
