STD Other Projects S202 OM605 build .
S202 OM605 build .
S202 OM605 build .
Niko
06-21-2023, 01:30 AM #17
Sort of an update .
The clutch pressure plate arrived . It's an e34 M5 (PN: 3082 147 033) unit and those springs are tough .
So with the NSG-370 gearbox the flywheel ends up 30 mm thick, which means 1045 will be used to make that .
Face of the flywheel ends up being flat, which is easy enough, and the entire thickness of the friction disk is inside the pressure plate .
Things end up fitting nicely tho .
I'm planning on using a friction disk with organic material on the pressure plate side and ceramic on the flywheel side .
Should have enough bite .
Niko
Sort of an update .
Messages In This Thread
S202 OM605 build . - by Niko - 02-05-2023, 01:11 AM
RE: Not a project yet . - by Niko - 02-19-2023, 02:44 AM
RE: Not a project yet . - by Niko - 02-27-2023, 07:36 AM
RE: Not a project yet . - by Niko - 03-11-2023, 03:03 PM
RE: Not a project yet . - by Tobulus - 03-12-2023, 10:41 AM
RE: Not a project yet . - by Niko - 03-13-2023, 12:38 PM
RE: S202 OM605 build . - by Niko - 03-16-2023, 10:38 AM
RE: S202 OM605 build . - by Niko - 03-31-2023, 06:25 AM
RE: S202 OM605 build . - by Niko - 04-02-2023, 11:19 AM
RE: S202 OM605 build . - by junkyarddawg - 04-14-2023, 06:17 AM
RE: S202 OM605 build . - by Niko - 04-17-2023, 10:15 AM
RE: S202 OM605 build . - by TE27Levin - 04-22-2023, 02:25 PM
RE: S202 OM605 build . - by Niko - 04-24-2023, 05:23 AM
RE: S202 OM605 build . - by Niko - 05-15-2023, 02:28 PM
RE: S202 OM605 build . - by Niko - 05-26-2023, 12:03 PM
RE: S202 OM605 build . - by Niko - 06-12-2023, 02:25 AM
RE: S202 OM605 build . - by Niko - 06-21-2023, 01:30 AM
RE: S202 OM605 build . - by Niko - 06-25-2023, 02:34 PM
RE: S202 OM605 build . - by Niko - 07-03-2023, 05:16 AM
RE: S202 OM605 build . - by Niko - 08-30-2023, 08:38 AM
RE: S202 OM605 build . - by Niko - 09-03-2023, 08:13 AM
RE: S202 OM605 build . - by Niko - 09-11-2023, 09:29 AM
RE: S202 OM605 build . - by Niko - 09-27-2023, 02:14 PM
RE: S202 OM605 build . - by Niko - 10-08-2023, 09:52 AM
RE: S202 OM605 build . - by Niko - 10-22-2023, 02:29 AM
RE: S202 OM605 build . - by Niko - 11-11-2023, 03:44 PM
RE: S202 OM605 build . - by Niko - 11-20-2023, 02:43 PM
RE: S202 OM605 build . - by Deltaevo - 01-14-2024, 01:16 PM
RE: S202 OM605 build . - by Niko - 01-15-2024, 02:18 AM
RE: S202 OM605 build . - by Niko - 02-05-2024, 01:08 PM
RE: S202 OM605 build . - by Niko - 03-17-2024, 03:00 AM
RE: S202 OM605 build . - by Deltaevo - 06-03-2024, 02:33 PM
RE: S202 OM605 build . - by Niko - 05-23-2024, 02:48 AM
RE: S202 OM605 build . - by Niko - 06-05-2024, 02:43 AM
