STD Other Projects Toyota pickup OM617 swap
Pages (2): Previous 1 2
4rnnr33
04-14-2011, 05:39 PM #51
well ive been gathering parts to do my remote oil filter setup and got this turbo oil line to -4 AN hose adapter off ebay and noticed the oil hole is very small on one side the website says its to prevent to much oil pressure going straight to the turbo but it seems to small to me. What do you guys think should i drill it out a little more or leave it?
[Image: IMAG0108.jpg]
[Image: IMAG0109.jpg]
4rnnr33
4rnnr33
04-18-2011, 06:27 PM #52
Any suggestions?
4rnnr33
Any suggestions?
300D50
Graphite Moderator, ala RBMK
04-18-2011, 06:37 PM #53
I'd match it to what the old flange had, safe way to go.
300D50
4rnnr33
04-18-2011, 06:49 PM #54
(04-18-2011, 06:37 PM)300D50 I'd match it to what the old flange had, safe way to go.
thats what I was thinking but i wasnt sure if there was any restrictions on the other end of the line where it comes off the filter housing
4rnnr33
300D50
04-18-2011, 07:25 PM #55
I don't think there is, iirc the line is the only restriction.
300D50
4rnnr33
04-19-2011, 06:18 PM #56
well i finally got around to removing the in tank pump and that was definately the problem. Its now way more smoother at higher rpms.
Just added a piece of hardline in place of the pump
[Image: IMAG0110.jpg]
While I had the tank dropped I also modified the filler neck so I could fit a diesel nozzle in it
Just took a large punch and knocked out the restrictor
[Image: IMAG0112.jpg]
Then welded back up the holes from the plug welds ripping out and voila!
[Image: IMAG0113.jpg]
This post was last modified: 04-19-2011, 06:19 PM by 4rnnr33.
4rnnr33
4rnnr33
04-23-2011, 02:48 PM #57
ok so ive been having a couple different issues now that ive been driving the truck everyday. The first is that I need to put a filter on the pickup in the tank because I will be driving then all of a sudden lose basically all power due to the fuel line getting plugged so i just pull the line off at the pre filter and blow in it with the air nozzle and that solves that.
Second problem im not 100% sure about. The last couple times I have gone to start the truck i have to hold the throttle to the floor to keep it running (barely) and it has quite a bit of blue smoke until it warms up then the smoke clears and it runs smooth. Im thinking this may be valve stem seals? Does anyone have any other ideas?
This post was last modified: 04-23-2011, 02:48 PM by 4rnnr33.
4rnnr33
stan
04-23-2011, 09:52 PM #58
(04-23-2011, 02:48 PM)4rnnr33 The last couple times I have gone to start the truck i have to hold the throttle to the floor to keep it running (barely) and it has quite a bit of blue smoke until it warms up then the smoke clears and it runs smooth. Im thinking this may be valve stem seals? Does anyone have any other ideas?
maybe obvious but have you made sure your whole glowplug system is working properly?
have you made sure the valves are adjusted to spec?
have you done a compression test?
stan
4rnnr33
04-24-2011, 03:12 PM #59
yes glowplug system works, valves are adjusted but i havent ran a compression test. I am also kind of thinking maybe this has to do with my turbo being worn out. I pulled off my intake hose and felt the propeller and noticed it has quite a bit of slop, enough to where it looks like it is hitting the compressor housing which i can also hear at certain rpms. I have heard of worn out turbos spraying out oil into the exhaust so maybe this has something to do with the smoke.. looks like its time to start searching for another turbo
This post was last modified: 04-24-2011, 03:12 PM by 4rnnr33.
4rnnr33
04-24-2011, 04:44 PM #60
Want mine? I am trying my best to unload all this scrap. Though mine has quite a bit of play too and WA is a long way to ship it.
4rnnr33
04-24-2011, 06:29 PM #61
(04-24-2011, 04:44 PM)larsalan Want mine? I am trying my best to unload all this scrap. Though mine has quite a bit of play too and WA is a long way to ship it.
Ya sure any idea what it would cost to ship?
4rnnr33
04-24-2011, 06:33 PM #62
No, I will look into it. How much do you think it weights? It's still on the motor. We have been underwater for the last few days and they say there are a few more days till it drys out. I have some other work to do too but, I'll put your name on it.
The turbo housing is tapped for a water injection nozzle so, it would need a plug. 1/8 npt
4rnnr33
04-24-2011, 08:46 PM #63
(04-24-2011, 06:33 PM)larsalan No, I will look into it. How much do you think it weights? It's still on the motor. We have been underwater for the last few days and they say there are a few more days till it drys out. I have some other work to do too but, I'll put your name on it.
Awesome I was actually thinking about and i think it should fit in a large flat rate box maybe. That wouldnt be too bad. And no hurry.
4rnnr33
4rnnr33
05-02-2011, 09:24 PM #64
Well ive finally started putting together my remote oil filter setup. Heres a couple pics
Turbo feed line braided stainless hose with the ebay adapter
[Image: IMAG0118.jpg]
And the adapter that I got from 300D50 which is very nice!
[Image: IMAG0121.jpg]
Thats all for know I should have the rest pretty much buttoned up tomorrow
4rnnr33
4rnnr33
05-03-2011, 10:02 PM #65
Got it pretty much buttoned up today just have to get a couple more fittings and bolts
the pics are kinda crappy but its kinda tight so its hard to get a good angle but heres what i got
[Image: IMAG0124.jpg]
[Image: IMAG0123.jpg]
[Image: IMAG0122.jpg]
[Image: IMAG0126.jpg]
4rnnr33
300D50
05-03-2011, 10:08 PM #66
Just make sure your fittings are letting oil flow to the turbo port!
300D50
4rnnr33
05-04-2011, 12:30 AM #67
(05-03-2011, 10:08 PM)300D50 Just make sure your fittings are letting oil flow to the turbo port!
Yep I did I ended up clearancing the back of the turbo fitting just to be sure
4rnnr33
05-04-2011, 12:55 AM #68
Like the fittings stick through the back of the plate and block flow or something?
300D50
05-04-2011, 09:44 AM #69
Yeah, depending on the fitting you use, you might need to trim the end a bit. It's a weakness of tapered pipe thread...
300D50
05-04-2011, 03:44 PM #70
(05-04-2011, 09:44 AM)300D50 ...It's a weakness of tapered pipe thread...
True that.
True that.
4rnnr33
05-12-2011, 07:15 PM #71
Ok so i need some help on deciding what turbo to get. I rebuilt my current turbo probably less than 500 miles ago and its already shot. I think the inside of the housing where the bushing sit was just too worn out leading to the early failure. So im now looking for a complete replacement and wouldnt mind upgrading it with somthing that will have some better performance. So any ideas?
4rnnr33
05-12-2011, 07:25 PM #72
http://www.amazon.com/GT35-R-GT35R-Beari...295&sr=1-1
4rnnr33
05-12-2011, 11:47 PM #73
(05-12-2011, 07:25 PM)larsalan http://www.amazon.com/GT35-R-GT35R-Beari...295&sr=1-1
Is there a website with specs on that turbo? Particularly the exhaust flange
4rnnr33
05-13-2011, 01:47 AM #74
After seeing a BB turbo in person, I would jump on one in a second!
05-13-2011, 09:44 AM #75
(05-12-2011, 11:47 PM)4rnnr33 Is there a website with specs on that turbo? Particularly the exhaust flange
That page says this
Product Description
GT35-R BALL BEARING Turbo Charger Ball Bearing Compressor, Quick and Fast Spool High Quality Turbo, Each one is Computer Balanced and Tested. 4" Air Inlet 2.5" Compressed Air Outlet Standard T3 Turbine Housing Flange 4-bolt Exhaust Outlet , 3" OD Ball Bearing Compressor / Journal Bearing Turbine 300~500 WHP Oil and Water Cooled 6-25 PSI Working Pressure .70 A/R Compressor .63 A/R Turbine
I just posted that cause it was a 'cheap' ball bearing turbo. Though I can't seem to find it on their site.
http://www.cxracing.com/
That page says this
Product Description
4rnnr33
05-16-2011, 01:23 PM #76
What would you nguys think about somthing like this?
http://cgi.ebay.com/ebaymotors/T3T4-ball...35b1499c19
or this
http://cgi.ebay.com/ebaymotors/SUPER-60-...35b20a25d4
4rnnr33
or this
4rnnr33
06-07-2011, 10:19 PM #77
woohoo finally got my turbo back from performance techniques. Damn it looks awesome. Heres some pics
[Image: IMAG0128.jpg]
[Image: IMAG0129.jpg]
60 trim compressor wheel
[Image: IMAG0130.jpg]
[Image: IMAG0131.jpg]
[Image: IMAG0132.jpg]
4rnnr33
06-08-2011, 02:48 AM #78
Looks Friggin Sweet!
Hows she run?
Hows she run?
4rnnr33
06-08-2011, 05:47 PM #79
(06-08-2011, 02:48 AM)Captain America Looks Friggin Sweet!
Hows she run?
Its running great!
I also got some other things done today. Moved my battery to the drivers side so I could get my intake up front away from the exhaust.
[Image: IMAG0135.jpg]
[Image: IMAG0136.jpg]
4rnnr33
Hows she run?
Its running great!
mr_manny
Diesel Offroad Club
91
06-24-2011, 02:41 PM #80
looks like a nice air-filter solution.
where did you get those tubes, adapters?
thanks,
manny
mr_manny
thanks,
manny
4rnnr33
06-24-2011, 11:27 PM #81
you should be able to find everything on siliconeintakes.com
4rnnr33
4rnnr33
10-29-2011, 09:14 PM #82
Ok so I havent been on here for a while but would like to bring this thread back from the dead. I havent really done much to the truck besides putting on 39.5" tires. I really am trying to come up with another motor mount solution because the poly mounts are creating way too much vibration. Does anyone have any good ideas on what to use for rubber mounts?
4rnnr33
10-29-2011, 10:06 PM #83
On the Mercedes they used soft rubber mount and little shock absorbers and let the engine shake a little but it doesn't shake the car at all
4rnnr33
10-31-2011, 01:15 AM #84
so i ended up ordering a few of these
[Image: motormount.jpg]
They look like it should be pretty easy to modify my existing mounts to make these work they look like a pretty good style of mount I like the way the rubber sits in a tube which should make them plenty strong. More updates when they get here.
4rnnr33
10-31-2011, 07:15 AM #85
(10-31-2011, 01:15 AM)4rnnr33 so i ended up ordering a few of these
what kind of mount is that? What application? Im looking for something like that too, I hate the soft rubber MB mounts because they are too difficult to remove and wont work where im putting them, but id be using chevy mounts, which I think will be way too hard and result in the same problem you are having with vibration. these look like some of both worlds
4rnnr33
10-31-2011, 10:49 AM #86
They are for a 90-93 toyota celica and are anchor part # 8359. I ordered them off rock auto for about $10 a piece
4rnnr33
iheartboost
10-31-2011, 12:21 PM #87
wow this is so awesome. i love toyota pick ups. did you manage to keep its 4 wheel drive?
00 Mustang gt drift car
iheartboost
4rnnr33
10-31-2011, 12:31 PM #88
(10-31-2011, 12:21 PM)iheartboost wow this is so awesome. i love toyota pick ups. did you manage to keep its 4 wheel drive?
Oh ya its mated to the toyota 5 speed which uses the stock t case
4rnnr33
iheartboost
10-31-2011, 01:13 PM #89
yeaaaa thats the way to do it! lol. but do you plan for a soild front axel swap? i know its popular on those trucks
wish i could get a hold of an 86 my self. soild front stock Wink
also keep this updated. i would like to see what kind of mileage you get compared to the 22re. or w/e came in yours.
This post was last modified: 10-31-2011, 01:16 PM by iheartboost.
iheartboost
4rnnr33
10-31-2011, 01:51 PM #90
(10-31-2011, 01:13 PM)iheartboost yeaaaa thats the way to do it! lol. but do you plan for a soild front axel swap? i know its popular on those trucks
If you look through the thread you'll see its already been straight axled before I started the motor swap. And actually it was 85 that was the last year for straight axles and I can't remember if I posted it or not but when I had 37s and 5.29 gears I was able to get 21 mpg pretty easily which I consider very good for a lifted truck with 37" tires
4rnnr33
iheartboost
10-31-2011, 06:02 PM #91
thats not bad at all! and if you decide to convert over to WVO then you get free fuel! horray! lol.
but sorry about the not reading. pretty long just looked at the pictures HAHA
iheartboost
4rnnr33
10-31-2011, 07:06 PM #92
(10-31-2011, 06:02 PM)iheartboost thats not bad at all! and if you decide to convert over to WVO then you get free fuel! horray! lol.
I hear ya I do the same thing myself quite a bit its a lot of work to read through a long thread
4rnnr33
toyfreak
11-04-2011, 12:18 AM #93
Hmm, what model did you get those from? I know the alltracs 3sgte is a heavy 4banger, they might be strong enough to withstand some off road beatings. The guys that race alltracs end up making poly bushings because the stocks won't hold the torque from them.
toyfreak
11-04-2011, 05:42 AM #94
(11-04-2011, 12:18 AM)toyfreak Hmm, what model did you get those from? I know the alltracs 3sgte is a heavy 4banger, they might be strong enough to withstand some off road beatings. The guys that race alltracs end up making poly bushings because the stocks won't hold the torque from them.
I had the exact same question for different reasons! Big Grin
He said 90-93 toyota celica, anchor part number 8359
toyfreak
11-04-2011, 01:50 PM #95
I would say that the anchor # 8213 or 9119 would work better. They are designed for more abuse (seeing that its a rally car). They come on the 90-93 alltrac.
Some people have used 4bt mounts as well. I think my rubber spring bushing will last a while.
This post was last modified: 11-04-2011, 01:53 PM by toyfreak.
toyfreak
pyrojoe22
04-13-2012, 02:10 AM #96
I have a few questions as I'm trying to get my OM617 finished up this weekend.
When you did the SAS, what kit and spring size did you run? Did you move the front hanger 3/4" forward? How far did you move the transmission mount back? What tranny are you running?
I ask all this because I'm running Trail-Gear's 5" HD springs with the front hanger 3/4" forward, and when I flexed it with the 22R in, the drag link didn't hit the tie rod, so I left the steering box where it was. I bought 4x4labs adapter kit, and my motor is so far forward, the crank pulley is 1 1/4" from the front frame cross member. I'd love to leave the engine where it is to reduce the amount of oil pan mods. I'd just really like to know if you moved the transmission/engine combo back, because that would shove the oil pan into the drag link even more. I'd move the tranny back if I didn't think it'd give me hell with with oil pan.
pyrojoe22
BBCoffroad
04-13-2012, 06:46 AM #97
(04-13-2012, 02:10 AM)pyrojoe22 I have a few questions as I'm trying to get my OM617 finished up this weekend.
on my swap if you looked at it i used the stock x member and tranny location i had to mod the oil pan alot to make it fit properly im in the proces of making a rear sump oil pan right now while offroading you will notice on inclines you will get 0 oil pressure with a front sump pan take a look at my swap maybe it will give you some ideas. and for your exhuast run a 3 inch straight pipe its sounds awsome.
BBCoffroad
02-12-2014, 12:43 AM #98
I've been lusting after a 4runner lately. Nothing would make me happier than to throw a 602 in it......
 50 Guest(s)
 50 Guest(s)
