STD Tuning Engine New Master Power R series turbo
Pages (2): Previous 1 2
Rub87
02-01-2012, 05:51 AM #51
(01-31-2012, 11:37 AM)antonmies if the comp housing changes, the map changes. Where is the 178034 you said the map is from?
http://turbosupplycenter.com/en/borgwarn...1-a-r.html here you can buy it if you want it
As you stated, the map indeed changes, and not only slightl broadenign of the efficiency islands.. it has a important inpact on surge characteristics, and in this case it widens the map a healthy portion
This post was last modified: 02-01-2012, 05:59 AM by Rub87.
Rub87
antonmies
Go MPR
59
02-01-2012, 09:04 AM #52
(02-01-2012, 05:51 AM)Rub87 As you stated, the map indeed changes, and not only slightl broadenign of the efficiency islands.. it has a important inpact on surge characteristics, and in this case it widens the map a healthy portion
Yes, that's the general belief.
antonmies
kmaser
Turbocharged G-Wagen
125
02-23-2012, 12:09 AM #53
I've sent a PM and emailed the website with no response so I thought I would post again for an update on the R444-2, if it is available yet or I there is a timeframe on it?
I need to replace my turbo ASAP and would really like to try this one?
Thanks
kmaser
Thanks
antonmies
Go MPR
59
02-29-2012, 09:44 AM #54
Sorry, haven't been here in a while. Didn't you receive my emails, I sent you two if I remember correctly.
antonmies
sjwbond
03-16-2012, 03:44 PM #55
Is the R545 good for a single turbo application on an om606, i.e. can it spool by 2500 rpm?
also approx how much is shipping to turkey and how quıickly can it be dispatched for delivery? I need a turbo pretty quıckly.... and Im interested in this one..
sjwbond
jeemu
457
03-19-2012, 11:33 AM #56
Om605 and Master Power R4449. 466nm@2900rpm
http://www.youtube.com/watch?v=QytQIE-eB...ature=plcp
jeemu
antonmies
Go MPR
59
03-20-2012, 04:14 AM #57
Please use my email anton (at) hevosvoima.com to contact me. I try to follow the forums, but don't always have the time for it.
antonmies
antonmies
Go MPR
59
07-16-2012, 05:38 AM #58
I put some of the units I have readily available on eBay. Prices include the shiping to the US.
For the European customers, the prices are w/out Finnish VAT. Please contact me directly and I will give you a quote.
antonmies
Rub87
07-16-2012, 06:05 AM #59
Nice looking clamps! do you know if there are for sale somewhere in europe for similar price?
Rub87
antonmies
Go MPR
59
07-16-2012, 08:52 AM #60
(07-16-2012, 06:05 AM)Rub87 Nice looking clamps! do you know if there are for sale somewhere in europe for similar price?
Yes, we are located in Finland.
GT Clamps
Prices you see in the web shop include 23% VAT that's not included in the eBay listings.
antonmies
GT Clamps
m2rkz
09-01-2012, 01:08 PM #61
any experiances? Is it better than holset or not? And if it is better then tell me please why it is better?
m2rkz
m2rkz
09-04-2012, 02:57 AM #62
I asked because at the moment I'm using Holset hx 40 but master power turbos have much better maps. Does anyone have experiance now? Is it realistic? And does it last?
m2rkz
jeemu
457
09-04-2012, 03:38 PM #63
Just anwered you on your PM. Like i said Master Powers are been good on what we are used on them, old ones. These MPR series are new all around and not tested own cars yet, but responce id´s been good example MPR 61-Magnum and 545-2.
Bui it, test it and tell all how good is it Big Grin
jeemu
majesty78
09-05-2012, 01:14 PM #64
I am quite sure they will outperform a similar siyed Holset ;-)
majesty78
antonmies
Go MPR
59
10-05-2012, 09:05 AM #65
New catalog is out. You can download it from here
antonmies
jeemu
457
11-16-2012, 03:00 AM #66
Some new models on stock.
54mm billet and 13.6cm turbinehousing
[Image: _smaller.jpg]
and 61mm billett 17cm turbinehousing
jeemu
Turbo
11-16-2012, 04:06 PM #67
The R7277 and the R766 seams to be nice turbos, just a pitty they can not make higher pressure rate
(11-16-2012, 03:00 AM)jeemu Some new models on stock.
Turbo
jeemu
457
11-16-2012, 04:25 PM #68
(11-16-2012, 04:06 PM)Turbo The R7277 and the R766 seams to be nice turbos, just a pitty they can not make higher pressure rate
Hi. What kind engine and power goal you have?
jeemu
Turbo
11-16-2012, 04:32 PM #69
full potential of the Herlevi 8mm pump Smile
quote='jeemu' pid='46071' dateline='1353101156']
[/quote]
Turbo
[/quote]
Turbo
11-22-2012, 03:59 PM #70
Not even one suggestion Jeemu?
full power mean 270cc to 7200rpm 0m606.962
looking for two turbo
(11-16-2012, 04:32 PM)Turbo full potential of the Herlevi 8mm pump Smile
[/quote]
Turbo
[/quote]
EDH_Performance
11-22-2012, 04:32 PM #71
(11-22-2012, 03:59 PM)Turbo Not even one suggestion Jeemu?
Two turbos, as in twin turbo or compoud turbo?
EDH_Performance
Turbo
11-22-2012, 05:34 PM #72
If we speaking Sequential turbo set up with master power I can not find something since the pressure rate of the turbos is to low and out of the compressor map (of the pressure ratio so compound like some say would be what I am looking for
about 0,8kg/s at 4,2 bar absolute pressure and the exhaust pressure must be lower then the boost pressure at least at full boost, something that can make the work of a Garrett GTX4202R on top and a Borg warner efr 6258/ 7163 on the bottom. 1 bars boost from 1500rpm is required because of it is going to be a daily driver
It would be interesting to se what jeemu can come up with, I am open minded
(11-22-2012, 04:32 PM)EDH_Performance
This post was last modified: 11-23-2012, 02:35 PM by Turbo.
Turbo
jeemu
457
11-24-2012, 01:03 PM #73
What are specs on the engine?
jeemu
Turbo
11-24-2012, 03:59 PM #74
I do not at this stage say exactly say what is done, but I can tell you it is a lot, and it is not just the engine...
(11-24-2012, 01:03 PM)jeemu
Turbo
thegooch27
12-19-2012, 10:09 PM #75
(12-19-2011, 02:36 PM)antonmies R4449-2, R474-3 or even R545-2 or 4 depending of wanted power output. But if the thing is the best low end and mid range, you should go with either 4449 or 474.
I am wondering if you had an opinion on the R384? I am looking for an upgrade to my OM617 Turbo daily driver. I am most interested in quick spooling take off power and do not care about more top end at all. I cannot find much info on the R384, and I realize it would require a t2 to t3 adapter. I am looking to get 150 hp with this upgraded turbo as well as an A/W intercooler and maxxing out my MW pump. Water/Meth is an option for me as well. Do you think these would be an option or it too small? Thanks
This post was last modified: 12-22-2012, 12:07 PM by thegooch27.
thegooch27
antonmies
Go MPR
59
01-16-2013, 04:50 PM #76
Try R444-2
I'm throwing these out now, business was too slow Sad
Insane Prices
-Anton
antonmies
Try R444-2
Insane Prices
-Anton
maKe-
01-20-2013, 03:30 AM #77
Oh crap... Sad
Now my possible turbo choice is sold out, and no alternative suppliers available. R545-7 might have been excellent charger, but guess a HX35 or garrett gt/gtx equivalent will work also.
maKe-
Oh crap... Sad
JustPassinThru
W123 and W124
491
01-20-2013, 01:58 PM #78
(01-16-2013, 04:50 PM)antonmies I'm throwing these out now, business was too slow Sad
Insane Prices
-Anton
"Insane prices," you say...check your PM box.
JustPassinThru
Insane Prices
-Anton
antonmies
Go MPR
59
01-21-2013, 01:49 PM #79
PM replied.
MaKe, I think that Tarvikemotti has R545-7 in stock. Contact Jeemu to find if it's still available.
antonmies
PM replied.
