towing a trailer?
towing a trailer?
If you're just going to use it for bike racks and cargo trays, it's probably fine the way it is. If you're going to tow a trailer, more would be good.
Does the 123 have frame horns going all the way to the rear sheet metal? Making use of those instead of just sandwiching the rear sheet metal would be strongest.
I really like what you've got. Might have to steal the idea for the wagon.
Yeah it has a quasi frame in the back that terminates at the bumper mounts, and I plan on adding more bracing going forward and up under the car to that for more strength so I can pull trailers with it (thinking about turning the service box on my truck into a utility trailer and getting a regular pickup bed)
Looing good!
Going back to my diagram, just add some forward facing straps. Think about the forces/directions involved. You want to spread the weight out to all of the rear chassis.
1"x2" box (or 3"x1/4" flat) on the ends, bent or cut to be flush to the underbody. 3"x1/4" flat on the center, bolted up through the bottom of the spare well.
I used flats and had no trouble with heavy loads, just make sure the load is balanced and you drive slow/allow time for braking(blah blah blah stanard towing advice)
