STD Other Projects Long project: ELITE. ELectronical Injection Timing Enhancement.
  • 4 Vote(s) - 5 Average
Pages (2): Previous 1 2
starynovy
01-15-2018, 09:21 AM #51
BERU did it for you. Big Grin
http://beru.federalmogul.com/diesel-cold...w-plug-psg
This post was last modified: 01-15-2018, 09:21 AM by starynovy.
starynovy
Turbo
01-15-2018, 03:10 PM #52
Nice find!
well that is interesting, do you know what they cost?
little pitty they "just" go to 200 bars, I would like to go to 220bars
Turbo
Nice find!
starynovy
01-15-2018, 05:09 PM #53
Around 50€. These come on new TDIs, found it on Skoda Octavia mk.3 TDI. I dont think you will see even 200bar. Cylinder pressure is directly tied to engine torque and even strong DI 6cyl. diesels which make a lot of it are made to withstand around 230 bar max. So if you do not aim upwards 700Nm..
starynovy
Turbo
01-16-2018, 03:59 PM #54
If I could find them for 50euro I will buy some...
most sertanly buy them, what is the thread for mercedes glow plugs in 0m613/om648?
Newer Mercedes om642ls is on the 200 bar region like the bmw 550/750d, if the new 400ps BMW is higher I have no information about, what the new engines with steel pistons have I do not know ether, but it would be interesting to now, but later engines I have no feeling that they are over engineered like 0m606/om613/om648.
I am thinking about 220bar with water injection since it brings peak combustion pressure down a bi,t but have at this moment no info about how much water is needed, that is why this is so interested, really good to get some feedback when playing around.
where you get that they should withstand 230 bar? om613 is original 145bar, if I am not wrong om648 is at 155bar, and how much they can take I do not know yet, and no steel piston from Mercedes will fit since bore is different
Turbo
starynovy
01-17-2018, 10:32 AM #55
That pressure was stated for then new N57 engines family from bmw, obviously bi and tri turbo ones.
starynovy
Turbo
01-17-2018, 03:42 PM #56
Well acording to
https://drive-my.com/en/tech/item/2172-n...amily.html
they where limited to 200bar peak combustion pressre only on the N57s tri turbo vertion
regarding the B57S quad turbo
https://blog.caranddriver.com/bmw-has-co...el-engine/
it state 3046psi about 210 bars combustion pressure
or read
https://newatlas.com/bmw-quad-turbo-750d/43355/
so please where did you get the 230bars figure from?
bmw is doing a new series where
https://www.autocar.co.uk/car-news/new-c...ngine-line
where the most powerful get 2700 injection pressure, can not find maximum combustion pressure there
Turbo
Well acording to
or read
starynovy
01-18-2018, 05:11 AM #57
Well did not remember it exactly read it like 3 years ago, so 210Bar it is. Still far cry from shitty 160 MBz can handle.
starynovy
Turbo
01-18-2018, 06:55 AM #58
ok thank for the clarification
you mean that mercedes om613/om648 can not take more then 160bar peak combustion pressure? or what do you mean with -"Still far cry from shitty 160 MBz can handle." is piston the weak part or what is your experiance, can you please tell?
If that would be the case it would be f###n "%¤&%%&%¤# since I now have really god injectors for upcoming tuning that i put some years in finding and they where even better then I wished for, turbo and pump and rail gearbox suspension etc, just need to study this ridiculous edc15c6/edc16c2 how it works and that is really not my cup of tee...
Turbo
Evgeniy1987
01-24-2018, 05:51 AM #59
[Image: c8ee7cdb-fc20-47bb-8ebe-df11b7283b5d.jpg]
it is not dead.. I just need 30 hours a day for the other stuff...
Evgeniy1987
Turbo
01-25-2018, 01:02 AM #60
wow
so what are we seeing here Smile
Turbo
wow
Evgeniy1987
01-25-2018, 03:09 AM #61
Well, to the left is an EDC pump ( Big Grin ) assembled by Barrote a while ago (thanks again!)
I had a worn out timing device that i bought for 2€ on ebay, I disassembled it and had it milled down to a cilinder of 25mm outer diameter. So 25mm on the outside, splines for the pump shaft on the inside. Using a TranTorque (http://www.fennerdrives.com/trantorque/) coupling, I attached the big flange to the pump.
Now, with a special metal coupling, I can attach the pump to the test bench, which contains the same thing as the red one on the right (I took a 2nd one for the foto)
The red thing is a torque (and rpm) measuring shaft. It is very precise. I can read it with the same device I used for the pressure measurement, so it can measure up to 150 kS/s .
So, If I go to 3000 pump-rpm, it does 50 per second. I can have up to 3 kS per revolution. So, over 360 degrees, I will have 3000 measurement points. Which is good, as we need to get nice, precise torque curves.
The outcome of the test will be shown to Harmonic Drive AG, who will help me with choosing the right harmonic drive.
This post was last modified: 01-25-2018, 03:09 AM by Evgeniy1987.
Evgeniy1987
Turbo
01-25-2018, 03:19 PM #62
what is so interesting with harmonic drive? I must be missing something.
I understand  of it before that you where trying to create a electric controllable timing device?
what do you have that can sample so fast?
I want to get hold of something that can sample fast since I want to measure the pressure in the cylinder during all cycles in the engine.
There are system for this like below but it it is a lot of money even if I really need it for my tuning.
www.tfxengine.com
Turbo
www.tfxengine.com
Evgeniy1987
01-25-2018, 05:50 PM #63
http://www.datatranslation.co.uk/gb/meas...f7509de78b
These are affordable Smile
Oh and by the way: remember, in-cilinder pressure is not the same thing as pre-chamber pressure..
This post was last modified: 01-26-2018, 05:55 AM by Evgeniy1987.
Evgeniy1987
baldur
Fast
511
01-26-2018, 11:42 AM #64
I want an in line transducer like that for my engine dyno. Do they come rated for 10000RPM and 2000Nm?
Baldur Gislason
baldur
Baldur Gislason
Turbo
01-26-2018, 03:35 PM #65
(01-25-2018, 05:50 PM)Evgeniy1987 http://www.datatranslation.co.uk/gb/meas...f7509de78b
what about controllable timing device you where working to! I really need one to my engine to control it better
Yes I know on IDI cylinder pressure is not the same as pre chamber pressure, I got some 0m613/om648 too Wink
I have not yet fingered out how to measure cylinder pressure on the om606 with out weakening of the cylinder head
Turbo
Evgeniy1987
01-28-2018, 10:37 AM #66
(01-26-2018, 11:42 AM)baldur I want an in line transducer like that for my engine dyno. Do they come rated for 10000RPM and 2000Nm?
Baldur,
The measurement shaft I have at work is up to 500 Nm rated KTR part. ... But KTR can offer much bigger stuff:
https://www.ktr.com/de/produkte/antriebs...esswellen/
https://www.ktr.com/de/produkte/antriebs...taflex-70/
Dataflex 70 would cut it: up to 3000Nm or 5000Nm. Whether it could go up to 10000 RPM - I don't know. I believe, the problem in that case is not the shaft, but the electronica amplifier.
But you probably won't bother building an amplifier that could Tongue
This post was last modified: 01-28-2018, 10:37 AM by Evgeniy1987.
Evgeniy1987
Baldur,
Evgeniy1987
01-28-2018, 10:57 AM #67
(01-26-2018, 03:35 PM)Turbo
Everything I put in this topic has to do with that timing device, haha
I am almost done with school... so I was motivating myself by pulling stuff out of the closet..
Evgeniy1987
Evgeniy1987
03-02-2018, 01:08 PM #68
[Image: injectors_holder.jpg]
This way, I will not have to bend the precious fuel lines!
Ah, if someone needs to know: the thread is M22x1.5
This post was last modified: 03-02-2018, 01:08 PM by Evgeniy1987.
Evgeniy1987
SurfRodder
Jackass Extraordinaire
611
09-21-2019, 11:49 AM #69
Any update on this one?
OBK# 62
SurfRodder
OBK# 62
atypicalguy
11-21-2019, 07:29 PM #70
(01-26-2018, 03:35 PM)Turbo I have not yet fingered out how to measure cylinder pressure on the om606 with out weakening of the cylinder head
Is it not possible to screw a pressure transducer into the glow plug hole?
atypicalguy
atypicalguy
11-21-2019, 08:17 PM #71
atypicalguy
