STD Other Projects ForcedInduction's 1982 300D
  • 2 Vote(s) - 5 Average
Pages (3): Previous 1 2 3
08-17-2010, 10:01 AM #101
Hate those Leaky freeze plugs for sure! I've got one right behind the oil filter housing...
jeemu
457
08-18-2010, 05:16 PM #102
0-60 10sec
And you say at this is slower http://www.youtube.com/watch?v=9zs5W-e_HBs
Have to film new vid with new camber arms and extra 75hp Cool
jeemu
0-60 10sec
08-18-2010, 05:32 PM #103
(08-18-2010, 05:16 PM)jeemu 0-60 10sec
How nice. My 160hp car can keep up with your 500hp car to 60. Rolleyes
Next.
Next.
jeemu
457
08-18-2010, 05:34 PM #104
(08-18-2010, 05:32 PM)ForcedInduction
Next.
Its your car what take 10sec 0-60 Smile
jeemu
Next.
08-18-2010, 05:40 PM #105
Your English has been incoherent the last few days. Whats changed?
Anyways, the discussion is moot, your baiting posts in my thread will be removed shortly.
This post was last modified: 08-18-2010, 05:45 PM by ForcedInduction.
08-18-2010, 05:45 PM #106
whats the best way to repair the freeze plug on the car? Can you cover it up for now with some JB weld?
jeemu
457
08-18-2010, 05:46 PM #107
(08-18-2010, 05:40 PM)ForcedInduction Your English has been incoherent the last few days. Whats changed?
Anyways, the discussion is moot, your trolling posts in my thread will be removed shortly.
I m sorry my bad english, not my languauge. Sorry if you feel like i m trolling because i had different opinion of things.
You can remove my messages, like you done before.
jeemu
08-18-2010, 05:51 PM #108
(08-18-2010, 05:45 PM)dropnosky whats the best way to repair the freeze plug on the car? Can you cover it up for now with some JB weld?
It can be replaced in the car, you just have to remove whatever is in front of it, in my case thats the injection pump. I've tried JB twice but the coolant makes its way through before the JB can harden. Its slowed significantly but there is still a pinhole left.
08-18-2010, 06:44 PM #109
He said below 3200 that you have less torque than he does. Your dyno run is one gear right? On the street (as he said) this will prove to be more useful. Of course having the top end power that you do is useful as well. I personally would rather have the low end torque. I would imagine a slush box will make boost sooner through the rpms once you are going, but personally I will take the low end grunt any day.
08-19-2010, 02:06 AM #110
(08-18-2010, 05:51 PM)ForcedInduction
Why don't you drain the coolant before you apply the JB? Or am I missing something... I believe they make little tools to remove the plugs when the engine is still in the car...
08-19-2010, 07:11 AM #111
(08-19-2010, 02:06 AM)Captain America Why don't you drain the coolant before you apply the JB?
The cooling system in this engine already had a rust issue that was a royal PITA to clear up. I'd like to keep air exposure to a minimum so I don't have to go through that again.
In other news...
Disassembled and cleaned the leaking #2 injector and its finally sealed.
Pulled the #5 prechamber hoping to find the cause of the nailing and found nothing. The piston top looks good and the prechamber looks normal. Swapped in my good spare with no change to the sound. At this point its now a "live with it" issue. But at least its combustion nailing and not mechanical knocking like with the 240's engine.
This post was last modified: 08-19-2010, 07:14 AM by ForcedInduction.
In other news...
08-21-2010, 08:13 PM #112
The ignition tumbler finally jammed for good and left me stranded, only 2 miles from home.
I called AAA but the request of "bring a drill and 3/16 bit" pretty much made their brains explode. Three hours later the truck finally arrives. Then the tow driver damn near ripped a gash in the frame before I stopped him and pointed out the tow loops on each end of the car. To top it off I had to listen to his "9/11 was a conspiracy" bullshit the whole way home.
Now I've got go drive the other car to work, get my drill and get that damn steering lock out of there. Rolleyes
This post was last modified: 08-21-2010, 08:14 PM by ForcedInduction.
08-21-2010, 08:20 PM #113
That sucks. I've managed to get all mine fixed right before certain doom. Are you going to have it releafed or just carry two keys for it?
08-21-2010, 10:37 PM #114
(08-21-2010, 08:20 PM)winmutt Are you going to have it releafed or just carry two keys for it?
It always had two keys. Drilling destroys the lock body so there's no way I can reuse it. I'll see if Tom Judd has one from his parts cars.
Here is the lock removal.
http://www.superturbodiesel.com/std/remo...-1658.html
This post was last modified: 08-28-2010, 07:48 AM by ForcedInduction.
09-25-2010, 06:34 AM #115
I found the source of #5's nailing, low compression.
Cold Hot
1- 300
2- 330
3- 340
4- 335 360
5- 250 275
Oh well, it runs well enough. I'll just have to live with it like I do my 240's knocking wrist pin.
Cold Hot
1- 300
2- 330
3- 340
4- 335 360
5- 250 275
09-25-2010, 08:05 AM #116
(09-25-2010, 06:34 AM)ForcedInduction I found the source of #5's nailing, low compression.
That sucks, any idea whether its valve or ring related?
This may have absolutely no relevance to the problem at hand or how the MB valve operates since I have never played with them apart from adjustments, but on an old low compression straight six bronco I had, we were able to improve compression slightly by rotating the valves without breaking the whole motor down.
In that case, there was an issue with the valve seating across 2 cylinders.
09-25-2010, 08:26 AM #117
I don't know. I'll have to build a leakdown tester to see where the air is going.
The 617 has rotocaps. Doesn't mean it still works though.
09-25-2010, 03:30 PM #118
Try some bg 109 in some fresh oil for a week! We did it on a land cruiser 6 cyl and picked up 60psi in compression on one cylinder and like 10-20 on the others might help! My dads 6.9 ford non turbo really woke up after using it!
I guess it helps clean the rings!
09-25-2010, 07:59 PM #119
I think with the tank of B50 a few months ago, synthetic 15W50, no crankcase gasses going back into the intake, 6.6gph water injection (its used about 10 gallons so far) and daily Italian tuneups, carbon should pretty much be gone from the cylinders. Wink It still averages 23.4mpg too.
This post was last modified: 09-25-2010, 08:00 PM by ForcedInduction.
09-26-2010, 12:26 PM #120
maybe it's some worn valves?
10-10-2010, 06:09 PM #121
Looks to be that way. The leakdown test has most of the air going out the exhaust pipe.
4thesporty
10-19-2010, 09:59 AM #122
(10-10-2010, 06:09 PM)ForcedInduction Looks to be that way. The leakdown test has most of the air going out the exhaust pipe.
First post here, but I see so many of your posts over at PP.
FI, I am curious what 90 elbow you used for your air filter to turbo connection. Is it just a generic one, or did you cut the stock to 90?
Thanks.
4thesporty
Thanks.
12-14-2010, 11:38 AM #123
I finally replaced that broken column lock to one from a junkyard 80 300D that still had the keys in it.
I also got a new toy from a GMC Topkick. Big Grin
[Image: S2E.jpg]
[Image: S2E.jpg]
12-14-2010, 11:47 AM #124
(12-14-2010, 11:38 AM)ForcedInduction I finally replaced that broken column lock to one from a junkyard 80 300D that still had the keys in it.
5 years of junkyarding now and I have never ever seen a car with the keys in the ignition. I have found cars with keys and broken ignitions but never one that worked... Rare find.
12-14-2010, 12:04 PM #125
Its fairly common if you look at every car, especially domestics. There have been occasions where I needed to stash something (don't want to carry it around the lot, for example) so I just put it in a car's trunk and lock it. Most people won't take the effort to force open a trunk. I even left a manifold in the trunk of a Volvo for a week before I remembered it! Big Grin
This post was last modified: 12-14-2010, 12:05 PM by ForcedInduction.
12-14-2010, 12:32 PM #126
Wierd, must be something my junkyard does (keeping keys).
300D50
Graphite Moderator, ala RBMK
12-14-2010, 08:29 PM #127
Heh heh heh... I used to collect JY keys...
Till I had to rip a truck to pieces to find the key between the seats so I could uuse the door lock cylinders...
300D50
02-14-2011, 05:14 AM #128
Jtn190D
MERCEDES DIESEL POWER!
192
02-14-2011, 08:44 AM #129
Hood stack?
Jtn190D
Hood stack?
02-14-2011, 08:53 AM #130
Only waiting on a 2-2.5 silicone boot to finish. I bought one on ebay but the seller screwed me over and never shipped after a week.
yankneck696
395
02-14-2011, 09:42 AM #131
We used to use SS wire to attatch the keys to the column. Made us alot more money on the column sales & less destruction.
Ed
yankneck696
Ed
led-panzer
02-14-2011, 09:57 AM #132
That's all poking through the hood? Quite a statement. Looks good!
1985 300D 280,000 miles RIP
led-panzer
02-14-2011, 10:18 AM #133
Whats up with the green dots on the dash?
02-14-2011, 11:31 AM #134
(02-14-2011, 10:18 AM)winmutt Whats up with the green dots on the dash?
Water injection stages.
This post was last modified: 03-17-2011, 06:32 AM by ForcedInduction.
03-17-2011, 06:34 AM #135
Just a quick video accelerating onto the highway to test microphone placement. I'll get a good 0-60 video this weekend.
Imaginos
In disguise
66
03-17-2011, 10:11 AM #136
That sounds nice!
Is the fuel consumption figure still in this ballpark?
Imaginos
That sounds nice!
03-17-2011, 10:53 AM #137
Did you repaint the needles? The yellow on the gauges looks almost orange so I am assuming its original. Good god that is loud. Where is the mic, in the engine bay?
03-17-2011, 05:55 PM #138
(03-17-2011, 10:53 AM)winmutt Where is the mic, in the engine bay?
About 10" from the air filter.
03-17-2011, 06:59 PM #139
(03-17-2011, 05:55 PM)ForcedInduction
No wonder it sounds deafeningly bad ass. Does the iphone have a mic input or something?
mike-81-240d
more like mike-84-300d now
427
03-17-2011, 09:52 PM #140
Oh my shit that sounds like pure heaven.
mike-81-240d
03-18-2011, 08:15 AM #141
(03-17-2011, 06:59 PM)winmutt Does the iphone have a mic input or something?
Kodak Zi8
and a generic omnidirectional mic.
Kodak Zi8
stan
03-23-2011, 03:02 PM #142
(12-14-2010, 12:04 PM)ForcedInduction so I just put it in a car's trunk and lock it. Most people won't take the effort to force open a trunk.
i hate people who do that. every time i come across a w123 where someone did that, i make an extra effort to open the trunk up because obviously there is something good in there that someone wanted to bogart for themselves.
stan
03-23-2011, 05:37 PM #143
(03-23-2011, 03:02 PM)stan
Same here haha...yet i havnt found anything too special yet.
03-23-2011, 08:35 PM #144
Thats why I always pick some shitbox like a Buick, NEVER the same type of car the parts are from.
This post was last modified: 03-23-2011, 08:35 PM by ForcedInduction.
 30 Guest(s)
 30 Guest(s)
