STD Other Projects 500BHP DRIFT PROJECT
  • 5 Vote(s) - 4.2 Average
maxypriest
09-19-2013, 02:06 AM #101
(08-29-2013, 06:45 AM)Ksteen2 if you have 10mm all around, its a 20mm space, and a 4" os 25.4mm bigger, si if you hammer it little bit it should fit Wink
This is true, however the concern I have is heat. On RHD cars the DP runs next to the steering box ( very close) and I'm concerned about cooking the fluid and seals!
I will have the DP ceramic coated, and will make a fancy shield for the steering box.
I might be able to make a larger DP later on once the project is actually running!
maxypriest
mantahead
10-05-2013, 04:12 PM #102
hi,
my friend made this crank pulley for me from a solid block of aluminium.
gonna run the charger at 18k rpm to start with, lol
wish i had a lathe.
[Image: 10106031785_94b11956a3.jpg]
Lisburn-20131005-00639.jpg by mantahead, on Flickr
[Image: 10106035715_30331bc407.jpg]
Armagh-20131005-00641.jpg by mantahead, on Flickr
[Image: 10106001284_e03c5a8467.jpg]
Armagh-20131005-00642.jpg by mantahead, on Flickr
hi,
i made a start on the fuel tank, i have no folder so had to improvise with some heavy metal and some vice grips.
[Image: 10106320376_3edbb95ef3.jpg]
Armagh-20131004-00631.jpg by mantahead, on Flickr
[Image: 10106336863_1c38eb27a1.jpg]
Armagh-20131004-00629.jpg by mantahead, on Flickr
ended up putting 2 baffle plates inside.
[Image: 10106186864_7118aae8a1.jpg]
Armagh-20131004-00632.jpg by mantahead, on Flickr
[Image: 10106196784_1236ce78f7.jpg]
Armagh-20131004-00636.jpg by mantahead, on Flickr
This post was last modified: 10-05-2013, 04:29 PM by mantahead.
mantahead
hi,
wish i had a lathe.
hi,
10-07-2013, 12:42 PM #103
That pulley is sweet man! That should get that charger spinning Wink
mantahead
10-08-2013, 04:38 PM #104
WTF, bonnet won't close, lol
[Image: 10161363306_55036e9664.jpg]
Armagh-20131008-00668.jpg by mantahead, on Flickr
[Image: 10161392054_aa8a172d5d.jpg]
Armagh-20131008-00664.jpg by mantahead, on Flickr
[Image: 10161202984_4e66c76c59.jpg]
Armagh-20131008-00661.jpg by mantahead, on Flickr
[Image: 10161459903_a7a0b5a872.jpg]
IMG-20131008-00654.jpg by mantahead, on Flickr
[Image: 10161278395_1feae484a7.jpg]
Armagh-20131008-00669.jpg by mantahead, on Flickr
This post was last modified: 10-08-2013, 04:48 PM by mantahead.
mantahead
EDH_Performance
10-09-2013, 12:50 PM #105
Make a hole in the hood now mate, want to see how it looks! You can have shot gold or?
This post was last modified: 10-09-2013, 02:01 PM by EDH_Performance.
EDH_Performance
mantahead
10-09-2013, 02:54 PM #106
here we go;
[Image: 10169998965_b18cf933e9.jpg]
Armagh-20131009-00677.jpg by mantahead, on Flickr
[Image: 10170004795_e2ff52aa82.jpg]
Armagh-20131009-00672.jpg by mantahead, on Flickr
[Image: 10175231895_b9257d40dc.jpg]
mantahead
here we go;
10-09-2013, 04:04 PM #107
Are you going to be able to see around it?! It sticks wayyyy up there
mantahead
10-09-2013, 05:16 PM #108
oh yea, i'll be looking out the side windowsTongueTongue
mantahead
HughF_UK
10-10-2013, 07:36 AM #109
Wayne, looks good!
Have you decided which way the compound will work yet?
HughF_UK
Wayne, looks good!
mantahead
10-10-2013, 04:47 PM #110
(10-10-2013, 07:36 AM)HughF_UK Wayne, looks good!
yea, i'm gonna feed the turbo and then valve will open for turbo to suck from atmosphere as well.
this is the first setup i will try.
mantahead
10-10-2013, 05:05 PM #111
(10-10-2013, 04:47 PM)mantahead
Gale banks recently did this on a Semi engine, I think bit should work well.
mantahead
10-10-2013, 06:25 PM #112
(10-10-2013, 05:05 PM)MFSuper90
only valve i know of is penta marine engine, you know of any thing bigger, like 4 inch?
mantahead
10-10-2013, 06:57 PM #113
This is on a 14.0L Detroit engine running a 8.3L supercharger turning 4.31 over crank speed.The only thing I can find is they are running massive dual blow off valves between the supercharger and turbo.
How that works? I'm not quite sure... Huh
HughF_UK
10-11-2013, 03:41 AM #114
I'm going the other way round, turbo blowing into M112, feeding into inlet..
HughF_UK
mantahead
10-12-2013, 04:13 PM #115
Hugh, you ever thought about a clutch on the charger for disengaging?
mantahead
Triker
10-13-2013, 11:24 AM #116
Great looking project! The charger above the hood looks awesome Cool Hope you get this rocking hard Cool
S210 320CDI
W140 S300DT
EX: C126 om606 compound "300STC
Triker
S210 320CDI
W140 S300DT
Duncansport
10-13-2013, 12:11 PM #117
This thing looks like it should be in the new Mad Max film haha. Looks great!!
Duncansport
maxypriest
10-14-2013, 06:35 AM #118
That is some fucking MFP Madmax 1 shit going on there.
Possibly the first time i have seen an advantage of having a RHD car on STD - so you can see past a massive S/C!
Brilliant.
PS make sure you brace the inlet manifold to the engine - a lot of tension on those top inlet/head bolts.
This post was last modified: 10-14-2013, 06:38 AM by maxypriest.
maxypriest
Brilliant.
HughF_UK
10-14-2013, 09:31 AM #119
(10-12-2013, 04:13 PM)mantahead Hugh, you ever thought about a clutch on the charger for disengaging?
Nope, I'm going to run the m112 all the time (it displaces 1800cc ish per rev, engine displaces 1500cc/rev)
HughF_UK
mantahead
10-14-2013, 05:21 PM #120
ok, what pulley ratio you going for?
mantahead
HughF_UK
10-15-2013, 08:01 AM #121
Not sure on that yet Wayne, probably 1.6:1 or something like that. I don't want the eaton to make too much boost and hence heat, it is mainly there for off the line torque.
HughF_UK
mantahead
10-15-2013, 04:23 PM #122
(10-14-2013, 06:35 AM)maxypriest That is some fucking MFP Madmax 1 shit going on there.
Brilliant.
LOL.
have belt tensioner brackets supporting the manifold at the front so maybe a bracket at the back should do.
did some messing with the bonnet today.Tongue
[Image: 10298393194_55e65c53a6.jpg]
IMG-20131015-00711.jpg by mantahead, on Flickr
[Image: 10298672216_764d781f87.jpg]
IMG-20131015-00712.jpg by mantahead, on Flickr
maybe some mesh in the gap.
[Image: 10299113414_379975be47.jpg]
IMG-20131015-00705.jpg by mantahead, on Flickr
This post was last modified: 10-15-2013, 05:01 PM by mantahead.
mantahead
Brilliant.
LOL.
10-15-2013, 10:07 PM #123
Looking good man! Keep it up, can't wait for the end results, awesome project
mantahead
12-08-2013, 05:27 PM #124
wee bit more work done, more bars to the cage and fuel cell sorted.
[Image: 11196806253_47f8dc41cb.jpg]
IMG-20131203-00847.jpg by mantahead, on Flickr
[Image: 11196661365_03c7d62b99.jpg]
IMG-20131203-00849.jpg by mantahead, on Flickr
[Image: 11196707246_2fc2176ef0.jpg]
IMG-20131129-00842.jpg by mantahead, on Flickr
[Image: 10891782854_a8d7b336e1.jpg]
IMG-20131015-00707.jpg by mantahead, on Flickr
mantahead
Gearbound
In need of a OM606.96x
172
01-10-2014, 08:40 AM #125
insane build and where can i get a hood ornament like that? Smile
Gearbound
01-10-2014, 01:34 PM #126
It's beautiful!
For the extra air inlet valve, can you get a throttle body from a gas car and use that with a strong actuator?
It's beautiful!
mantahead
01-10-2014, 05:26 PM #127
[Image: 11877450505_9ba06599d8.jpg]
Armagh-20140108-00904.jpg by mantahead, on Flickr
making this myself, i think an actuator type will open too quickly and give a power dip.
also made aluminium cone for dual plenum,
[Image: 11878424296_5711268b49.jpg]
IMG-20131113-00806.jpg by mantahead, on Flickr
This post was last modified: 01-10-2014, 05:36 PM by mantahead.
mantahead
mantahead
01-13-2014, 07:18 PM #128
radiator arrived today,
[Image: 11938092653_2110f841c8.jpg]
Armagh-20140113-00908.jpg by mantahead, on Flickr
[Image: 11938140643_ce4aa98951.jpg]
Armagh-20140113-00911.jpg by mantahead, on Flickr
mantahead
mantahead
01-24-2014, 05:36 PM #129
got some pipework done today.
[Image: 12122952495_d4105be66b.jpg]
Armagh-20140124-00961.jpg by mantahead, on Flickr
[Image: 12123229163_774dd0ef4f.jpg]
Armagh-20140124-00963.jpg by mantahead, on Flickr
[Image: 12122989815_2a4858a61f.jpg]
Armagh-20140124-00950.jpg by mantahead, on Flickr
[Image: 12124566504_824fece02f.jpg]
Armagh-20140124-00964.jpg by mantahead, on Flickr
mantahead
erling66
SuperDieselVan
294
01-25-2014, 10:06 AM #130
This is going to be totally wild and very coolBig Grin Keep up the good work, one day it will be finishedSmile
HuhCoolTongue
erling66
HuhCoolTongue
mantahead
01-31-2014, 06:49 PM #131
Cheers Erling,
hopefully be finished for the summer.
decided to remove front panels and wheel tubs and replace with tube, make some space and add some strength.
drivers wheel tub was wrinkled from previous accident anyway, so i have more wheel room for that extra steering angle.
[Image: 12242906113_02d0117667.jpg]
Armagh-20140131-00991.jpg by mantahead, on Flickr
[Image: 12242928793_9cba1a744b.jpg]
Armagh-20140129-00978.jpg by mantahead, on Flickr
[Image: 12243333106_151d396cd9.jpg]
Armagh-20140131-00998.jpg by mantahead, on Flickr
mantahead
Cheers Erling,
mantahead
02-11-2014, 03:59 PM #132
ha ha, nissan skyline drift bumper on a w202.
[Image: 12465944984_5661cf0e1a.jpg]
Armagh-20140210-01034.jpg by mantahead, on Flickr
[Image: 12465953194_0c1edcf3eb.jpg]
Armagh-20140210-01035.jpg by mantahead, on Flickr
This post was last modified: 02-11-2014, 04:00 PM by mantahead.
mantahead
Turbo
02-15-2014, 03:44 AM #133
I like it! Smile
(02-11-2014, 03:59 PM)mantahead ha ha, nissan skyline drift bumper on a w202.
Turbo
I like it! Smile
mantahead
02-15-2014, 04:18 PM #134
was just put on for a laugh but actually fits pretty well. need to get some arches then decide on bumpers.
mantahead
mantahead
02-24-2014, 05:37 PM #135
one of my driveshaft adaptors.
[Image: 12756800075_a5696b380d.jpg]
Armagh-20140219-01070.jpg by mantahead, on Flickr
got a lend of this machine .
[Image: 12757045743_101e6ea1e2.jpg]
Lisburn-20140222-01085.jpg by mantahead, on Flickr
[Image: 12757216254_ffbd5bb9d8.jpg]
Lisburn-20140222-01087.jpg by mantahead, on Flickr
[Image: 12756998393_70d3695460.jpg]
Armagh-20140212-01047.jpg by mantahead, on Flickr
[Image: 12757513954_3ae6ec1632.jpg]
IMG-20140221-01084.jpg by mantahead, on Flickr
This post was last modified: 02-24-2014, 05:44 PM by mantahead.
mantahead
02-25-2014, 12:46 PM #136
That tube work is great, your manifold looks amazing.
anto
02-25-2014, 05:01 PM #137
This gets crazier and crazier, keep it up Wayne, il have to get a run down to see it in the flesh sometime.
anto
mantahead
02-26-2014, 05:26 PM #138
cheers guys,
any time anto
mantahead
cheers guys,
any time anto
03-05-2014, 06:06 PM #139
Yeah totally awesome, I want a C300TD!
So the bonnet wouldn't close properly over the 606 cam cover even with all the sound proofing removed?? Balls!
Regards, H.
This post was last modified: 03-05-2014, 06:07 PM by Hario'.
Regards, H.
mantahead
03-06-2014, 03:11 AM #140
Bonnet would actually close. I raised up centre section to see if it improved the look of the charger
mantahead
mantahead
03-07-2014, 06:01 PM #141
hi,
i was bored and made this up.
[Image: 12969259983_2cfbd674b0.jpg]
WP_20140305_16_19_06_Smart.jpg by mantahead, on Flickr
[Image: 12969529374_c21d939a07.jpg]
WP_20140305_16_18_53_Smart.jpg by mantahead, on Flickr
then i thought, why the hell notTongue
[Image: 12998303085_a99b2b1099.jpg]
WP_20140307_16_40_32_Smart.jpg by mantahead, on Flickr
[Image: 12998443193_1861b50e0b.jpg]
WP_20140307_16_52_33_Smart.jpg by mantahead, on Flickr
gonna add some butterflies.Big Grin
mantahead
hi,
03-10-2014, 03:40 PM #142
(03-06-2014, 03:11 AM)mantahead Bonnet would actually close. I raised up centre section to see if it improved the look of the charger
Lol! Sweet..
Lol! Sweet..
mantahead
03-10-2014, 04:45 PM #143
got fans mounted today.
[Image: 13068900135_e76813b9b3.jpg]
WP_20140310_001.jpg by mantahead, on Flickr
[Image: 13069230264_acffe93398.jpg]
WP_20140310_005.jpg by mantahead, on Flickr
mantahead
mantahead
04-05-2014, 05:42 PM #144
picked up this today, spare engine
[Image: 13653048073_af38697a77.jpg]
mantahead
mantahead
04-08-2014, 04:41 PM #145
spare engine has come in handy
[Image: 13725452574_3242fef4bd_c.jpg]
[Image: 13725116423_8dcdde72ce_c.jpg]
can sort out the wastegates now and make inlet manifold support brackets.
mantahead
mantahead
05-14-2014, 04:48 PM #146
hi,
got the wastegates sorted.
[Image: 14000815188_3b27caf03f_b.jpg]WP_20140514_011.jpg by mantahead, on Flickr
mantahead
hi,
05-15-2014, 09:24 AM #147
That is INSANE!!!!
That is INSANE!!!!
mantahead
05-26-2014, 05:38 PM #148
little update.
[Image: 14091548957_91678df462_b.jpg]WP_20140522_004.jpg by mantahead, on Flickr
[Image: 14091462689_9f6d6cd121_b.jpg]WP_20140526_005.jpg by mantahead, on Flickr
[Image: 14274796591_763ae7bf81_b.jpg]WP_20140526_001.jpg by mantahead, on Flickr
[Image: 14274780841_06fe08cdcb_b.jpg]WP_20140526_018.jpg by mantahead, on Flickr
[Image: 14274766191_fb2875951b_b.jpg]WP_20140526_019.jpg by mantahead, on Flickr
mantahead
little update.
05-27-2014, 05:46 PM #149
Nice cant wait to see the outside when its painted
mantahead
06-04-2014, 06:37 AM #150
cheers, might have to go racing with no paint on outsideBig Grin
[Image: 14157563608_8925a76ff7_b.jpg]
mantahead
 8 Guest(s)
 8 Guest(s)
