STD Other FS / WTB / Buying guides EBay Alert Thread
EBay Alert Thread
EBay Alert Thread
  • 3 Vote(s) - 3.67 Average
dieselboy
Rotatin 5500 times a minute
680
10-07-2011, 05:24 PM #151
Want. I want a slc with a 606
http://cgi.ebay.com/ebaymotors/1981-Merc...2c5fb7445f
-Jesse
97 f250 psd 4x4, crawler
70 f250 390
83 Volvo 242, lots of mods
66 Volvo amazon
dieselboy
-Jesse
70 f250 390
66 Volvo amazon
mike-81-240d
more like mike-84-300d now
427
10-07-2011, 05:28 PM #152
The sucky thing is that the SLC above isn't a true Hammer car. It has a bored out 5.6 M117, as the 32 valve 6.0 doesn't fit in the R107 engine bay.
mike-81-240d
01-16-2012, 03:00 AM #153
Son of Biiiiiiiiiioooootcchhhh! $4,050.00 current bid!!!!
Mercedes-Benz 280SL factory ZF 5 speed transmission MINT complete
1963 thru 1971 230SL 250SL 280 SL RARE pristine
http://www.ebay.com/itm/Mercedes-Benz-28...3f12694793
Quote:280SL factory FIVE SPEED gearbox - RARE
Hard to find PRISTINE ZF stock 5 speed gearbox with driveshaft, linkages and mounting hardware - complete. These were special order in the 1963 through 1971 Pagoda roadster (230SL, 250SL or 280SL.) The five speed gearbox option was apparently available only up through the 1969 model year here in the US but very few American customers pursued the added expense and wait time which is an absolute pity. This is the transmission that will make any Pagoda a great touring car. It can be retrofitted into any 4 speed or automatic Pagoda series SL. Included here is the hard to find short output shaft with original balancing weights. No custom work is required. Also included is a brand new factory shift knob with 5 speed graphic - your choice of black or white to match your car's steering wheel. Wiring for reverse gear is original and intact including factory connector.
This transmission comes from a low-mileage (approx. 80k original documented kilometers on the clock,) accident free 1968 european specification 280SL that suffered from serious rust issues. Both the motor and transmission were superb but the car was more valuable parted out. I had the opportunity to drive the original car this transmission came from and can attest that all synchros including 2nd and 3rd shifted flawlessly and that the gearbox was quiet and free of any unnecessary noise or vibration. There was no problem accessing reverse. This transmission shifts beautifully as one would expect in a new car such as a Ferrari or Maserati but of this vintage. I drove the original car from Palm Springs to Los Angeles at speeds over 100 MPH. I had the opportunity to drive this car in the Santa Monica Mountains over Malibu. The mechanics of this transmission were flawless.
The oil in this gearbox will most certainly be original and should NEVER be changed.
The vehicle from which this gearbox was removed had the original inside fender welds preserved. All body panels, though heavily rusted, appeared to be original. The car had never been in a frontal collision of any magnitude. Therefore there is no impact or sheer damage to the internal gearing or output spline.
This transmission was removed from the original vehicle in September of 2011. This transmission had NOT been sitting idle for long periods prior to that date. The donor vehicle was not only in operating condition when I agreed to buy this transmission but had been driven regularly for years. I paid $11,500.00 for this gearbox and the accompanying parts offered here. I never got around to installing this transmission in the concours 69 SL for which it was purchased. Unfortunately I sold the car last week.
The factory ID plate of this transmission reads as follows:
Zahnradfabrik Friedrichshafen A.G.
Typ. S5-20
Stueckl. Nr. 102500057
AFT Oel ('oil')
Gretriebe (serial number) # 2333
Plate No. 1025301014-02
Main case No. 1025401042 ZF
Bell housing No. 1025401049
X-fer plate No. 1025408018 ZF
Rear transmission housing No. 1025401054 ZF
Gear rations as transcribed from original plate. These are quite legible and this plate appears to never been modified or removed from the housing.
1 Gg: 3.29
2 Gg: 2.215
3 Gg: 1.418
4 Gg: 1.0
5 Gg: 0.848
R Gg: 3.49
Tach: 2.16
Please note that Gg is an abbreviation for "Gang" which is the German for 'gear.'
The majority of the so-called 5 speed Pagoda cars you will see at shows or car meets have in fact been fitted with a gearbox salvaged from a W124 series or similar car and a custom drive shaft has been cut and balanced. This is NOT the same gearbox nor are the ratios optimal nor is the machining of all parts including linkages of this high a caliber. This is truly a magnificent gearbox and decidedly the most desirable and anatomically correct upgrade for any sixties through 1971 SL.
This post was last modified: 01-16-2012, 03:04 AM by DeliveryValve.
Typ. S5-20
AFT Oel ('oil')
1 Gg: 3.29
2 Gg: 2.215
3 Gg: 1.418
4 Gg: 1.0
5 Gg: 0.848
R Gg: 3.49
Tach: 2.16
JustPassinThru
W123 and W124
491
01-25-2012, 10:47 AM #154
A turbocharger with a Holset exhaust housing and a Garrett compressor housing. I didn't know you could do that...
http://www.ebay.com/itm/HOLSET-HX35-GARR...43aca752c0
JustPassinThru
01-25-2012, 11:33 AM #155
"NO BENT FINS ON INTAKE OR EXHAUST SIDE"
well that photo of the intake kinda looks like a bent fin to me. as is.
led-panzer
01-25-2012, 12:48 PM #156
1.15 AR exhaust housing lol. That thing would never spool. On an MB diesel anyway
1985 300D 280,000 miles RIP
led-panzer
02-04-2012, 04:44 PM #157
Is this any good?
http://www.ebay.com/itm/Mercedes-W123-In...3a70175d5f
Is this any good?
02-04-2012, 04:56 PM #158
I got one of those from a pick-n-pull/pull-a-part whatever for like $11. They had 2 of them there but, I've yet to try and install it.
led-panzer
02-04-2012, 05:22 PM #159
Won't clear the stock turbo
led-panzer
02-04-2012, 06:15 PM #160
For sure? It was looking like the snail might align right between those couple double runners.
02-04-2012, 06:38 PM #161
I think you will need the other type from the W115 instead of the one pictured, but if you can make it work, good deal !
02-05-2012, 03:04 AM #162
I think I'll hold on to my money for now, I've noticed lately the more I spend the more dear it becomes lol
lgreeley83
Mr. Rumbles
03-16-2012, 11:16 AM #163
http://www.ebay.com/itm/Mercede-Benz-W12...3cc2bee1cf
I need a tach. No mercedes are ever in my junkjard. 75$ seems absurd. Is it? Anyone got one for sale?
lgreeley83
w123love
Stockish
354
03-16-2012, 02:04 PM #164
No way don’t do it. I’ll have to see how much they are next time I go to the PaP. They have gotta be like $10
The VEGEWGN
w123love
The VEGEWGN
03-16-2012, 03:01 PM #165
I got 2 of those. Hmm, unless I threw one or both of them out. Who knows if they work.
lgreeley83
Mr. Rumbles
03-16-2012, 03:20 PM #166
Thanks i almost made a stupid impulsive purchase. Also my car i think has a 2 pin harness.
lgreeley83
w123love
Stockish
354
03-19-2012, 03:56 PM #167
"Street Life W123"
What a looker....
The VEGEWGN
w123love
"Street Life W123"
What a looker....
The VEGEWGN
03-19-2012, 04:25 PM #168
Looks nice. How about some pics of the engine bay, yah?!
03-21-2012, 07:17 PM #169
Nothing a little primer couldn't cover! Cool
03-21-2012, 09:09 PM #170
(03-19-2012, 03:56 PM)w123love "Street Life W123"
What a looker....
Thanks, I'd prefer http://bringatrailer.com/2012/03/21/extr...benz-300td
What a looker....
03-22-2012, 01:40 AM #171
OM606 125K miles on it.
http://www.ebay.com/itm/Mercedes-Benz-E3..._500wt_949
04-09-2012, 09:32 AM #172
http://cgi.ebay.com/ebaymotors/Mercedes-...2a1bec4914
non turbo but it must have a turbo kit
This post was last modified: 04-09-2012, 09:34 AM by willbhere4u.
04-09-2012, 12:17 PM #173
I can't decide what to think about it lol
w123love
Stockish
354
04-10-2012, 12:30 AM #174
http://www.ebay.com/itm/MERCEDES-W123-GE...773wt_1114
Oh hello.....
The VEGEWGN
w123love
Oh hello.....
The VEGEWGN
aaa
04-10-2012, 01:14 AM #175
m102 bellhousing, nothing to write home about, considering overpriced uk shipping.
aaa
serverman777
04-13-2012, 01:34 AM #176
http://cgi.ebay.com/ebaymotors/1983-MERC...3f15ce03a9
Its a '83 w123 om617 Limo NON Turbo and EGR-less with 21,xxx on the clock.
'84 300 SD w126 Race Car Wink
'85 500 SEL w126 Scraped
serverman777
yatzee
04-15-2012, 09:01 PM #177
OM606 Short Block, pickup only from Tenn.
http://www.ebay.com/itm/Mercedes-W210-E3...d7&vxp=mtr
This post was last modified: 04-15-2012, 09:01 PM by yatzee.
1991 350SDL, burning oil and slow
1991 500SL, yet another project car
1984 190D, swapped 3.6 m104 with a megasquirt
yatzee
w123love
Stockish
354
05-09-2012, 12:19 AM #178
300GD Turbo Intake
Is this something to look for? I cannot tell if it has an EGR port.
The VEGEWGN
w123love
300GD Turbo Intake
The VEGEWGN
05-09-2012, 01:38 AM #179
(05-09-2012, 12:19 AM)w123love 300GD Turbo Intake
That's looks like a 1985 Cali Intake.
Are you looking for a EGR-less stock type intake?
w123love
Stockish
354
05-09-2012, 12:07 PM #180
(05-09-2012, 01:38 AM)DeliveryValve
Nope just sent my 78 SD intake off to be ceramic coated Smile
The VEGEWGN
w123love
The VEGEWGN
05-09-2012, 09:36 PM #181
Mercedes 2.0 turbo diesel he also has a 5spd mt transmission
http://www.ebay.com/itm/Mercedes-2-0Turb...231cfa4a13
05-15-2012, 10:13 PM #182
Not sure if these are any good or not, I might consider getting one just because they're so cheap
http://www.ebay.com/itm/Universal-polish...2593189311
Purplecomputer
Slowness 220D
897
05-16-2012, 07:05 PM #183
(05-15-2012, 10:13 PM)sassparilla_kid Not sure if these are any good or not, I might consider getting one just because they're so cheap
Think that would help once I put that turbo on my 240?
Purplecomputer
05-16-2012, 07:11 PM #184
(05-16-2012, 07:05 PM)Purplecomputer
It may help, I think it would help increase the lifespan of the non-turbo parts from the extra stress they'll be getting after the turbo is added
waz
05-23-2012, 01:54 PM #185
I've seen worse.
1982 Mercedes-Benz 300-Series TD, Pickup
waz
I've seen worse.
05-29-2012, 12:07 PM #186
Bosch IP for sale.
Here is a 6 cylinder Bosch IP for sale that I think you could pirate the 10mm elements from to swap into your 617 MW pump if you wanted to go that large.
http://www.ebay.com/itm/200752618565?ssP..._500wt_949
Bosch IP for sale.
05-30-2012, 01:06 PM #187
RHD euro 1980 280se in CA
http://cgi.ebay.com/ebaymotors/1980-MERC...20c622f858
06-02-2012, 09:11 PM #188
w115 Intake - Funny description on the ad about someone we know....
http://www.ebay.com/itm/1976-1985-merced..._500wt_949
w123love
Stockish
354
06-02-2012, 10:46 PM #189
(06-02-2012, 09:11 PM)DeliveryValve w115 Intake - Funny description on the ad about someone we know....
lolzzzzzz
The VEGEWGN
w123love
lolzzzzzz
The VEGEWGN
06-03-2012, 06:11 PM #190
Hahahaa
Hahahaa
06-04-2012, 12:44 PM #191
(06-02-2012, 10:46 PM)w123love lolzzzzzz
(06-03-2012, 06:11 PM)sassparilla_kid Hahahaa
I thought that ad was way funny not to post.. even though it still a w115 manifold.
06-09-2012, 05:55 PM #192
$98 Depo euro lamps
http://www.ebay.com/itm/MERCEDES-E-CLASS...2251815304
$98 Depo euro lamps
Secondaries
06-13-2012, 11:26 AM #193
Any interest in a meticulously maintained 1994 S350D with a rebuild motor? Less than 30,000 miles on rebuild with strengthened rods (this WAS a rod bender!). This car is owned by the owner of Houston Biodiesel, and I can attest to this car's immaculate condition. Simply beautiful and runs like a dream.
http://cgi.ebay.com/ebaymotors/Mercedes-...993wt_1182
Secondaries
06-13-2012, 06:02 PM #194
(06-13-2012, 11:26 AM)Secondaries Any interest in a meticulously maintained 1994 S350D with a rebuild motor? Less than 30,000 miles on rebuild with strengthened rods (this WAS a rod bender!). This car is owned by the owner of Houston Biodiesel, and I can attest to this car's immaculate condition. Simply beautiful and runs like a dream.
If i wasn't closing on a house that car would be in my garage.
Secondaries
06-18-2012, 12:10 PM #195
This car is still for sale if anyone wants to make an offer. http://houston.craigslist.org/cto/2969856194.html
Secondaries
08-24-2012, 01:56 PM #196
Non-EGR exhaust manifold from a 79, he's asking $100 but it's rusty as hell
http://www.ebay.com/itm/Mercedes-Exhaust...4c&vxp=mtr
w123love
Stockish
354
09-06-2012, 04:14 PM #197
OM617 Flywheel and PP
Somebody snatch this up before I do
The VEGEWGN
w123love
The VEGEWGN
CRD4x4
CompoundSuperTurboDiesel4x4!
399
09-15-2012, 01:30 PM #198
OM617 N/A Intake manifold $35
http://item.mobileweb.ebay.com/viewitem?...cmd=VIDESC
'05 Jeep Liberty CRD - 160k
'06.5 VW Jetta TDI - 230k
CRD4x4
JustPassinThru
W123 and W124
491
09-27-2012, 02:34 PM #199
Gray-market non-turbo 1983 300D with 5-speed and Euro bumpers near Salt Lake City, Utah. The ad title says "turbo diesel" but it is not, look at the air intake. The car is driveable:
http://cgi.ebay.com/ebaymotors/Mercedes-...2575d533dd
This post was last modified: 09-27-2012, 02:39 PM by JustPassinThru.
JustPassinThru
JustPassinThru
W123 and W124
491
10-09-2012, 08:45 PM #200
W115 300D intake manifold in Arizona:
http://www.ebay.com/itm/290787377485?item=290787377485
JustPassinThru
