STD Tuning Engine Jeep Liberty Turbo to T3 Adaptor
  • 1 Vote(s) - 5 Average
Pages (2): Previous 1 2
bgkast
VGT-Intercooled
325
04-25-2008, 10:03 AM #51
The head fit the diameter fine, I did not get to test the depth or insert the bolt for the pictures because I need to chase my manifolds threads in that location with a tap.
bgkast
04-25-2008, 12:34 PM #52
bgkast The head fit the diameter fine, I did not get to test the depth or insert the bolt for the pictures because I need to chase my manifolds threads in that location with a tap.
* winmutt taps foot patiently. I already got the 8mm-10mm stud but I think it is too short. I got an allen bolt head for the blind one.
Cant wait!!!!
My 8 to 10 stud is marginal in length too. Is there some sort of high temp loctite I can use on the studs?
Cant wait!!!!
dieselkid
04-25-2008, 05:28 PM #53
sorry bro.
Sent it out today 2day.
-jon
dieselkid
sorry bro.
-jon
bgkast
VGT-Intercooled
325
04-25-2008, 09:04 PM #54
It looks like I will have to thin out the head of my alan bolt a few mm.
I spent some quality time with my angle grinder and dremel and transitioned the two flange holes yesterday and today.
bgkast
04-28-2008, 03:30 PM #55
Heh how long did that take? I planned on doing the same with mine.
bgkast
VGT-Intercooled
325
04-28-2008, 04:18 PM #56
It took about 3 hours. It would have been faster if I started out roughing the hole with my angle grinder, instead of trying a dremel for an hour at first. Once the hole is roughed out the dremel works great.
bgkast
04-29-2008, 11:07 AM #57
bgkast It took about 3 hours. It would have been faster if I started out roughing the hole with my angle grinder, instead of trying a dremel for an hour at first. Once the hole is roughed out the dremel works great.
Mine came in (wife didnt tell me of course). Was the 10->8mm stud long enough?
bgkast
VGT-Intercooled
325
04-29-2008, 04:29 PM #58
It will work, but I would like it to be longer on the 10MM side. Any ideas on high-temp loc-tite? We will need to use something to keep that 8 to 10 MM stud in place with only 3/8” of threads screwed into the exhaust manifold. I would also like to use something to prevent exhaust leaks around the studs where they thread into the adaptor.
bgkast
11-04-2008, 03:37 PM #59
I've made up an adapter using Bryan's dimensions(Friendly hint:It's easier for machinists if you dimension everything outwards from the center of the block)
While I'm waiting on some gasket material, I can't get the manifold studs out. Are they pressed in or threaded in? I don't want to crack the manifold trying to pull them out.
11-04-2008, 04:36 PM #60
Simpler=Better I've made up an adapter using Bryan's dimensions(Friendly hint:It's easier for machinists if you dimension everything outwards from the center of the block)
Threaded. I had to put the studs in a vise and turn the manifold.
11-04-2008, 06:50 PM #61
Yes, after 20+ years of heat cycling and corrosion they can be a bear to get out. I had to use triple jam nuts to get the studs out of mine without damage.
GREASY_BEAST
11-04-2008, 08:14 PM #62
ditto on how big a pain in the ass those studs are to get out.. Try lots of PB Blaster or Liquid Wrench, heat, maybe give them a good whack (gently, don't crack anything) with a hammer, and use a multitude of jam nuts.. good luck! I don't know what pitch they are, but 3/8" studs from autozone just sorta threaded right in for my HX30 swap.. lol
GREASY_BEAST
11-04-2008, 09:26 PM #63
I'll be making a 8-10 stud for it
bgkast
VGT-Intercooled
325
11-05-2008, 01:21 PM #64
I'm a Civil engineer, not a mechanical. Wink :mrgreen:
bgkast
11-05-2008, 10:58 PM #65
It's all good. If I get bored at work one of these days I'll post "formal" drawings of all the parts
EDIT: I've attached a drawing with dimensions from the center of the T3 stud holes. Yeah I was kinda bored :roll:
[Image: adapteriq7.th.jpg][Image: thpix.gif]
bgkast
VGT-Intercooled
325
04-01-2009, 09:27 PM #66
Anybody have the orignal flange dimensions from post 12? I can't find them on my computer
bgkast
04-02-2009, 04:43 AM #67
This?
This?
bgkast
VGT-Intercooled
325
04-02-2009, 04:11 PM #68
Thanks
bgkast
Thanks
09-24-2009, 01:49 AM #69
Any updates? I'm looking into a Liberty turbo for my 240 instead of bolting the stock T3 back on.
I do already have a turbo, but it has end play so I'm searching for another.
This post was last modified: 09-24-2009, 01:50 AM by ForcedInduction.
09-24-2009, 08:37 AM #70
I have the test plate still if you want it for shipping costs...
Jdmills
09-24-2009, 10:25 AM #71
(09-24-2009, 01:49 AM)ForcedInduction Any updates? I'm looking into a Liberty turbo for my 240 instead of bolting the stock T3 back on.
can these newer VNT turbos be rebuilt, or is it cheaper, easier, and smarter to find a good used one?
Jdmills
09-24-2009, 12:36 PM #72
The cost of a used turbo is usually less than a (genuine, not Chinese clone junk) rebuild kit.
Kiwibacon
09-25-2009, 03:53 AM #73
Did I mention I have solidworks and a whole collection of turbo adapter designs already?
It's pretty quick to crank out another if you guys provide some measurements.
Kiwibacon
Tymbrymi
Klatta Klatta
185
09-25-2009, 10:26 AM #74
(09-25-2009, 03:53 AM)Kiwibacon Did I mention I have solidworks and a whole collection of turbo adapter designs already?
Could you make a T3 to 3" V-band? Big Grin
Also, will this adapter plate work for the Sprinter turbos?
John Robbins
Tymbrymi
John Robbins
Kiwibacon
09-25-2009, 05:18 PM #75
(09-25-2009, 10:26 AM)Tymbrymi
Which end of the T3?
I have a sprinter turbo, the flange is indeed a mongrel. I've got a T3-sprinter turbo adapter but it runs through about 120 degrees. I've yet to install this turbo.
Kiwibacon
brynton
09-27-2009, 10:07 AM #76
How much boost can the liberty and sprinter turbo handle??
Cheers
brynton
Cheers
09-27-2009, 03:49 PM #77
They are limited by compressor surge. Without an intercooler, 15psi before 3500rpm and 23psi past 3500rpm.
This post was last modified: 09-27-2009, 03:49 PM by ForcedInduction.
Kiwibacon
09-27-2009, 04:41 PM #78
(09-27-2009, 03:49 PM)ForcedInduction They are limited by compressor surge. Without an intercooler, 15psi before 3500rpm and 23psi past 3500rpm.
Are those your experiences at alititude or predicted off that map?
My GT2256V has a smaller trim than that map shows, which will give it higher pressure ratios without surge.
Kiwibacon
brynton
09-28-2009, 06:28 AM #79
Thanks for that,
so are the Sprinter and Jeep turbo's the same unit??
I only have to worry about being 240 foot as opposed to you guys with some really high spots.
I have an intercooler that is 700x300x75, ( was planning Super turbo on a OM605, but reading more about the VNT/VGT these seem to offer greater driveabilty as opposed to an HX35) would this be a little large, and would the turbo benifit from an external wastegate??
Sorry to hijack this thread
brynton
Thanks for that,
09-28-2009, 10:46 AM #80
They are not. GT2256V(sprinter) vs GT2056V(jeep)
09-28-2009, 03:07 PM #81
(09-27-2009, 04:41 PM)Kiwibacon My GT2256V has a smaller trim than that map shows
Yes, the Sprinter turbos that are electrically actuated have a slightly larger inducer.
This post was last modified: 09-28-2009, 03:07 PM by ForcedInduction.
Tymbrymi
Klatta Klatta
185
09-29-2009, 09:12 AM #82
(09-25-2009, 05:18 PM)Kiwibacon Which end of the T3?
Going from the T3 on the exhaust manifold to a v-band for the 6.0L Powerstroke turbo. Big Grin
Nice work on the GT22 adapter! Cool
John Robbins
Tymbrymi
John Robbins
Kiwibacon
09-29-2009, 02:03 PM #83
(09-29-2009, 09:12 AM)Tymbrymi
Thanks.
Get me the measurements for the V band flange and I'll see what I can do.
Kiwibacon
Thanks.
10-01-2009, 10:40 AM #84
Kiwi what manifold is that from? Looks like an om314.
Kiwibacon
10-01-2009, 02:16 PM #85
(10-01-2009, 10:40 AM)winmutt Kiwi what manifold is that from? Looks like an om314.
88 onwards Isuzu NPR.Angel
Engine is a 4BD1T, but the later 4BD2T used the same manifold. 3.9 turbo 4 banger.
This post was last modified: 10-01-2009, 02:17 PM by Kiwibacon.
Kiwibacon
10-02-2009, 04:05 PM #86
Well crap, I've been laid off so the Liberty turbo plan is dead. I'll just throw the stock T3 back on the 240 and be done with it.
Tymbrymi
Klatta Klatta
185
10-05-2009, 11:32 AM #87
(09-29-2009, 02:03 PM)Kiwibacon Get me the measurements for the V band flange and I'll see what I can do.
The adapter would need to make a 45 degree angle upwards in order for the turbo to fit (I think)... Coming out from the manifold a bit is cool too. Thanks!
(10-02-2009, 04:05 PM)ForcedInduction Well crap, I've been laid off so the Liberty turbo plan is dead.
That sucks! Hope you can find something quickly...
John Robbins
Tymbrymi
John Robbins
Kiwibacon
10-05-2009, 03:41 PM #88
(10-05-2009, 11:32 AM)Tymbrymi The adapter would need to make a 45 degree angle upwards in order for the turbo to fit (I think)... Coming out from the manifold a bit is cool too. Thanks!
I've got the T3 flange and V band flange modelled. Can you give a side on sketch of the orientation you want between them?
Kiwibacon
cell
01-22-2010, 01:07 PM #89
has anyone worked on an adapter flange for the electronically actuated 2256v? or has anyone found dimensions for it anywhere?
[Image: gt2256v-exhaust-flange.jpg]
cell
300SD81
01-22-2010, 01:17 PM #90
(01-22-2010, 01:07 PM)cell has anyone worked on an adapter flange for the electronically actuated 2256v? or has anyone found dimensions for it anywhere?
I started working on one and got as far as having a CAD file for it, never found a place to get it made for a reasonable price tho. I know theres a few other people that have/are working on one...
This post was last modified: 01-22-2010, 01:17 PM by 300SD81.
Ich liebe meine Autos!
300SD81
cell
01-22-2010, 01:25 PM #91
ahh, I didn't see you had a 2256 thread! nice.
are you interested in sharing that CAD file? Wink
cell
300SD81
01-22-2010, 01:37 PM #92
(01-22-2010, 01:25 PM)cell ahh, I didn't see you had a 2256 thread! nice.
I'll see if I can find it. I made it in the software from emachineshop.com so I don't think its in a standard format.
300SD81
cell
01-22-2010, 02:23 PM #93
well, I helped out the UT solar racing team and was given a copy of solidworks as a result. I'd be happy to model it up in solidworks. I think it can export to a standard cad format (I think .dxf?).
cell
 33 Guest(s)
 33 Guest(s)
