STD Tuning Engine Holset oil supply and drain
01-25-2010, 08:53 AM #1
The HE341Ve is finally well on its way to running. The drain is 42* below horizontal but the issue is supply pressure and temperature. MB's oil pump runs up to 107psi cold and at above 3000rpm when hot. The oil thermostat is 230*F but the 341Ve is water-cooled.
From Holset's manuals
Quote:8. Normal oil temperature is 95+/-5°C (203+/-9°F). It should not exceed 120°C (248°F) under any operating condition.
11. Oil return pipes are permitted to decline at an overall angle of not less than 30 degrees below horizontal.
14. The minimum oil pressure when the engine is on load must be 210 kPa (30 lbf/in2). Maximum permissible operating pressure is 500 kPa (72 lbf/in2) although 600 kPa (88 lbf/in2) is permitted during cold start up. Under idling conditions pressure should not fall below 70 kPa (10 lbf/in2).
15. Recommended oil flows for the turbochargers are 2 litre/min at idle and 3 litre/min above maximum torque speed.
What size restriction orifice would I need to reduce 100psi to max. 75psi without overly restricting flow? The garretts use a 3mm orifice (in the oil line for the stock T3 and inside the oil hole on the GT22).
[Image: attachment.php?aid=2093]
This post was last modified: 01-25-2010, 09:02 AM by ForcedInduction.
muuris
OM605
318
01-25-2010, 10:56 AM #2
Not sure about OM617, but on OM60x max pressure should be around 75psi.
muuris
01-25-2010, 12:21 PM #3
Relief valves on all MB's diesels are set at 7bar.
muuris
OM605
318
01-25-2010, 05:06 PM #4
(01-25-2010, 12:21 PM)ForcedInduction Relief valves on all MB's diesels are set at 7bar.
I stand corrected, although I've never heard anyone having problems with oil pressure being too high for a turbo. That 5bar limit sounds kinda strange..
muuris
E300TSC
Turbo-Supercharged
321
01-26-2010, 01:07 PM #5
Off the top of the head, it's pretty hard to guess at the size of the oriface without knowing the internal restriction of the turbo and the flow rate of that leg of the oil system.
I would construct a test supply line with a pressure gauge after a fitting where you could swap restrictors. Connect this to the turbo and play with the restrictions until you reach your desired pressure. In reality, the internal restriction of the turbo may be sufficient to keep the pressure to 75 PSI.
Once you get your pressure set, connect the turbo oil discharge to a tube and run it into a container. Run the engine at the prescribed RPM for one minute and compare the amount of oil you collect to the specs.
For temperature control, you put a small 2 pass oil cooler in line with the supply line. You wouldn't even have to mount it in an air stream. The radiant action would probably be sufficient to cool the oil a little.
Another option would be to construct a small water to oil heat exchanger out of copper tubing and either mount it in series with the water supply to the turbo or mount it independently if you don't plan on using the water cooling on the turbo.
This post was last modified: 01-26-2010, 01:10 PM by E300TSC.
E300TSC
01-26-2010, 09:10 PM #6
(01-26-2010, 01:07 PM)E300TSC For temperature control, you put a small 2 pass oil cooler in line with the supply line. You wouldn't even have to mount it in an air stream. The radiant action would probably be sufficient to cool the oil a little.
Those are both good ideas.
I have a little oil to air cooler from a small Kohler engine (about 4" square) and a gasoline to A/C fuel cooler off an 70's MG.
Both will have to run alongside each other to reach the turbo so adding the MG cooler wouldn't be an issue, I could attach it to the rear engine hoist eyelets.
The issue with the MG cooler is its meant for carburetor fuel and low-side A/C pressures. I'll have to do some pressure tests and see if it will fail.
This post was last modified: 01-26-2010, 09:11 PM by ForcedInduction.
Tymbrymi
Klatta Klatta
185
01-27-2010, 10:43 AM #7
(01-26-2010, 09:10 PM)forcedinduction a gasoline to A/C fuel cooler off an 70's MG.
That's pretty spiffy!
(01-26-2010, 09:10 PM)forcedinduction The issue with the MG cooler is its meant for carburetor fuel and low-side A/C pressures. I'll have to do some pressure tests and see if it will fail.
The A/C side of things should be fine since when the A/C is off and the pressures are equalized, there should be over 100PSI there. The fuel side... no clue.
This post was last modified: 01-27-2010, 10:43 AM by Tymbrymi.
John Robbins
Tymbrymi
John Robbins
01-27-2010, 11:28 AM #8
Temperature I'm not too worried about; MB uses a pretty large oil cooler and I can always add a fan to it or extend the radiator shroud. Colorado isn't known for its heat either. Big Grin
Its the pressure I'm really worried about. At this point I'm figuring starting with 3mm (or 1/8") and working from there with some replaceable inline fittings and a post-orifice gauge. If I can get cold-start pressure around 80psi then maintaining more than 30psi will be a given since even hot idle doesn't go below 20psi.
01-27-2010, 01:01 PM #9
I have owned several MG's and never seen one of those very cool!
If you get a chance take some pics of the cooler off the kohler engine
 6 Guest(s)
 6 Guest(s)
