STD Tuning Engine Boost and EGT combo gauges
Syncro_G
0-60 in 29 sec
280
01-28-2010, 12:34 PM #1
I'm looking for a combo gauge and was wondering what others here are using.
The dual gauge from Spa looks interesting but the name is impossible to search for on STD without getting a flood of posts on SPAcers.
Spa dual is 450 and includes the senders. Has alert and logging capabilities.
BD x monitor looks interesting but would be more expensive since it doesn't come with senders (edit - Just talked with BD. the price does include all senders so it's about the same price as the spa dual gauge)
westach makes a good unit (very old-school looking)- no extra features and it's just the gauge so it's probably going to cost the same as the other units once installed.
This post was last modified: 01-28-2010, 01:44 PM by Syncro_G.
'84 G-Wagen turbodiesel
'75 240D 4-Speed
Syncro_G
'75 240D 4-Speed
01-28-2010, 02:12 PM #2
I'm running plain vdo egt and boost and an oil temp myself
This post was last modified: 01-28-2010, 02:12 PM by willbhere4u.
01-28-2010, 06:18 PM #3
I think Westach is what you're looking for.
http://flashoffroad.com/Accessories/Gaug...st/EGT.htm
Syncro_G
0-60 in 29 sec
280
01-28-2010, 10:03 PM #4
(01-28-2010, 02:12 PM)willbhere4u I'm running plain vdo egt and boost and an oil temp myself
multiple gauges are great - I just don't have the dash space and still need to a fit battery monitor somewhere. Also am trying to keep it really non-techy.
(01-28-2010, 06:18 PM)forcedinduction I think Westach is what you're looking for.
It's definitly the most old school. I just wish it were back lit. Though not essential, I like that the alarms and logging that the other two offer.
'75 240D 4-Speed
Syncro_G
'75 240D 4-Speed
01-28-2010, 11:14 PM #5
Did you check out the gauge setup on this 300sd looks really cool but expensive!
and what do you mean by non-techy?
When I'm done it will look factory! That is a stock gauge pod from a vw golf!
Syncro_G
0-60 in 29 sec
280
01-29-2010, 02:02 AM #6
(01-28-2010, 11:14 PM)willbhere4u Did you check out the gauge setup on this 300sd looks really cool but expensive!
Was there supposed to be a link or do you mean the VW MKII pod?
I like it (have been a VW fan for a long time) but I don't have that kind of space. The truck doesn't have much of a center console to work with. I'm trying to avoid taking up space below the heater controls as that's right over the cup holders and is valuable space.
"techy" may not be the right word because what I'm imagining will probably require more hidden tech than just adding a bunch of gauges.
But the intent is to have as few gauges as possible or at least the perception that there are fewer while still getting the important stuff (boost, egt, oil pressure, water temp, battery A, battery B, etc)
A row of gauges across the dash looks "techy" but if I can get something with alarms and readings that swap to show what's important at the moment, that would be ideal. That's more like what you'd see on a modern car with an engine monitor computer.
'75 240D 4-Speed
Syncro_G
'75 240D 4-Speed
01-29-2010, 10:39 AM #7
Sorry here is the link
I really like his gauge setup! I think he made it him self if I understand the post correctly I would try to buy one my self if I thought I could afford it
http://superturbodiesel.com/std/mb-300sd...t-996.html
This post was last modified: 01-29-2010, 10:50 AM by willbhere4u.
Syncro_G
0-60 in 29 sec
280
01-29-2010, 11:51 AM #8
(01-29-2010, 10:39 AM)willbhere4u Sorry here is the link
Yeah, I remember seeing that and also figured it was DIY. It's more or less what I'm looking for. The BD X-monitor appears to be similar (tracks 3 inputs) and the form factor might be able to fit in my ash tray slot. it's just $$$.
'75 240D 4-Speed
Syncro_G
'75 240D 4-Speed
01-29-2010, 12:50 PM #9
(01-28-2010, 10:03 PM)Syncro_G ....
Do you have space above the steering wheel column?
This might work.
http://www.thefind.com/cars/info-dual-st...-gauge-pod
This might work.
Syncro_G
0-60 in 29 sec
280
01-29-2010, 03:09 PM #10
(01-29-2010, 12:50 PM)DeliveryValve Do you have space above the steering wheel column?
This might work.
Unfortunately, I don't have any space between steering wheel and dash. problem would be easily solved.
Here's another that looks interesting...
http://www.zeitronix.com/
their simple digital readout looks like a full featured product that can be put in tight places.
Also their "DashDAQ" looks really cool but well beyond my budget and is too big to fit anywhere but on the dash.
'75 240D 4-Speed
Syncro_G
This might work.
'75 240D 4-Speed
SurfRodder
Jackass Extraordinaire
611
01-30-2010, 04:36 AM #11
Have you thought about a "serial" gage... those take many inputs and cycle through them. They are all digital, but it meets the one gage requirement. They are pretty cool and can be programmed to cycle through all the inputs and flash to a particular reading if/when a setpoint is met.
popular brands are AEM and defi... although I think autometer has one too. I wouldnt be surprised if VDO makes one.
OBK# 62
SurfRodder
OBK# 62
JTY
01-30-2010, 05:02 PM #12
It's my supermeter project. I do custom setups for sale with different specs some with larger display, some with small display, also many pressure sensors are supported, with egt or without, single afr and dual afr for V-engines.
Here's my supermeter info page:
http://oh1jty.toimii.net/supermeter/
Supermeter setup running in nissan skyline (customers):
[Image: p1030485.jpg]
Some more photos
- MB r129 500SL AMG (JDM) -94
- MB w123 250E-TT (JDM) -85
JTY
Some more photos
gvp
01-30-2010, 05:46 PM #13
Quote:It's my supermeter project. I do custom setups for sale with different specs some with larger display, some with small display, also many pressure sensors are supported, with egt or without, single afr and dual afr for V-engines.
Could you tell us more details about your system...Does it works also at cars without obd2 etc...???[/quote]
gvp
Syncro_G
0-60 in 29 sec
280
01-31-2010, 10:49 AM #14
(01-30-2010, 05:02 PM)JTY It's my supermeter project. I do custom setups for sale with different specs some with larger display, some with small display, also many pressure sensors are supported, with egt or without, single afr and dual afr for V-engines.
this looks interesting! I have a little matrix of warning lights in the middle of my gauge cluster. If I were able to Relocate them or reproduce their functions, I could put an LCD screen there (like the later model G-wagens have)
hazard/ turn signal
front locker engaged
rear locker engaged
(and a planned aux fuel filter pressure)
'75 240D 4-Speed
Syncro_G
hazard/ turn signal
rear locker engaged
'75 240D 4-Speed
Syncro_G
0-60 in 29 sec
280
02-03-2010, 02:46 AM #15
Just found a BD X-monitor for less than 1/2 what everyone else was selling it for so I bought it. (fingers crossed)
it's one that comes with a dodge ram pillar mount. I'll either cut that up for my use or come up with some new mount.
'75 240D 4-Speed
Syncro_G
'75 240D 4-Speed
offroadbakos
02-03-2010, 03:06 AM #16
sorry for the huge pic ConfusedConfused
so left of the dash EGT and on the right BOOST ,VOLTOMETER and oil pressure
so left of the dash EGT and on the right BOOST ,VOLTOMETER and oil pressure !!
ps : if somebody tells me the correct image size i know for next time
and the left of the triple gauge pod is the famous Frappe we Greeks can't do without
This post was last modified: 02-03-2010, 03:13 AM by offroadbakos.
offroadbakos
gvp
02-03-2010, 08:52 AM #17
Quote:Just found a BD X-monitor for less than 1/2 what everyone else was selling it for so I bought it. (fingers crossed)
This is a universal monitor system as i understood,right??Isn't necessary the Ecu...
gvp
Syncro_G
0-60 in 29 sec
280
02-03-2010, 10:58 AM #18
(02-03-2010, 08:52 AM)gvp This is a universal monitor system as i understood,right??Isn't necessary the Ecu...
mostly. Boost and EGT are universal (come with senders) while the optional third input can be configured to receive an add on module or tap directly into one of several Detroit wire harnesses. I'm going to call today to see if I can hook up a vdo oil pressure sender to it (gwagen doesn't have a gauge like the w123 does)
'75 240D 4-Speed
Syncro_G
'75 240D 4-Speed
gvp
02-03-2010, 11:35 AM #19
Ok!!Let me know....thanks!
gvp
Syncro_G
0-60 in 29 sec
280
02-04-2010, 12:21 AM #20
(02-03-2010, 11:35 AM)gvp Ok!!Let me know....thanks!
I talked to Chris at BD
Out of the box, the gauge kit will do Boost and EGT.
With an add on kit, you can choose one of the following:
1080120 X-Monitor Remote Temp Kit - 1/8npt Sender
1080125 X-Monitor Remote Temp Kit - Dodge
1080135 X-Monitor Brake Pressure Kit - Dodge
1080156 X-Monitor Fuel Pressure Kit - Dodge 98.5-07
1080160 X-Monitor Auxiliary Fuel Tank Level Interface Kit
1080127 X-Monitor Remote Temp Kit - Ford
1080126 X-Monitor Remote Temp Kit - Chev Duramax
1080136 X-Monitor Brake Pressure Kit - Duramax
As you can see - most options are tailored to detroit diesels.
'75 240D 4-Speed
Syncro_G
'75 240D 4-Speed
gvp
02-06-2010, 08:51 AM #21
Thanks for the reply,i prefer the dakota digital gauges as i ll build my own dashboard.....
gvp
12-02-2012, 11:14 PM #22
I went ape on this topic for while. I spoke with a tuner friend of mine, told him what I wanted to do, he gave me zietronix, I called and spoke with them. They could do some of what I wanted, but thier were all geared toward a gasser so I would always have a channel wasted on AFR. I found a really cool DIY and another company who CAN make you exactly what you want...yes you have to use their sensors and no you can add on later as the controller box for the LED panel would need not only a firmware upgrade but also a port to accommodate your new sensor input. Duh. But it looks like a pretty good cost / value ratio considering the options. I was going to and still might put energy into making one...I've got a couple of bud's who's handy w computers Wink anyway http://zada-tech.com/ seems like the cats pajamas so far on this topic
-1982 300SD, found out she has an '85 Engine, unknown mileage, redoing the top end and chain, head has been ported and polished, non EGR manifolds / non ARV turbo
-1982 300D, too many issues to list.
-Alt Fuel Buff
-Founder www.SWFLBenzCLub.com
SpecialDelivery
-Alt Fuel Buff
Jambo
12-03-2012, 06:29 AM #23
I use this one in my G and am very happy with it.
Its the MadDog EMS1.
http://www.landyonlineretail.co.za/shop/...gory_id=24
Jambo
 12 Guest(s)
 12 Guest(s)
