STD Tuning Engine injector nozzle question
btrapr
03-07-2010, 10:54 PM #1
I know I have seen some posts where VW injectors were used...
My question is do the VW nozzles themselvs for like a 1.6 or 1.9 diesel?
I have seen these listed for VW
The DN0SD265 nozzle
I thought I might be able to use these in my Mercedes 617?
I also saw some posts about the 240 nozzles
Does anyone have a source for these?
*How would you rate the Monark nozzles against these?
thanks
in Advance
btrapr
The DN0SD265 nozzle
thanks
in Advance
03-07-2010, 11:02 PM #2
DN0SD265 is an MB nozzle used in OM601/2/3 engines, not VW.
240/ nozzles are technically better in the 61x engines, but the prespray hole clogs easily.
There is no significant advantage to using either except quieter idle with the 240/ nozzles. Injectors are not a limitation on IDI engines like they are DI engines since there are no orifice holes to inject through.
The VW parts used are just the 2-stage injector bodies themselves, MB nozzles were installed.
This post was last modified: 03-07-2010, 11:08 PM by ForcedInduction.
btrapr
03-08-2010, 10:12 AM #3
[b]Thanks ForcedInductionSmile!
I thought that was true about the 265's but I found a guy that has them but he listed them for VW...
I have a set of Monarks in the wagon and they seem to work well...got a set of 240's out of the wagon that look pretty good just not sure how to really check them...I thought about putting the 240's in my 240D...
*I have two of those early 5cyl n/a manifolds on the way. I want to add some items to my 300SD...the others one will be going into my 240d 4spd manual car when I put a 617turbo in it...
This post was last modified: 03-08-2010, 10:15 AM by btrapr.
btrapr
Alastair E
Moderator?--Nah...
266
03-08-2010, 03:22 PM #4
The below list of nozzles have been used in OM.61x engines...
DNOSD1510
DNOSD220
DNOSD240
DNOSD240/A
DNOSD261
DNOSD265
There may be others, but those above I have confirmed and have been seen...
Alastair E
DNOSD1510
DNOSD220
DNOSD240
DNOSD240/A
DNOSD261
DNOSD265
03-08-2010, 03:44 PM #5
(03-08-2010, 10:12 AM)btrapr I thought about putting the 240's in my 240D.
It should have them from the factory.
