timing IP, which tool is better?
I used both recently. I much preferred the RIV tool (one that screws into the side). It gives you unambiguous results and is really accurate but it's also very expensive (over $500) compared to a drip tube made from a surplus injector line ($0).
the RIV is easy to use - hook it up to the battery and plug the socket into the port on the IP (I think it has to be a late model 617 MW IP).
set the crank shaft to where you want it.
loosen the IP and injector lines
rotate the IP slowly and watch the LED's.
they'll blip when the IP passes through the correct rotation point.
tighten the IP and injector lines
(03-12-2010, 02:28 AM)Syncro_G I used both recently. I much preferred the RIV tool (one that screws into the side). It gives you unambiguous results and is really accurate but it's also very expensive (over $500) compared to a drip tube made from a surplus injector line ($0).
Locks the pump cam in place so it doesn't rotate during installation.
(03-12-2010, 07:29 AM)ForcedInduction Locks the pump cam in place so it doesn't rotate during installation.
Since this is a "use once every 25 years" kind of tool, wouldn't someone offer a rental service? Something like $250 shipped and when you return it within 30 days you're refunded $210 or something. Just a thought.
Just open the RIV port and use a dental mirror to get the tang in the middle. Of course this only works with newer (RIV capable) MW pumps and IIRC all M pumps. According to Dave (iirc) this is quite doable.
