STD Other FS / WTB / Buying guides Selling my old turbo - SOLD
Rudolf_Diesel
Ask me if I care...
04-12-2010, 07:51 PM #1
I am selling the following as a kit:
  • T3/T4OE Hybrid Turbo with internal wastegate
  • Non-EGR exhaust manifold coated with high temp Techline coating
  • W115 Intake Manifold
  • 3" 90 deg aluminum intake tube with bung for PCV
  • Aluminum air dam to isolate air filter from engine compartment
  • AEM dry air filter
  • Exhaust outlet from turbo to directly bolt to your down pipe
  • Silicone hose from turbo to intake manifold.
You can use the stock oil feed, but you will have to rig your own oil outlet.
You will also need a simple manual boost controller, really cheap on ebay.
I have been using this turbo for about 9 months and have had NO problems since the intial installation. I am peaking at 17 lbs of boost with my MW-pump and the rack removed. I am not running an intercooler right now and regularly drive it like I stole it and have not seen the EGR get past 1050 climbing a good sized hill.
I am asking $450.00 plus shipping, I have an account with FEDEX so I can get a better rate, it is ready to bolt on and drive.
This post was last modified: 04-12-2010, 09:50 PM by Rudolf_Diesel.
Rudolf_Diesel
04-12-2010, 08:09 PM #2
Pm sent
Pm sent
Rudolf_Diesel
Ask me if I care...
04-12-2010, 08:09 PM #3
To the one that PMd me, I cannot send you a message - box is full? You are first on the list!
This post was last modified: 04-12-2010, 08:12 PM by Rudolf_Diesel.
Rudolf_Diesel
04-12-2010, 08:22 PM #4
(04-12-2010, 08:09 PM)Rudolf_Diesel To the one that PMd me, I cannot send you a message - box is full? You are first on the list!
Cool! I sent an email this time using the email thing on the forum, hopefully that works
EDIT- It did not work, returned to sender. Can you email me outside of the forum at dropnosky@ hotmail dot com? Then I can email you back
This post was last modified: 04-12-2010, 08:25 PM by JB3.
Rudolf_Diesel
Ask me if I care...
04-12-2010, 08:28 PM #5
(04-12-2010, 08:22 PM)dropnosky
I tried to change my email, but the stupid forum wouldn't change it. email sent
Rudolf_Diesel
Rudolf_Diesel
Ask me if I care...
04-12-2010, 09:32 PM #6
SOLD
Rudolf_Diesel
SOLD
04-12-2010, 10:43 PM #7
Good to see the setup will live again. Big Grin
 7 Guest(s)
 7 Guest(s)
