STD Other Projects MB 300SD oldtimer
MB 300SD oldtimer
MB 300SD oldtimer
  • 4 Vote(s) - 3 Average
jeemu
457
04-15-2010, 04:35 PM #51
(04-15-2010, 03:34 PM)Tymbrymi Has anyone done any work with the electronic pumps yet? I think that would make a huge difference in what you dyno graphs would look like
Here is some electronic pump made at 7mm, but those are low emission cars, so those had tune smokeless and not that big turbo, there for no that much power as mechanical pumps can give.
We get new dyno in Kalajoki where i go dyno my car. Then we get double mass on rolls. So turbo spools earlier and dyno graph looks much nicer.
And bt the way.
Sorry JTY your awesome topic goes off topic.
This post was last modified: 04-15-2010, 04:37 PM by jeemu.
jeemu
And bt the way.
Tymbrymi
Klatta Klatta
185
04-15-2010, 04:52 PM #52
(04-15-2010, 04:00 PM)antonmies Actually they do these days. If you go and see a newer more emission controlled diesel engine, you will see a wideband sensor in the exhaust manifold and sometimes also after the cat converter.
I was really skeptical about these super rich fuel ratios, etc. since they don't make any sense compared to anything I've read so far, but I remembered that my CDI has a wideband O2 sensor on it!! It can measure a lambda from .7 to 4.0 (10.3:1 to 59:1). The crazy thing is it is mounted almost exactly at the turbo outlet.... so it is exposed to some pretty sooty exhaust. Admittedly, not as sooty as these performance cars, but it is definitely able to withstand "normal" use of a diesel. Exclamation
(04-15-2010, 04:35 PM)jeemu Here is some electronic pump made at 7mm, but those are low emission cars, so those had tune smokeless and not that big turbo, there for no that much power as mechanical pumps can give.
It isn't the pump that's limiting power, it is the tune right? You could take one of the electronic pumps, put your elements in it, and tune it to make the HP you are correct?
(04-15-2010, 04:35 PM)jeemu We get new dyno in Kalajoki where i go dyno my car. Then we get double mass on rolls. So turbo spools earlier and dyno graph looks much nicer.
What is the mass of the rollers? Does it match the weight of your car?
John Robbins
Tymbrymi
John Robbins
jeemu
457
04-15-2010, 05:28 PM #53
(04-15-2010, 04:52 PM)Tymbrymi It isn't the pump that's limiting power, it is the tune right? You could take one of the electronic pumps, put your elements in it, and tune it to make the HP you are correct?
Like i say. Those are low emission cars and those cant put that big turbo as these old piece of shit. Actually those cars cant change at all if goes right at the law says. another thin is money. Electronic pump at 7mm and tuned software cost more than mechanical pump.
(04-15-2010, 04:52 PM)Tymbrymi What is the mass of the rollers? Does it match the weight of your car?
These what i dynod dont weight that much as my car.
jeemu
JTY
04-16-2010, 05:50 AM #54
Jenkki enjoying "warm" spring weather Confused
[Image: jenkki-ulko-uusi1.jpg]
[Image: jenkki-ulko-uusi2.jpg]
Jeemu: no problem, it's okay to go offtopic sometimes Smile
(04-15-2010, 07:19 PM)GREASY_BEAST
(04-15-2010, 05:28 PM)jeemu Electronic pump at 7mm and tuned software cost more than mechanical pump.
If we can DIY the software, it should cost quite a lot less than a mechanical pump. All the shop has to do is install and balance the elements. Governor is all software, should be able to be tuned with a laptop and a chip programmer.
Still you need some cash to get the pump and new parts + service for it.
Software is not the problem or the controller, not for me.
I usually go with the parts i have and improvise as i go. Still if i were building new a setup i would go directly with CDI engine, skipping om60x engines all together. New MB CDI engines are strong and easy to tune.
This post was last modified: 07-14-2012, 04:49 PM by aaa.
- MB r129 500SL AMG (JDM) -94
- MB w123 250E-TT (JDM) -85
JTY
jeemu
457
04-16-2010, 05:04 PM #55
I can imagine face of a driver who is front of you and he look at back mirror and see that BIG Mercedes Big Grin
jeemu
antonmies
Go MPR
59
04-17-2010, 04:12 AM #56
(04-16-2010, 05:04 PM)jeemu I can imagine face of a driver who is front of you and he look at back mirror and see that BIG Mercedes Big Grin
If the driver was a tourist he would most probably think that "Man they really drive old pieces of shits back here" Big Grin
This post was last modified: 04-17-2010, 04:12 AM by antonmies.
antonmies
jeemu
457
04-17-2010, 01:25 PM #57
(04-17-2010, 04:12 AM)antonmies
Thats true Smile
jeemu
Thats true Smile
JTY
04-18-2010, 12:50 PM #58
So true Confused
JTY
So true Confused
04-19-2010, 02:49 PM #59
I hate clear lights usually but something about that body color makes them look really good with those rims!
Tymbrymi
Klatta Klatta
185
05-04-2010, 02:42 PM #60
How goes the car progress? Enjoying the car in the nice warm weather? Angel
John Robbins
Tymbrymi
John Robbins
jeemu
457
05-05-2010, 07:40 AM #61
(05-04-2010, 02:42 PM)Tymbrymi Enjoying the car in the nice warm weather? Angel
OT: Here is cold as hell Undecided
jeemu
JTY
05-09-2010, 05:28 AM #62
(05-05-2010, 07:40 AM)jeemu
Yes VERY cold weather, still waiting for the spring Sad
Been driving with the car some bit, it's been a blast to drive. Still needs some tuning on timing, have tried several settings to get best results.
Currently having problems with one injector and "minor" oil leak. Oilpan got an hit from "speed bump" Undecided
When those are fixed it's time to go on dyno.
JTY
rdirtycar
flash gordon
145
06-05-2010, 09:31 PM #63
this is the best thread I've read on this forum yet. you have the funny foreign guy with the secret cylinder head. you have the American yelling at him cause there is some secret s... they're keeping from us over there in Europe. JTY and his textual accent and his avatar. JTY has to be some Californian ex pat living in sweden like a pig in west German s... laughing at us cause he lives in the land of make believe now. LETS ALL STAND AND TOAST TO THE SD THAT HAS BEEN VERY LUCKY TO MEET ITS LAST OWNER!! cheers and I wish I lived in Europe again.
and he has naturally aspirated under his name like mine which is from my 85 ford f350 not with us anymore.
This post was last modified: 06-05-2010, 09:33 PM by rdirtycar.
rdirtycar
JTY
06-06-2010, 04:42 AM #64
(06-05-2010, 09:31 PM)rdirtycar this is the best thread I've read on this forum yet. you have the funny foreign guy with the secret cylinder head. you have the American yelling at him cause there is some secret s... they're keeping from us over there in Europe. JTY and his textual accent and his avatar. JTY has to be some Californian ex pat living in sweden like a pig in west German s... laughing at us cause he lives in the land of make believe now. LETS ALL STAND AND TOAST TO THE SD THAT HAS BEEN VERY LUCKY TO MEET ITS LAST OWNER!! cheers and I wish I lived in Europe again.
I lolled Big Grin
Has been little busy on work side, but managed to install LSD on the diff last week and made some modification to wastegate side and exhaust.
Here's some youtube video, first is older from April side doing some tuning and second one from yesterday when i tried new modifications on closed road (video stopped too early):
MB 300SD tuning
MB 300SD testing
This post was last modified: 06-06-2010, 04:50 AM by JTY.
JTY
I lolled Big Grin
MB 300SD tuning
MB 300SD testing
06-06-2010, 11:55 AM #65
Is your speedo in mph or kph?
JTY
06-06-2010, 04:23 PM #66
(06-06-2010, 11:55 AM)willbhere4u Is your speedo in mph or kph?
300SD import from california so yes speedo is mph Confused
JTY
06-06-2010, 10:15 PM #67
Then that's damn quick!
JTY
06-07-2010, 09:17 AM #68
(06-06-2010, 10:15 PM)willbhere4u Then that's damn quick!
It feels nice on highway speeds, no problems to keep in pace with others Tongue
JTY
06-11-2010, 01:13 AM #69
Where did you mount the first inter cooler before the engine rebuild? I just got the exact same one for free and was wondering if I could make it work on my '82 with too much cutting.. I can kind of see it through the top of the bumper but Iwas wondering if you had any more install pics of it?
The one I ave Measures 21.5"L x 2.5"w x 5.5"t
This post was last modified: 06-11-2010, 01:28 AM by Captain America.
JTY
06-11-2010, 07:02 AM #70
(06-11-2010, 01:13 AM)Captain America Where did you mount the first inter cooler before the engine rebuild? I just got the exact same one for free and was wondering if I could make it work on my '82 with too much cutting.. I can kind of see it through the top of the bumper but Iwas wondering if you had any more install pics of it?
All intercooler installation pics are on first page.
There was no cutting involved, just install brackets for the cooler, it all fits behind front bumper Smile
JTY
06-11-2010, 01:51 PM #71
Nice. I don't think I could make it fit as nicely as yours though. the SD bumper is definitely tons different than a regular D bumper. Mine looks like it belongs on a tank lol
JTY
06-11-2010, 08:59 PM #72
(06-11-2010, 01:51 PM)Captain America Nice. I don't think I could make it fit as nicely as yours though. the SD bumper is definitely tons different than a regular D bumper. Mine looks like it belongs on a tank lol
lol Big Grin
JTY
lol Big Grin
JTY
06-13-2010, 04:56 AM #73
Some update, I installed a LSD unit in the diff
Few shots of the LSD unit:
[Image: p1040914.jpg]
[Image: p1040928.jpg]
Empty diff case
[Image: p1040932.jpg]
Looks good
[Image: p1040933.jpg]
Middle shaft seems to be in good shape
[Image: p1040934.jpg]
Spiders are pretty bad :roll:
[Image: p1040935.jpg]
LSD unit installed
[Image: p1040937.jpg]
Gear ratio
It's no much more fun to drive and it's very stable when you do an fast launch.
JTY
Empty diff case
Looks good
LSD unit installed
Gear ratio
06-13-2010, 07:10 PM #74
that's a neat little set up whats something like that run?
06-14-2010, 02:03 PM #75
I've heard these solutions don't last long, will be interested to hear about lognevity. They are what $200 or so USD? I still have no clue how this works.
06-14-2010, 02:50 PM #76
Oh it's good! DID chains are the shit!
Tymbrymi
Klatta Klatta
185
06-14-2010, 04:40 PM #77
(06-14-2010, 02:03 PM)winmutt I've heard these solutions don't last long, will be interested to hear about lognevity.
I'm sure it depends on how much you use it. Angel Also, the clutches in a normal LSD don't exactly last a really long time either.
John Robbins
Tymbrymi
John Robbins
JTY
07-18-2010, 06:13 PM #78
Okay some minor updates.
Made an hybrid steering box from 123 worm gear, steering ration now little faster.
Also installed water injection setup last week, made some trial runs yesterday and blew one boost pipe Wink
Seems to work as planned, EGT are way lower and now the rear end has some problems to keep up Big Grin
Pics coming soon
Also need bigger pump for MOAR fuel!
This post was last modified: 07-18-2010, 06:25 PM by JTY.
JTY
Pics coming soon
JTY
07-22-2010, 05:44 AM #79
Here's pics:
[Image: water1.jpg]
[Image: water3.jpg]
This post was last modified: 07-14-2012, 04:50 PM by aaa.
JTY
Here's pics:
[Image: water1.jpg]
[Image: water3.jpg]
07-22-2010, 02:16 PM #80
Got some JB on there Huh?
07-22-2010, 03:32 PM #81
If it works it works. Paint it with the pipe and it wouldn't look much different than a bung weld.
JTY
07-22-2010, 05:01 PM #82
(07-22-2010, 02:16 PM)Captain America Got some JB on there Huh?
JB ?
It's threaded to the pipe with some hydralic glue in the threads.
Very secure and will hold Smile
JTY
JB ?
07-22-2010, 05:34 PM #83
Ok I see. I was asking because usually those brass fitting are NPT and I just use a little lock tight then wipe off the excess.
07-22-2010, 07:28 PM #84
(JB weld) It's a glue that hardens like plastic we use it over here in the US
Rudolf_Diesel
Ask me if I care...
07-22-2010, 10:41 PM #85
(07-22-2010, 07:28 PM)willbhere4u (JB weld) It's a glue that hardens like plastic we use it over here in the US
A two-part epoxy to be more specific, I have used similar for some repairs. Many have used for permanent repairs with good results. We use a two part that is a putty that my brother and I call "Magic Booger". You tear a piece off and knead it to a uniform color - smells like ass thoughBig Grin It has some sulfur or something nasty in it but it works!
This post was last modified: 07-22-2010, 10:43 PM by Rudolf_Diesel.
Rudolf_Diesel
07-22-2010, 11:47 PM #86
I use Locktite #246 to seal all NPT fittings. It is quite fantastic actually, more of a sealer in my book than a thread locker. Plus it is oil resistant! Its a darker blue and thicker than your standard #242 stuff.
Well it still locks the threads.... just not permanently.
This post was last modified: 07-22-2010, 11:47 PM by Captain America.
JTY
09-08-2010, 12:39 PM #87
Small updates nothing new really.
Have been driving alot, changed to ethanol/water mixture, much better response now.
Also started installing NOS kit.
Pics later on.
JTY
Pics later on.
Riverstick
12-26-2010, 12:34 PM #88
Really really enjoyed reading this thread.....so good in fact I had to go back and read most of it twice!....top class job,very professional and well executed.....it's just what this site is all about....someone applying modern technology to older cars and achieving spectacular results...would love to rebuild a car like that. As a matter of interest JTY.....any idea of power and torque outputs?
Riverstick
Diesel-Wiking
12-26-2010, 12:56 PM #89
estonishing, briliant! That is just a perfect S-class after you lowered it and mounted those lorinser-wheels, the motor is also the right one, love it!
*1984 Mercedes S123 300TD turbodiesel*
*1993 BMW 525tdsT*
*1990 BMW 524 turbodiesel*
*1983 BMW 745iA e23*
*1969 BMW 3.0csl racecar*
Diesel-Wiking
*1993 BMW 525tdsT*
JTY
07-10-2012, 03:35 PM #90
"There was an error performing the update.
You can only edit messages for 14400 minutes after they were posted."
That's pretty rough from the Admins.
I would like to fix the picture urls, nothing else.
JTY
07-10-2012, 04:05 PM #91
You can thank our buddy ForcedInduction for that one
JTY
07-11-2012, 04:30 PM #92
THANK YOU FORCEDINDUCTION!! Big Grin
JTY
07-11-2012, 05:17 PM #93
(07-10-2012, 03:35 PM)JTY "There was an error performing the update.
pm aaa or winmutt, maybe they can help get the urls changed. would be nice to see what you did again! Big Grin
JTY
07-15-2012, 11:32 AM #94
Let's bump this project with some external photos Smile
These are from Summer 2011:
[Image: mese1.jpg]
[Image: mese2.jpg]
And some rear shots from today:
[Image: mese-ulko1.jpg][Image: mese-ulko2.jpg]
Why not post some internal shots also Big Grin
[Image: mese-sisa3.jpg]
[Image: mese-sisa4.jpg]
Brabus suspension from the 80's was spot on, the stance is just perfect for the w126 chassis.
The car is still in everyday drive, same configuration, runs strong and is still fast. Big Grin
JTY
[Image: mese1.jpg]
[Image: mese2.jpg]
Austincarnut
07-15-2012, 11:46 AM #95
Hey forced do you use a controller on your GT2359V? or do you have a linkage to control the vanes?
Austincarnut
w123love
Stockish
354
07-16-2012, 12:49 AM #96
(07-15-2012, 11:46 AM)Austincarnut Hey forced do you use a controller on your GT2359V? or do you have a linkage to control the vanes?
Forced no longer exists on this hear forum. But the answer to your question is somewhere in this site.
The VEGEWGN
w123love
The VEGEWGN
Secondaries
07-18-2012, 03:59 PM #97
How is that fake LSD holding up? If you're using the car much I'd pull the diff cover off and inspect your spider gears. Truth is, that style "LSD" (AKA Phantom Grip, AKA Phantom Slip) is actually a bad and incomplete copy of another, better LSD add-on. There are supposed to be clutches between the sprung plates and spider gears. Instead, those plates wear directly on the spiders to limit slip. Which is bad, m'kay?
Other than that, your car is awesome and you are awesome! Thanks for the inspiration!
1984 Mercedes-Benz 300TD Turbo - 260k miles - Daily driver
1982 Yamaha XV920RJ - 9k miles - Currently in pieces
I have valve wrenches and timing tools for rent! PM for details!
Secondaries
JTY
07-19-2012, 01:51 AM #98
(07-18-2012, 03:59 PM)Secondaries How is that fake LSD holding up? If you're using the car much I'd pull the diff cover off and inspect your spider gears. Truth is, that style "LSD" (AKA Phantom Grip, AKA Phantom Slip) is actually a bad and incomplete copy of another, better LSD add-on. There are supposed to be clutches between the sprung plates and spider gears. Instead, those plates wear directly on the spiders to limit slip. Which is bad, m'kay?
Yes i know that, it's not the most optimal solution but currently the best before i can get me an 1st series LSD diff. So it really doesn't matter if it eats the spider gears. I installed the "softer" version of the lock which have finer machining so it will not eat metal so fast but it also holds less.
I'm using performance grade diff oil 90W-145 and that have also made difference, i also change the oil quite frequently and so far there has been minimal metal in the oil.
Thanks, let's keep these oldies in the pace of progression Smile
JTY
07-21-2012, 06:09 PM #99
I though LSD was a psychedelic drug??
JTY
07-22-2012, 08:45 AM #100
(07-21-2012, 06:09 PM)sassparilla_kid I though LSD was a psychedelic drug??
Maybe it is and this 300sd project is just my imagination Big Grin
I'm sooo high Big Grin
I just uploaded a video.
New tune in the pump and some exhaust sound Big Grin
This post was last modified: 07-22-2012, 08:47 AM by JTY.
JTY
 68 Guest(s)
 68 Guest(s)
