STD Maintenance General 140 Diesel
140 Diesel
140 Diesel
Morro Man
05-10-2010, 12:14 AM #1
Can I bypass the computer controls on my 1993 140 diesel? I have blocked open the fresh air intake and plugged the EGR but the computer is still controlling the mixture and I assume turbo boost pressure. I have the original trap oxidizer at 150,000 miles and I considering the removal as I assume it would run better without it. I also wonder if there is any way to rig up a boost contoller set on intake pressure versus the computer to get more power.
Morro Man
05-10-2010, 12:32 AM #2
Replace the vacuum wastegate with a traditional pressure wastegate and the computer will no longer have any control over power.
Morro Man
05-10-2010, 04:39 PM #3
(05-10-2010, 12:32 AM)ForcedInduction Replace the vacuum wastegate with a traditional pressure wastegate and the computer will no longer have any control over power.
Do you have a reccomeded source for the traditional wastegate?
Morro Man
05-11-2010, 01:35 AM #4
From an 86/87 300D or 300SDL.
jagoras
05-26-2010, 09:33 PM #5
would that also work on w124 2.5 turbo?
jagoras
