STD Tuning Engine w210 idle problems
w210 idle problems
w210 idle problems
jagoras
05-12-2010, 10:20 AM #1
my mom has a 1998 e300 turbodiesel, the car looks and runs amazing, but when you put the car in neutral or in park it starts shaking, almost like the injectors are clogged. when the car is in drive there is no sign of this, the car does this when it's warm as well, so it has nothing to do with the car being cold. Has anybody come across this problem, or does anybody have an answer for this?
jagoras
Jtn190D
MERCEDES DIESEL POWER!
192
05-12-2010, 11:21 AM #2
My car is doing the same thing and i don't know why. Any answers will be great!!
Justin.
Jtn190D
Justin.
Tymbrymi
Klatta Klatta
185
05-12-2010, 01:45 PM #3
(05-12-2010, 10:20 AM)jagoras when you put the car in neutral or in park it starts shaking
Does it get worse when it is in reverse? The first thing that comes to mind is motor mounts...
John Robbins
Tymbrymi
John Robbins
jagoras
05-12-2010, 04:24 PM #4
(05-12-2010, 01:45 PM)Tymbrymi
no. it doesn't, it just started...and if it was motor mounts, it would be doing this constantly, and it would bang real hard while shifting into gears. i feel it's somehow related to fuel air ratio, but i can't put my finger on it.
jagoras
E300TSC
Turbo-Supercharged
321
05-12-2010, 07:46 PM #5
My first thought is mounts as well. The mounts on this car are liquid filled and if the bladder ruptures, it can get real bad instantly. My car was shaking through to the very chassis when I bought it and new mounts solved the problem immediately.
E300TSC
jagoras
05-12-2010, 08:35 PM #6
(05-12-2010, 07:46 PM)E300TSC My first thought is mounts as well. The mounts on this car are liquid filled and if the bladder ruptures, it can get real bad instantly. My car was shaking through to the very chassis when I bought it and new mounts solved the problem immediately.
the thing is that it only happens sometimes when the car is in neutral or in park. i drove it all day yesterday and it didn't happen once....i drove it last week and it did it to me once while i parked the car. it seems like its misfires likea gas car does. it's really strange.
jagoras
MB TECH
05-13-2010, 10:01 AM #7
I know I have ran into this before, but of course I cant remember what the fix was. I agree first check the motor mounts AND transmission mount, if you have more than 120k and they are original it might just be a good idea to replace all 3. The only other thing I can think of that would give you a rough idle (intermittently) and no check engine light, are the flaps inside the intake manifold are gummed up and sometimes getting stuck.
If something else comes to mind I will get back to you.
1979 450SEL 6.9 - stock
1960 220SE
2005 S55 AMG - stock
2006 SLK55 AMG - stock
MB TECH
1960 220SE
Tymbrymi
Klatta Klatta
185
05-13-2010, 10:28 AM #8
Check and see if there are ANY diesel leaks around the injection pump. It could very well be air getting into the fuel lines or the delivery valves leaking.
John Robbins
Tymbrymi
John Robbins
jagoras
05-14-2010, 10:00 PM #9
(05-13-2010, 10:28 AM)Tymbrymi Check and see if there are ANY diesel leaks around the injection pump. It could very well be air getting into the fuel lines or the delivery valves leaking.
i did fail to mention that this started happenning after my dad replaced the fuel filters. we did see some bubbles in the air lines, but they went away after a while. i guess there is no way to manually pump the air in the lines. we assumed that there might be some garbage and air in the lines, and that the shaking and vibration would eventually go away....but here i am trying to get some answers from you guys.
jagoras
E300TSC
Turbo-Supercharged
321
05-15-2010, 08:17 AM #10
OK, that's good info. One odd thing about the pre-filter is that most often, it does not come with a lower O-ring. Many people don't notice this and reassemble it with the ring missing which makes it nearly impossible to start and if started, it may run poorly at times.
E300TSC
jagoras
05-16-2010, 09:36 PM #11
i'll look into that....that's something that might be a possibility. thanks for your help.
jagoras
 14 Guest(s)
 14 Guest(s)
