617.952 Wont start
617.952 Wont start
I am just trying to get my project running again tonight and I cannot get the !@#!$ engine to start! I have done a valve adjust and I have had the IP pump off. I timed the IP pump twice (drip method in fsm) and came up with the same result both times. glow plugs are working great as well... all i get is black smoke and the smell of diesel while cranking.... I am out of ideas. please help!
You sure the IP is installed on the compression stroke instead of exhaust?
disconnect the glow plugs!!!! and give it a tiny kick with a bit of either just a touch while cranking! see if that helps
(05-17-2010, 11:02 PM)willbhere4u disconnect the glow plugs!!!! and give it a tiny kick with a bit of either just a touch while cranking! see if that helps
(05-18-2010, 07:00 AM)617.952 change the fuel filter
Pull your starter motor apart, clean up the comm and the brushes. If it doesn't start, blow it up. The starter motor was my problem. Another thing, the negative battery terminal cable that mounts directly to the body, pull it off, and clean the body and the eyelet. We found that it was losing power at that junction.
