STD Other Projects New to mercedes
New to mercedes
New to mercedes
JR66Ford
06-23-2010, 11:23 PM #1
Hello, I am new to Mercedes. I just bought an '83 300td wagon. I love it, but it's a slug. I intend to browse around on here and see what I can do to wake this car up. If I could be pointed in the right direction, that would help.
Thanks
Jason
Uhh, sorry about the large photo. I thought it would size it accordingly, guess I need to adjust it
This post was last modified: 06-23-2010, 11:25 PM by JR66Ford.
JR66Ford
Thanks
Jason
06-24-2010, 11:32 AM #2
Nice wagon first thing I would do is replace both of the fuel filters and the air filter and adjusts the ALDA for a little more off the line TQ
JR66Ford
06-24-2010, 06:47 PM #3
(06-24-2010, 11:32 AM)willbhere4u Nice wagon first thing I would do is replace both of the fuel filters and the air filter and adjusts the ALDA for a little more off the line TQ
What's the ALDA and how do I adjust it? Told you I was new to these. Anywhere I can go to learn mercedes diesels for dummys?
JR66Ford
06-27-2010, 09:16 AM #4
Heh try the other forums, benzworld.org and peachparts.com
06-27-2010, 12:19 PM #5
It's the square box on top of the Injection pump! It has screw and a nut on it if you loosen the nut and back the screw out and lock the nut back down it will give it a bit more fuel off the line!
85-300Dt
06-27-2010, 06:02 PM #6
Check the play in the throttle linkages, when I got my car had to press the pedal ~ halfway before it had some effect. Tightened up all the rods just by eyeballing & then practically felt like a completely diff beast. However, did read later in the FSM of an elaborate method involved in proper adjustments with some warnings of doing it right.
85-300Dt
