STD Tuning Engine Om601 IP tuning
Om601 IP tuning
Om601 IP tuning
SicNick
07-19-2010, 12:34 AM #1
So I've been searching here and other forums for the last couple days. I just completed a project adding a turbo to a low mileage 84 190d with the 2.2 OM601. It was sourced from a mitsubishi mighty max 2.3 turbo diesel so the sizing so be appropriate for a slight power gain. I'm not new to diesels, just the Mercedes IP. With the turbo and a custom free flowing intake, I can't get my egts above 400* on flat ground here at 5000ft elevation in fort Collins, CO and my probe is mounted pre turbo. I think it's time for some more fuel. I read the sticky above however it seems focused on the turbo IP and mine looks a little different. Any tips on turning her up a bit? Any worthwhile external adjustments like the turbos ALDA or my cummins VE pump? Also opinions on safe pressure to wastegate the turbo? I was thinking 6psi or so. TIA guys!
SicNick
07-19-2010, 06:42 AM #2
There are no external adjustments for yours. Follow the guide for the M-Pump.
SicNick
07-19-2010, 09:47 AM #3
(07-19-2010, 06:42 AM)ForcedInduction There are no external adjustments for yours. Follow the guide for the M-Pump.
Thanks for the reply, I'll see what I can do. Does the full fuel screw increase idle and result in runaway if turned to far up? Like on the VE on my cummins?
SicNick
Alastair E
Moderator?--Nah...
266
07-22-2010, 07:04 AM #4
(07-19-2010, 09:47 AM)SicNick
Yes to both questions!
The guide on the 'M' pump gives recommended adjustments....
Personally, from std. I would try 1.5 turns initially and see how you go...
[Image: 300TDnoplate.jpg]
Alastair E
07-22-2010, 03:31 PM #5
Yep. The coarse idle screw must be adjusted equally with the full load screw to maintain the stock speed.
