STD Maintenance General 617.952 short vs. long injector
rdirtycar
flash gordon
145
07-24-2010, 10:03 AM #1
When I was torquing the halves of an injector back together that looked like it could have been an original, it "creaked" as I tightened it and was hard to get a good torque setting on it. Now it's leaking from between the halves. It was also the only one I had to adjust the shims in and it gave me a hard time with that. I was surgical in my cleanliness and thoroughly lapped the sealing surfaces. I noticed it is shorter than most of the others. Is this an older design with a shorter spring/body? And does anyone have a spare injector body with an old nozzle or no nozzle they'd like to sell me?
rdirtycar
Rudolf_Diesel
Ask me if I care...
07-24-2010, 01:15 PM #2
(07-24-2010, 10:03 AM)rdirtycar When I was torquing the halves of an injector back together that looked like it could have been an original, it "creaked" as I tightened it and was hard to get a good torque setting on it. Now it's leaking from between the halves. It was also the only one I had to adjust the shims in and it gave me a hard time with that. I was surgical in my cleanliness and thoroughly lapped the sealing surfaces. I noticed it is shorter than most of the others. Is this an older design with a shorter spring/body? And does anyone have a spare injector body with an old nozzle or no nozzle they'd like to sell me?
I have a few, PM me your address and I will send you one.
Rudolf_Diesel
