STD Tuning Engine How can I improve exhaust until I get a full straight pipe?
jonbobshinigin
08-02-2010, 09:40 AM #1
I am looking to get a bit more flow and a little better tone until I put a 2.5"-3" on it at some point. What can I cut out and weld a pipe in place of? Cat? Resonator? Muffler?
Also, what size is the stock piping? I am not looking to get into a very detailed job, because at some point I am going to upgrade the turbo with a Euro 140 Manifold and completely redo it.
This post was last modified: 08-02-2010, 09:40 AM by jonbobshinigin.
1987 300TDT - 260,000 Miles
jonbobshinigin
08-02-2010, 09:47 AM #2
Yup all that you mentioned. Well there is no cat... and the pipe is 2.5" I believe. You can basically get a couple straight sections and weld them in for a couple bucks. Forced Induction did a writeup here: http://www.superturbodiesel.com/std/stra...t-625.html
The resonator and muffler are straight through anyway so there isn't much flow to be had by removing them...
Just don't dump it under the car... I will resonate so bad that you will be changing it back in about five seconds.
jonbobshinigin
08-02-2010, 10:21 AM #4
Ok...seems simple enough. I have access to welding and such. What would be an ideal setup where I can run a straight pipe for performance, but then swap out a muffler when I need a quieter ride?
My thinking it have a removable tip the length of rear muffler that clamps on. When necessary, I can drop the muffler in place of the straight pipe. Would this work?
Also, since the stock is 2.5", I may as well go ahead and run a 3" which will help once I get a larger turbo and tuned pump.
How complicated would things get if I ran a full 3" straight pipe NOW with stock turbo, and then modified it later when I added different exhaust manifold and turbo? Is there much modifying that would need to be done?
jonbobshinigin
08-02-2010, 10:55 AM #5
Quote:What would be an ideal setup where I can run a straight pipe for performance, but then swap out a muffler when I need a quieter ride?
Get a second exhaust system. Its only two bolts and four rubber hangers holding it in.
This post was last modified: 08-02-2010, 10:56 AM by ForcedInduction.
08-02-2010, 11:08 AM #6
(08-02-2010, 09:47 AM)Captain America Just don't dump it under the car... I will resonate so bad that you will be changing it back in about five seconds.
HAHA! yeah it is really bad...im still sticking it out with headaches and earplugs!
08-02-2010, 11:14 AM #7
The muffler is straight through. Just remove the resonator and that will remove 2 ~45* bends. I don't think there is much point to 3" unless you get a myna pump.
jonbobshinigin
08-02-2010, 11:16 AM #8
Eventually I will probably get a DervTuned pump with the Floyd 7.5s...in the meantime, what will change just by removing resonator and putting in a straight pipe in place? How much louder?
jonbobshinigin
08-02-2010, 12:07 PM #9
(08-02-2010, 11:08 AM)garage
lol that's funny. I can picture you in your car with ear muffs on!
08-02-2010, 12:08 PM #10
(08-02-2010, 12:07 PM)Captain America
Ha earmuffs with no AC in july, in socal....THATS FUNNY
(08-02-2010, 11:16 AM)jonbobshinigin Eventually I will probably get a DervTuned pump with the Floyd 7.5s...in the meantime, what will change just by removing resonator and putting in a straight pipe in place? How much louder?
It will be significantly louder.
Like a UPS truck..or garbage truck...ha, thats what people tell me when i pull up to there house.
This post was last modified: 08-02-2010, 12:10 PM by garage.
jonbobshinigin
08-02-2010, 02:26 PM #11
Even by leaving the rear muffler on and just deleting the resonator?
jonbobshinigin
08-02-2010, 02:36 PM #12
No, i thought you were talking about a straight pipe.
I belive the muffler would keep it pretty close to stock sounding..although im sure somone who has that setup can chime in.
jonbobshinigin
08-02-2010, 02:48 PM #13
So I wonder if there is any advantage to me just removing the Resonator and leaving Muffler. This is on my 1987 300TDT w/om603 BTW.
jonbobshinigin
08-02-2010, 05:26 PM #14
(08-02-2010, 02:48 PM)jonbobshinigin So I wonder if there is any advantage to me just removing the Resonator and leaving Muffler. This is on my 1987 300TDT w/om603 BTW.
Oh wow, well ive never heard an om603 in person, so disregard my posts
 13 Guest(s)
 13 Guest(s)
